Topic: dyeing seats (Read 3853 times) previous topic - next topic
dyeing seats
ok i know some of you guys have dyed your seats now im wondering if u got caught in a rain storm and you have been soaked will the dye come off on your wet clothing?
Got that fox rash again!
-Resident smartass! :ies:
Re: dyeing seats
most likley not,make sure you get the premium or high-quality die but make sure you clean your seats really good before you dye them.
Re: dyeing seats
so shampoo the hell out of em then let em dry
Re: dyeing seats
yeah,let them dry really good are you planning on removing the covers from the seats then dying them? or dying the covers on the seats?
Re: dyeing seats
the entire seat its a 84 cougar
Re: dyeing seats
how would  you remove the cover? Tearing out a few of the stitches?
would be easier to redye mine that way if I did (likely won't since it won't be as vibrant as when new - just look in the crack at the front of the seats. Most of the colors really shined when new. Also have a busted right side of my driver's seat. Either needs to be attached again (whatever "fell apart") or needs to be welded back together. The back support is weak on the right side :shakehead
1988 Thunderbird Sport
Re: dyeing seats
i havnt had dye come off on my clothing yet
Re: dyeing seats
underneath the seat do you have hog-rings or rubber straps holding on your cover?
well there alot easier if you remove the cover.
Re: dyeing seats
the seat portion looks easy to get off but the backrest is what looks difficult. I figure it can't be all that difficult though, as I doubt ford would make something complicated that'd take a lot of time (time is money)
Re: dyeing seats
there should be a bolt on the side of each seat its a big torque Screw. Turn it left it should slip off of the lower secton.
Let me know if you need anymore info?
Re: dyeing seats
and the headrests are easy just pull up hard and they come right out.
