Topic: Hmmm I wonder... (Read 25678 times) previous topic - next topic
Hmmm I wonder...
Reply #45
I ran into a hault. I finally figured out how to run the belt after installing 2 idler pullies. Well after installing the belt I saw that my supercharger began to flex. After seeing that I installed a support going from the shocktower to the main bracket  and it was super stiff but not stiff enough for the belt and it's still flexing. So now I need to add more support brackets or do something to stop the flexing. I would of never thought the belt tension was that strong, I also removed the wastegate and will be running the engine with the supercharger alone to see how much it boost's. Here are some pics.
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
Hmmm I wonder...
Reply #46
bad ass!!
Hmmm I wonder...
Reply #47
looks good.. use some thicker metal on that bracket.. and it wont flex as much.
Hmmm I wonder...
Reply #48
post some pics of where you mounted the plate
1979 Ford Fairmont
[/B]
Hmmm I wonder...
Reply #49
Very interesting...
Hmmm I wonder...
Reply #50
Well it's not the main bracket that flexs but the legs that bend to one side.
Hmmm I wonder...
Reply #51
Its mounted to the header bolts on one side and the intake bolts on the other side of the head.
Hmmm I wonder...
Reply #52
could you maybe run some more brackets from the intake? like where the two halves bolt together as a brace? maybe gusset the brackets you have now?
1979 Ford Fairmont
[/B]
Hmmm I wonder...
Reply #53
can't cross brace because of the valve cover, hum. I was thinking of ideas but none will work since the motor is going to flex also
Hmmm I wonder...
Reply #54
Triangulate the legs
Hmmm I wonder...
Reply #55
it is a 2-piece intake, right? 4 bolts hold them together? run two more brackets from the 2 closest bolts to the valve cover, to the plate. it would be at like a 45 degree angle, and should clear the cam cover.
1979 Ford Fairmont
[/B]
Hmmm I wonder...
Reply #56
I think Im gonna try that next.
Hmmm I wonder...
Reply #57
Here is an update to make the base stronger I triangulated the legs and welded gussets still have 2 more to go. If this dont work Im gonna have to start from scrath again. here are some pics.
Hmmm I wonder...
Reply #58
Got some more work done on the ole bird. I installed my new lakewood 70/30 struts and the 03 mustang spindles. I still have to run new lines to the manual brakes im converting it to and the line lock.
Hmmm I wonder...
Reply #59
any updates?
1979 Ford Fairmont
[/B]
