Topic: A picture is worth a Thousand WORDS (Read 6034 times) previous topic - next topic
Here is a track shot of me versues Turbo Viper, I got him out of the hole but my I/C pipe blew about the top of 1st gear.
 I would have loved to see the look on his face when we left though
Well apparently the pic you posted is worth "0" words....
Did you forget something? ;)
If pictures are worth a thousands words, i think you just took a vow of silence.
Hey try that pic, The file was to large and it was late last night.
  So I screwed up.
  Enjoy
where's the fender??  funny way to cut down wieght  :):welder:
That's some serious cold air intake. :)
Uhh Houston, we have a problem...
Keep having problem with the I/C pipe blowing off so we just pulled the fender off for easy access.
Quote from: 5.8fastcat
:rollin:
You're a lunatic :giggle:
1st things 1st get the pipe to stay on then we will worry about what the think.
are you going to try and put a lip on your  ic pipes, then clamp the rubber connectors down behind it so they cant pull apart? i plan on running some boost in 2 of my cars, more in one... but anyway i'd be interested to find out what you do to fix it so i can copy it later on :p
Hey, good luck with that I/C pipe...how about some power numbers?  Turbo size, boost pressure...c'mon man, I'm drooling!
Check out the post with the video @ the track the 2nd page has pictures.
 Have welded lips on part of the pipes now it only blowes it off @ the MAF and it has a Aluim  that is polished so I'll have to tig a ring on it now.
what kind of clamps are you using? when i was using regular worm clamps on my buick- once i would hit 18-20 psi the IC hose going into my front mount would blow off. i switch to t bolt style clamps then it would go 30psi no problem
heres the clamps i use
http://www.racepartsolutions.com/products.asp?cat=27
I have t bolt clamps now and only 12 lbs of boost
