Topic: *S.O.S* I Need help! (Read 7435 times) previous topic - next topic
Quote from: 88turbo
since nobody hit this one......  how many miles does this car have?  very possible that you spun the plastic teeth off of the timing gears causing it to jump time.  if nothing else works that would be what I would put my money on.
That's weird. I've never had a 5.0 with plastic timing gears.:dunno:
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Quote from: Warbird9
thats what i had in mine... pos plastic gear... :D replaced with a nice double roller coyles one
Well after running out of time and Ideas, the car has been taken to the Ford dealer. Let's hope they don't rape me TOO much in the ass.
Quote from: baXo
So...exactly what is your definition of "too much ass-raping"?
In my book any ass rapage is to much. As for the plastic gears I've seen cloyes sets that the gears are basically hardend card board. Those where for the old chevy 250 I-6. That one blew my mind.
Quote from: EricCoolCats
OK, I have a feeling they will no use lube before the raping
Quote from: Chuck W
Well, mine is ANY!
Just as an update.. they THINK it's the ignition switch so they've ordered it. should be in late tomorrow let's just hope it is so I don't get any further delays and I can actually make it to Cat Jam.
Just an ignition switch?  That should only cost you about $500 or so.  Hah, just kidding.  They charged my mom about $250 to replace the ignition cylinder in her '00 Focus, so I'm guessing around that area.  Unless the ignition switch costs a LOT.
In my Cougar, it was just a case of rotten gas. Shot down the intake got it fired, that told us enough, we just pumped the tank somewhat dry and added new. Mine sat for 15 years.
Quote from: Ifixyawata
:eek: Holy S$#t! Are we talking about the switch under the steering column cover?? If so, http://www.50resto.com has em for like 12.95. The ignition cylinders aren't much more. That's the kinda  that makes me a do it yourself kinda guy.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
My mom's car has a sentry-key kinda thing.  Plus, she didn't wanna wait for me to fix it, if that's what you're talking about.
Yeah, ignition switches are a bitch to change.  Lets pull the wheel, that's fun.  Either way, if we could have diagnosed that, we would have fixed it, but we didn't.
Willpower is no match for Horsepower.
, I never realized you had to pull the wheel to change the ign switch.
only takes 5 mins to pull a wheel unless theres an airbag involved
