Topic: Anti-Moans??? (Read 4061 times) previous topic - next topic
Anti-Moans???
I am using 96 Mustang rear brakes and axles. From what I read on coolcats they don't interchange... i would of verified this but I have no patience to do so at the moment, as I still have the front to deal with.
Anti-Moans???
The MK VII rotors are bigger than the TC rotors, so you can't use them with TC brakes.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Anti-Moans???
Quote from: EricCoolCats
Ah, gotcha. So that's why you had enough length to install the eliminators. Normally C-clip eliminators and rear disc brakes are a big no-no to do in a stock configuration. Aftermarket parts make all the difference though.
Man, I was getting a little nervous there thinking what the heck did I put together?:hick:  LOL. Only reason I went with elims was to be drag legal for 9 second passes. I know the rotor will keep the axle from coming out in the event of failure, but didn't think that would be sufficient for NHRA specs.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
Anti-Moans???
i preferr a moaner to a screamer...nyuck nyuck....
~John~
Anti-Moans???
finally got them brackets off. now if my bearing puller would show up i can button up my rear end. if i had to do it all over again i will just mount the stang caliper bracket and drill into the TC bracket to cover the offset.
Anti-Moans???
Quote from: cougarman
The 84-90 MArk VII Rotors are bigger, they are 11.3 or so in for 91 and 92 they changed the size to 10.5 with a similar hat design as the Turbo coupe rotor, only 5 lugs. The reason i was asking is because the rotors for the Cobra R have a 91 lincoln part number.
Anti-Moans???
thought the 93 cobras ran tc stuff out back only diferance was axles i think. but could be wrong i know the front is a whole different animal
Anti-Moans???
Quote from: CougarCoupe88
93 Cobra and 93 Cobra R are toatlly different animals brakewise.
The "std" Cobra used the TC stuff in the rear, including the axles (ths the odd offset on 93 Cobra wheels) and are 4-lug.  The fronts were std GT (11" Fox) with a different rotor. The "hat" was taller...
The Cobra R used what was to become the Cobra brake package on the SN-95's.
Anti-Moans???
Quote from: Chuck W
Nope, the 93 cobra R used the SAME calipers and brackets as the standard cobra (or Turbo Coupe). The only differences were the 5 lug rotors and axles. Check out the SVT Cobra Recognition Guide book, in the back they have a list of Cobra R unique part #'s, the only part numbers given for the rear brakes were the rotors (a 91 lincoln part #) and axles.
Anti-Moans???
hmm i just used 94-98 axles ,94-98 rear rotors with the diameter turned down .200 .used the t/c brackets ,caliper,pads,etc when i done my 87 shimmed the caliper brackat as needed to center the rotor in the bracket aprox 3/16th
Anti-Moans???
Quote from: SLEEPER T-BIRD 87
I didn't think about doing it that way. You can safely turn down the diameter of a rotor? I used mustang calipers but the t/c brackets and had to shim out the caliper the same 3/16 of an inch.  How much of a total track difference over stock is there? On wheel choices, I'm considering 15x9 with a 5.5 backspace (prostars).
TC#3- parts car
Anti-Moans???
Quote from: Pressure cooked chicken
yes, It is safe to turn down the diameter. I didnt notice a differance in track width i think most was in the hat depth of the rotor.I would probly go with a 15x10 with a 6.0  i have 15x8 w a 5.5 and there way in the wheel well. My slicks were mounted on a set of 15x8 with 4.5 rear spacing and filled the well good.
Anti-Moans???
Good grief, 15x10 with 6.0...... I would like to run a 28x10.5 slick. Would that size with that wheel keep from rubbing the inner wheel well and fender lip(rolled of course)?
TC#3- parts car
Anti-Moans???
I dont think it would be an issue. I ran a 17x10.5 on the rear of mine for a while. If i get a chance today i will mesure from inside the tire to wheel well.
Anti-Moans???
pulling this back up. sleeper t-bird 87 did you get a chance to measure the clearance from tire to well? pics would be great. I only ask because your'e about to get rid of the car. thanks
TC#3- parts car
