Topic: just an idea. (off the wall idea) (Read 10355 times) previous topic - next topic
Reply #45
well you could hook them up as a SVC just need to take a positive from one and the negative from the other. wolla svc. but the amp does say it can handle the new subs all day long (TS-W106DVC) so im guessing it could also handle my old ones (in good shape.)
Reply #46
well i like the pioneer products ive heard systems way beter than mine but i like the bang for the buck. like i said b4 my subs would probably be allrite if we didnt hook them up wrong. (oh well we live and learn.) they do work just a svc. im also going to talk to my stereo guy and see what he recomends me get. as for an amp to run with the subs.
Reply #47
Quote from: CougarCoupe88
Doing what you saying would take a 4 Ohm DVC and turn it into an 8 Ohm SVC.  Not a good idea if you want any decent sound.  if you brdge those you are still going into a 4 ohm mono load and whats the point.
Reply #48
oh. i didnt know that. so the lower the ohms the beter ? oh and by the way im not really set on a pioneer amp. so maybe and mtx i will get .my brothers got one and it's nice.
Reply #49
Yes lower ohms the better, BUT you have to make sure your amp is capable of handleing that load, Lower the load the hotter tha amp,  Most amps will handle a 2 ohm load easily.  THe pioneer you showed is only capable of a 2 ohm which you will not beable to get with 4 ohm DVC's
Reply #50
well why do they say this. it's just doesnt make sence thats all unless they just want to sell product.
2-Ohm Mono Stable
The GM-7100M is built to efficiently handle low-impedance loads, down to 2 ohms. That's perfect for a pair of 4-Ohm Woofers like the Premier-exclusive TS-SW124D Shallow subwoofers, or running a Dual Voice Sub like the TS-W126DVC or TS-W106DVC.  And it doesn’t just “handle” them: it continually monitors and adjusts the power supply voltage rails, for continuous, clean output. Among other things, this means that you can connect it to two subwoofers.
Reply #51
The key work there is "a Dual Voice Sub".  That would be perfect for running only one, because you could wire the voice coils to a 2 ohm load.  But since you want to run 2 of those subs, that amp would not work.
Reply #52
Ok, If you insist on usint DVC get two 8 ohm DVC's  these can be wired into a 2 ohm load.  just connect all the pos (+) together and all the negs (-) together on the subs wire it to the bridge mono on the amps and you have a 2 ohm mono load.
Reply #53
well maybe i should only run one bc of the size of a box and all.  im not insisiting on running a DVC. i was just throwing that pair together to see what you all thought. thanks for all the help im a little clearer on the subject now.
would a single 10 inch DVC run on a 2 ohm load give me what im looking for ? the nice clean hit with a punch ?
Reply #54
yes a 4 OHM DVC can be wired into a 2 Ohm.  take the + from each coil wire them together and the - and wire them together. Makes it a 2 Ohm SVC essentially
Reply #55
We'll  I put two 10" in my rear deck and 2 12" behind the rear seat. I did do alot of work to seal the trunk from the interior of the car. I fiberglassed the rear deck under the carpet. I removed all rear interior plastic and seat. I sealed all the air gaps with expand foam. behing the rear seat I drilled ou the spot welds on the cross memeber. Then I installed to layers of 3/4" plywood. bolted it down around the outer edge. fibergleassed it in. The bass is tight acurate and LOUD. more than I could have asked for. Plust I still have trunk space.
