Topic: Little advice please (Read 1630 times) previous topic - next topic
ok every one here is the deal i have my car gutted completly the only thing left in there is the steering column. I pulled the carpet and relized it weighed like 40 to 50 pounds i belive most of the weight is the insulation dedening . My question is if i pulled all the insulation off of the carpet and put a layer of fat mat down on the ground instead would that be good enough to quiet down the ride or is the insulation a must. I have heard real good things about fat mat my buddie says it is a good insulater as well but he only has it in his trunk so i am not to sure. I am just trying to lighten the ride a lil bit 50 sq feet of fat mat only weighs 12 pounds. Let me know what you all think is the best route to go here.  THANKS
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
I ran a 87 TC with open 3" exhaust for over a year completely gutted. I even cut out the door frames. Didn't bother me one bit, and that was in Florida heat too. Passenger's always bitched though...
only 50 lbs.. i figured it would weigh more than that.
it might weigh more then that it was just a guesstamate i mean it is not like it was quiet before but i had the pipes exiting right in front of my rear tires and now the pipes will cut off right at the axle and it is my everyday car sometimes i got to drive it kinda far sometimes 40 to 50 miles over there then back so if i cal loose a lil wieght and keep the sound down that would be great
i sed all the tarmat up and put down dynamat extream over everything. that quieted it down alot, but i also kept the jute because im a noise freak :p but you dont need it. if you want remove the jute from the carpet and maybe go to a carpet store and buy something thinner to put under their instead if your worried, but i would deffenatly se the tarmat stuff off if you going to put another sound deadener on it, thats another like 40#s and it will also give you a chance to address any rust you may find hideing under their.
so i should get ride of the tarmat as well i sed it in the trunk and sprayed down some gravitex its like a light duty bedliner what is a good way to get it off the floor cause it sucked ripping out of the trunk
Quote from: Sprayingsmooth
hand held propane torch, heat it and pull it up.
the insulation on the carpet comes off easier if you wet it first.
(this makes a good time to clean the carpet)
i took probly close to 100lbs out of mine that way. still have to remove the crash bars from the doors.. 30-40lbs per side
i used a heat gun and ser, came rite up. just heat for a second and wedge the ser under it. then its just heat and push, took about a night after work to do most of the inside of the car.
