TFI module going on a permanent lunch break?-SOLVED
Hey guys, for a few weeks now I have been having a problem with the 'Bird(HO conversion). Usually when it's cold, it will backfire slightly/misfire on other cylinders. I had AR133 plugs in it which I knew were too cold for this time of year, so I swapped the Autolite 25's back in. That helped but the problem still lingered, usually between 1500-2000rpm and approximately 20% throttle opening. I pulled the dist. cap off and noticed the rotor was cracked...new cap+rotor and a throttle body service later and it was running like new...for about an hour. So, I figured my wires were the next step..they were about 2yrs old and quite britle. The problem went away all together. About 300miles later it's back in action and worse than ever.
If I go full throttle from a dead stand still, it won't backfire or anything but just feels like it's tied to a tree until 3500rpm(like a 4cyl with nitrous...lol), it takes off like hell from there but now at about 4200-4600 it starts breaking up badly. It's definitely not valve float...And it doesn't exhibit these symtoms ALL the time...it happens often but isn't speed or temperature specific...I'm having a hard time diagnosing it simply because there really is no patterned failures.
Any experienced advice would be welcomed
Thanks and Merry Christmas,
Don
