Topic: Quarter drain hole (Read 2006 times) previous topic - next topic
Quarter drain hole
The drivers side quarter panel seems to have a drain hole, but its plugged with a rubber plug (or something). This side has been getting water in it for the last couple years and just curious if the plug was supposed to be pulled long ago. The passenger side has nothing though. Any reason why?
1988 Thunderbird Sport
Quarter drain hole
The plug is supposed to be there, the other one probabally fell out, find where the water is getting in before your car decays.
Quarter drain hole
There isn't a drain area at all on the passenger side though...
About where the water's getting in, before I thought it was the weatherstrip but turns out thats not it...it isn't through the tail light either. The moulding mounting holes on the side are covered with aluminum tape and primer. There really isn't a logical place the water's coming in and looking in the trunk after pulling in from the rain shows no runs. Its a pita to find the thing
Quarter drain hole
Mine does the same thing.  Water in the spare tire well.  I just drain it every now and again.  My weatherstriping is in perfect shape too?  I havn't located it yet.
Quarter drain hole
Rear window seal...or the trunk corner seal, in the perimeter rim up by the hinge. Sometimes spraying some rubberized undercoating along the bottom edge of the trunk rim helps.
Quarter drain hole
Eric, am I dense...or did your userid change?
Quarter drain hole
I have an 87 XR7 and was having the same problem. After 9years I
found it to be the marker light. The light screws into the 1/4 panel
theres a gasket between the light and 1/4 panel.
Quarter drain hole
I agree with Eric - rear window seal. They tend to become unsealed (sometimes to the point the rear window rattles). My '88 has this same problem
Quarter drain hole
I have an 87 XR7 and was having the same problem. After 9years I found it to be the marker light. The light screws into the 1/4 panel theres a gasket between the light and 1/4 panel.
Ah HA....that is a very good observation! I really never deemed that likely until I read your post. Might want to add that to the list of things to check. Nicely done.
Quarter drain hole
Quote from: EricUncoolCats
But he has a Thunderbird, and Thunderbirds don't have that marker light...
Quarter drain hole
good save eric :p
My 80 was leaking through thr trunk lock when it rained, the little flapper thingy inside didnt close all the way or was bent and allowed rain to get in, took a while to figure that bugger out
