Topic: Son of a biscuit! These subframe connectors are kicking my ass (Read 2519 times) previous topic - next topic
So 2 days ago I started on my subframe connector install, got the seat braces welded to the connectors and  the reinforcing tabs welded on, and my welder ran out of wire. So I picked up a new 1 lb spool before I left work yesterday. Today I started putting the connectors in, got all the welds done except the inside two on the back (on the subframe side facing the lers) and the welder ran out of wire AGAIN:toilet:
So, I guess my question is, will this thing be OK without those last two welds for a couple days? I won't be able to get at it again until Sunday most likely. I hope it'll be OK as I don't have any choice except to drive the car as is :dunno:
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Should be fine.
Second that Should be fine remember the car got by w/out them for ever you know better then me there your welds as long as there strong enough to stay there and you don’t do any road course racing so that the car flexes to the stress point to break them. Even still you should be fine with good welds on have them.
Subframe Connectors
Whats up man! I was just trying to figure out where to get subframe connectors for a tbird!! I dont know if mustang connectors would work or not!! All and any help would be appreciated!!
Whats up man!! Just wondering where you got connectors for a tbird.......all i see them for is a mustang.....they may work.....im not sure!! All and any help would be appreciated!!
http://www.40bob.com
They're on there. Or you could make your own, the Thunderbird's connectors are just straight 1"x2" rectangle tubing with endcaps welded on.
Garrett H.
Exhaust sound clip
Another clip
Hey man....thanks alot!!
Quote from: Red_LX
That'll work if you're doing through the floor connectors...see the angles on Bob's SFC's?  You kinda need them if you don't want to hack/beat the  out of your floor pans.
Huh?
Mine were just straight stock and they welded in just fine...didn't hit anything. The ones in the pics with the "angles" are the ones for the Mustangs.
Garrett H.
Exhaust sound clip
Another clip
The SFC's I did for the Tbirds were straight and have always been straight.  The offsets were not needed.
The KB sfc's I have are straight as well...
I'm straight too.
Quote from: tbirdscott
I'm straight too.
are ya sure? ;)
:rollin:  kiddin' man :D
Wow, if straight SFC's are working for everybody, then I must have a serious problem.  Disregard previous post.
yeah don, if u come out ever again :p we can compair SFC's
