Topic: Look what i did! (Read 2167 times) previous topic - next topic
Look what i did!
Always nice to find things that break when you least suppect it, at least you found what broke right away, I am still looking for the cause of some problems on my truck! lol
daniel
1987 Cougar XR7 5.0 SOLD
1992 Ranger 4.0
2018 Hyundai Elantra
2019 Ram Rebel
Look what i did!
Quote from: cougarcragar
Holy bacon.
I guess I have one more thing to worry about...
Ah I wouldn't worry too much, I have yet to have any major turbo problems (knock on wood)
With the factory T3 on your cougar you'll be fine.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Look what i did!
Its 100% done for now. Its pumping oil into the intake, so the bearings finally let go. Ill just block off the oil feed, and baby it.
Look what i did!
Quote from: Red_LX
Yeah, but the car smokes more than I do.
I plan on a complete rebuild within the next year.
Look what i did!
That sucks.  Well, at least you have an excuse to upgrade now.
88 TC, Lots of Mods.
Look what i did!
Quote from: Tbird232ci
that sucks, I was lucky that when my turbo went some sludge plugged up the oil feed line solid (probabally led to the turbos demise in the first place) if your no longer making boost remove the intake tubes from the turbo and route them together you will get a bit more power out of it.
Look what i did!
Quote from: Birdman
Thing that sucks is, it was already a hybrid!
Look what i did!
I found the turbo that will work well for my setup, its a T3/T04E 50-trim.Its also an "antisurge" turbo, so
Shawn, what do you mean by this?  mine surged well I could hear what I thought was it surging :dunno:
I guess it will be another TO4E for me since they are a dime a dozen.....
Look what i did!
Theres two different meanings to the term "compressor surge"
One meaning is the more common, when the throttle blade closes, and the air is forced back through the turbo.
The other meaning is when the turbo is pushing more air than the engine will physically take, as in a large restriction, and the turbo "hiccups" because the air is forcing back to the turbo.
Look what i did!
so by antisurge your meaning that you shouldnt need a BOV? I'm still totally clueless on this subject but I guess this is why your here :D
