Topic: Anti-Moans??? (Read 4060 times) previous topic - next topic
Anti-Moans???
Are these needed? I'm in the middle of my 5-lug conversion and I need to know asap. Thanks.
Anti-Moans???
well...they can be added later if your brakes vibrate...they look like they support them some what as well but you could probably get away with not using them...
~John~
Anti-Moans???
hmmm... i suppose i better put forth an effort to get them on then. i've got a 10 hr road trip to make.
Anti-Moans???
what's the best way to get the stock tc brackets off?
Anti-Moans???
which brackets?
Anti-Moans???
i cut them off with an angle grinder......if you unbolt them you  might be able too bend them back and forth untill they break off then grind the welds smooth.
~John~
Anti-Moans???
the antimoan brackets.
sweet. i'll give it go when i head out to the garage tomorrow. though i don't recall where the welds are...thanks john. :)
Anti-Moans???
you probably should use them if you have them for the new brakes...the turbo coupes anti moan brackets are welded to the axle housing tube....
~John~
Anti-Moans???
I didn't have to ditch my TC antimoan brackets. I got all my 5 lug stuff (brakes only) form a 96 stang. The j/y wouldn't let me have the backing plates(they said I had to buy the whole rearend for those-yeah right) They did let me compare my TC plates to the stang ones. Stang's were different thickness. I said wth and put it together with the TC plates. I have moser 33 splines with c-clip elims and brembo rotors and have to space the caliper out approx 1/4 inch which leaves plenty of bolt left to hold the caliper. Am i missing something here? I haven't reinstalled the rearend yet.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
Anti-Moans???
You're planning to use disc brakes with C-clip eliminators? That's pretty gutsy. :) There shouldn't have been enough of the axle shaft to even fit the C-clip eliminators on correctly. Did you remove the exciter ring from the axle shafts? If I were going to run C-clip eliminators, I'd be using 1999-2004 Mustang axle shafts since they're longer and will provide enough surface area for the eliminators to clamp to. But that's me.
Anti-Moans???
well i ordered the mosers for a 96 mustang to get the proper length. there are no exciter rings on them. the elims were preinstalled and there seems to be plenty of engagement in the spool.
TC#3- parts car
Anti-Moans???
Ah, gotcha. So that's why you had enough length to install the eliminators. Normally C-clip eliminators and rear disc brakes are a big no-no to do in a stock configuration. Aftermarket parts make all the difference though.
Anti-Moans???
i hate these  brackets... i had to go buy a dremel tool because my angle grinder is too friggin big.
Anti-Moans???
Quote from: darkthunder
Out of curiousity, what 5 lug parts are you using for the swap? Is it possible to use your existing TC calipers with 94-98 mustang axles and 91-92 Lincoln Mark VII rotors? I read somewhere that this is the set-up Ford used on the 1993 Mustang Cobra R.
Anti-Moans???
heh..that blows...give em' hell ;)
~John~
