Topic: what makes true power (Read 5256 times) previous topic - next topic
Re: what makes true power
If there's a way then I don't know it!  You should be able to tell if it is leaking or not without taking them off though....Run your car, wait a couple minutes and pull the spark plugs.  Look for incosistencies I.E. All plugs look good except the one that is extremely wet, oil coated, glazed etc.
    I know I say it time and again, but Keep your cars tuned up as well.  I have an aftermarket cam with a Speed Density setup.  It runs well and has a good idle, but the minute it starts to get rough I know where to go.  The plugs.  I get about 12-15K out of a set of plugs which is less than average I would assume.  That's why I always harp on it.
500hp fogger nitro kit, and a blowzilla blower from kennebell. that will put your ass in the seat, probley only last till the end of the quarter tho lol... :p
Quote from: Manson
that'll put your ass in the BACK seats  :ies:
if u call around your area to speed shops or hang out at a track u can find a nitrous used for cheaper.
