Topic: A picture is worth a Thousand WORDS (Read 6282 times) previous topic - next topic
a litle duct tape always proves to be a great fix even if you have to use the whole roll and it would look wonderful with the black! what do you guys think?
Quote from: cougar86_89
I don't think duct tape would stand a chance, not even a whole roll. :)
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Part of your problem might be your blow off valve. Not sure which type you have. It may be to small so when the throttle slams shut the valve is not flowing enough cfm so there is to much pressure in the pipe. (had that problem with my procharger)
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Ohh... just realized you have an auto so maybe it's not the valve!
192hp
