Topic: Door Lock Relays (Read 1385 times) previous topic - next topic
Door Lock Relays
Well, it looks like my driver door lock relays went out cause t he passenger side works just fine.  I'm about to install an alarm and I would like to get the locks working first.  I need to know where to find the relays.  I have heard they should be under the passenger seat but after locking I found nothing.  I'm looking for these relays on an 86 3.8 with keypad.
Door Lock Relays
Its not a relay that is bad, it is the door lock actuator, a common problem actually. To get at the actuator you must remove the door panel, unplug the power wire, and drill out the rivet that holds the actuator hanger. I have replaced these in my Cougar and my Lincoln Mark VII. Factory Ford ones are the best, but very expensive. I usually just get a set of used Mustang ones from E-Bay and just swap the rod.
Here is a link to what you need.
http://cgi.ebay.com/ebaymotors/1979-1987-1993-MUSTANG-COBRA-GT-LX-DOOR-LOCK-ACTUATOR_W0QQitemZ8026167960QQcategoryZ33706QQrdZ1QQcmdZViewItem
Door Lock Relays
I agree, it's probably the actuator.
Lots of Fords from the era used the same actuators, look in the junk-yard for something similar.
