Topic: Hmmm I wonder... (Read 25645 times) previous topic - next topic
Hmmm I wonder...
It can work...I just don't understand why people think they need to run a turbo with a twin screw blower....it's a freakin' positive displacement supercharger...it won't stop making boost on that 2.3 at any rpm...low-end, mid-range, top-end...doesn't matter...sell your turbo and make your car a little lighter...you'll be faster.
About the positive displacement I will be adding a bypass valve eventually so when the bypass valve is open the sc cannot make boost. That will solve that problem and just the turbo will be working. And about making the car ligher well ill post some pics of my car.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Hmmm I wonder...
Here are some progress I did today the blower now looks alot better.:evilgrin:
Hmmm I wonder...
Where is the Outlet on that blower?
Hmmm I wonder...
The outlet is the top plenum.
Hmmm I wonder...
looking good !!!!!!
Hmmm I wonder...
Cool, making progress. I see your more of a doer than a talker. :D
Hmmm I wonder...
I think most turbo/supercharger setup's (designed to work together) bypass the supercharger at high rpm's.  I don't know how they do it.
Hmmm I wonder...
A bypass valve set at a given boost rating would do it.  Since the blower is feeding the turbo I would think that you can put the bypass valve in between the two.  The trick is to pick a good point where the turbo is starting to make it's own power.  There would most likely be some experimenting involved here.
http://en.wikipedia.org/wiki/Twincharger
http://come.to/twincharger
http://www.geocities.com/motorcity/lane/1231/20-valve.html
Look here, the aftermarket's getting into it too:  http://www.detroittuned.com/products/index.php?sSection=engine&sProduct=20050324230623
Looks good!  I'm diggin' the idea.  Keep us up to date!
Hmmm I wonder...
Here are some more progress pics.
Hmmm I wonder...
Reply #39
The only issue now that I need to solve is the belt routing. I also filled the supercharger with oil and now its super smooth. Won't be long before its done.
Hmmm I wonder...
Reply #40
the belt looks like its gonna be a pain to do
Edit i wrote that before you posted about it lol
Hmmm I wonder...
Reply #41
Something I would do.  Install a boost gauge on that pipe going from the supercharger to the Turbo.  If you started reading vacuum at high Rpm then you would know it was a restriction.  Would be interesting to compare the reading off that pipe and the pipe going to the intake.
Hmmm I wonder...
Reply #42
Also are you overdriving the supercharger?  On SC's they run at something like 12k rpm because of the jackshaft.
Hmmm I wonder...
Reply #43
Yes I will be checking with a boost gauge on the sc to turbo pipe that's why I installed a nipple on the pipe.
Hmmm I wonder...
Reply #44
going to be an awesome setup
