Topic: Im going to give up. (Read 8611 times) previous topic - next topic
Took the TC to the track
first run was a shakedown, only had about 8-10psi in it because i just put the controller on, ran a 17 something, thats not important, second run, after having to "reconstruct" my boost controller, it made an insane amount of boost, blowing the upper hose off before i could lift, third run was a clean, and VERY dissapointing run
60ft-2.7
1/8- 11.2
mpg- 67.5
1/4- 17.14
mpg- 82.8
Even driving the car home, it made no power, i thought i blew out my bypass valve, but it seems to be fine, sounds as if it has a boost leak, but i didnt pull the intercooler off yet to mess with the hoses, i know my upper hose is about shot
ill take some time tomorrow to try to find out what the  things problems are, then finish up the mods i plan on and just drive the  thing, i chase more problems at the track than anything.
Well, i tore into the car, turns out that my lower IC hose blew off of its seat, an was leaking boost. Easy fix.
I also did a little bit of math, and if i were to get my 60ft down to a 1.9, i could have had a 15.60 or so, on 8psi, which isnt bad in all reality
So with full boost and a 1.9 what is your goal?
all i really want out of the car is a mid 14, just enough to have a little fun
when are you going back to the track shawn?
probably in the spring time
cooch....
~John~
You are what you eat, you dick.
then I guess that makes me a cabbage roll
pshhh....i got nothin... :(
~John~
hey now, even if it was a low 17 second run, you still got 82 miles per gallon.
4 cylinder fury! 17 seconds AND gas milage.
Yeah, Manson caught that, i looked at it and said "i aint changin it"
well then, I would like to formally complain against you.......or something.
If you could get a patent on that MPG... You'd be a rich man...
Was this at ital?
BTW, I'll be in Linthicum next week....I love going back to 'redneck ville' :-)
Ryan[/i][/COLOR]
1986 2R[/b] SVO
1984 T-Bird 5.0 (In Hibernation since 10/96)
