Topic: Wheel Lock Removal (Read 5744 times) previous topic - next topic
Wheel Lock Removal
Ok here's the deal. I need some ideas on how to get these bad boys off. I got two of them off via socket and jb weld. Tried to repeat on the rears and it failed. Now I'm out of useless 3/4 drive sockets and jb weld... and ideas.
Hiizelp!
Wheel Lock Removal
Cuttin tourh and Vice grips???
Heat till they expand the torque them off???
Wheel Lock Removal
can we have a pic of your setup?  you might be able to use a chisel but you have already told me that you dont have one.  so......  have you tried beating a socket on there with some jb weld??
Wheel Lock Removal
Quote from: 88turbo
I don't know why but the rear ones wouldn't hold with the jb weld like the front ones did. One socket was pretty big though... I may have to just go buy two more cheap 1" sockets and another pack of jb.
I can get pics.
Quote from: 84 Fila
Got the Vise-Grips. No torch. :(
Wheel Lock Removal
go get a chisel.....    thats about a sure fire way to get them off..  just chisel in the direction that you want the nut to turn.  we did this on my shop teachers 57 bel air
Wheel Lock Removal
Any decent tire shop will have a kit to take them off.
I got mine off with an impact socket and a sledge hammer.
Wheel Lock Removal
Here's the two successful ones.
The failure
And the setup.
Wheel Lock Removal
I have a key for the ones on the Vic when it had them would it workd on yours?
Wheel Lock Removal
It looks like it will work, I'll get pics of it for you if you want
Wheel Lock Removal
Quote from: 84 Fila
Sweet! Please do. :D
Wheel Lock Removal
I got to wait till tomorow, My freinds borrrowed my car. Is that cool? Try the chisel in the meantime.
Wheel Lock Removal
You gota use 12pt sockets to remove wheel locks... the 6pt dont provide enough traction.
Wheel Lock Removal
The key may "look" like it's going to work, but most likely not....they all look the same at a glance.
Looks like your best bet might be to pick up a couple more cheap sockets and try again.  It might also help if you have a cut off wheel to cut a couple slots across the end of the lug to give the JB more to bite into.
