Topic: what makes true power (Read 5257 times) previous topic - next topic
what can i put into a 5.0 to make it feel like i did a big difference  not something to expensive but somethin that you can actually feel the difference
Re: what makes true power
rear end gears....and maby a shift kit.  my  :2c:
for some "free" hp...advance the timing, ice the intake and remove the passenger seat, spare tire and anything else to save weight (at the track), remove the air box from inside the fender, run a short belt bypassing the smog pump and ac.....
~John~
Free up the exhaust.  I gutted my main catalyst (it was broken & turned sideways anyway, & the little ones were already gone) & I definitely noticed the difference.
Reducing the restriction of the exhasut may free up top end power, however will hurt your lower end of the power band. To do this with 3.73's may help out, or at least give you a nice exhaust note and quicker launches. Headers, x-pipe (h-pipe), hi-flow lers and a set of 3.73's are what I would suggest. Removing the air silencer is free, advance the timing to 14* is also free, but costs on the end of running 93oct or better.
i prefer false power
Adding a NOS sticker to each c pillar window will give you an instant 50HP.
But seriously, nitrous would give you the boost you want, at a pretty penny though, roughly 1200 for a starter kit.
Quote from: t0x1k
 NOT..... a basic kit 75-150 shot would be about $500.
Quote from: 88KSXR7
Guess I wasn't looking hard enough because all I was seeing at pep boys was a 1000 starter kit...
My engine ('88 5.0) gained across the board when I gutted the cat.
Quote from: t0x1k
Thats your first error,  There are many brands out there heres a list from  summit:
  CCA-82015  Ford: 1986-95 5.0L/1996-99 4.6L Mustang, adjustable from 55 to 75 HP, nitrous oxide system
  $509.95
heh, took the words right outta my mouth 88ks lol. haha, pep boys....
I gutted my cat and it seems that I am running through gas like it is nothing. Granted a 5.0 uses a lot of gas as it is but this is a little crazy. Is this because of not having a cat or is something else causeing my milage to drop?
sounds like you have no back pressure and are hitting the gas harder for longer to get going .
If the exhaust is still stock I'd say there is still a decent amount of backpressure.  Could be any number of things.  Timing might be off, injector stuck open,  leaking gas tank (YES I had a friend driving around for quite some time like that before he figured it out :giggle: )
Just checked the timing, it is right on the money. I guess the next thing I will have to check for is the injectors. Please tell me I can take them out without takeing my intake off?
