Topic: Im going to give up. (Read 8990 times) previous topic - next topic
whats your timing set at? my first pass ever in my TC was a 17.2 @ 82mph, timing was way retarded, got it set right and it ran 15.9 @ 87.
14* btdc
Quote from: turbo88
the motors are not tourqueless, mabey tourqueless to you but not  for a 4 cyl they have plenty of grunt, and hey the turbocoupes get good gas milledge and also are great and fun cars to drive, have you ever owned a turbocoupe or do you own one now? if so i dont think your would have said what you said. and with the turbos there are plenty of cheap mods you can do to make more power, and putting a 5.0ho in them wont solve much either just makes the car heavier and less of a "handler"... im all for the 4 cyl :headbang:
So what does the torque curve look like?
http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=5639&stc=1&d=1138476555
Peaks at 4 drops at 55 with peak of 220. Not a real good torque curve, but it is a 4cyl so most dont have a flat torque curve. Putting a V8 wont solve much either? Please tell me your kidding!
James:rolleyes:
What are your RPM's at launch?  Shift points?
Mine?
I havnt dialed in a launch, probably around 3,800 and i ride the clutch out a bit. I shift at about 6,000.
