Topic: Look what i did! (Read 2148 times) previous topic - next topic
Look what i did!
I dont know what happened. I was taking my girlfriend home, was coming off of an on-ramp at about 1/2 throttle in 2nd gear, built about 15psi, it surged, and i heard a wonderful grinding noise. This is what i found today.
Look what i did!
ah man that sucks!
Look what i did!
Shawn, I'm in the same situation......  so dont feel like your the only one :mad: only I think I got the exhaust turbine..  I'll look further into it today.  I can make about 5psi max
Look what i did!
I did that too, in my Volvo, on Christmas day, two days after I bought it. 200 miles from home. Sucks, don't it? :(
Look what i did!
Well, whats interesting is that the turbo itself isnt done for. The bearings are still good, theres little-to-no shaft play, it spins freely, its just the wheel got chewed up. It doesnt appear that anything got in there, so its possible that compressor surge took its toll.
Look what i did!
Quote from: Tbird232ci
Dunno looks like sumpthin' went through it to me.... Anyway if the bearings ain't bad now they will be, cause its gonna be big time out of ballance... Possibly a piece of the impeller broke and went through it, course guess that gets back to compressor surge...
Look what i did!
Im babying the car untill i pick up another turbo, right now, the plan is to buy a turbo better suited for my setup, and keeping this one. After a while, i want to build it, using a stage 3 turbine housing, a super V wheel and compressor housing, maybe some drop-in ball bearings, and let it sit untill i either build up a nasty engine, or blow another turbo.
I have a turbo in mind, im waiting for some feedback from the company, and probably within 2 weeks, ill have turbo waiting for the car.
Look what i did!
I am looking for a new turbo as well but not really wanting to go with another TO4E.  but then not wanting to spend an arm and a leg for one.
Look what i did!
I'm sorry to hear what happened to your car, shawn.
Look what i did!
That sucks. Maybe you can just get an insert to replace it. I would tell you to go over to turboford.net. They might have some used turbo's in the for sale section. Also they could help you with making a good turbo selection for you setup
Look what i did!
I found the turbo that will work well for my setup, its a T3/T04E 50-trim. Im waiting on a reply from the seller to see what turbine housing it has on it. Its also an "antisurge" turbo, so im waiting on a reply on the details about that.
Look what i did!
Been there done that, in my case the nut that hold the wheel to the shaft was rattling around in the housing... and the exhaust wheel was in the cat.
Look what i did!
That sucks.
Look what i did!
Holy bacon.
I guess I have one more thing to worry about...
Look what i did!
Sucks man , but now it is time for an upgrade :)
