Topic: no spark from coil (Read 1170 times) previous topic - next topic
no spark from coil
i have changed the comp, coil, ing mod. still have nothing. also checked voltage at coil and that was good. please help.
Re: no spark from coil
Take your distributor cap off, have somebody crank the engine, and verify that the rotor is turning. You may have broken a timing belt, and if so you'll have no spark because the distributor won't turn
i dont have a spark leaving coil, timing belt is ok.
Quote from: tbirb23l
ok since you said timing belt i am assuming it is a 2300 turbo
they are bad about eating distributor gears pull the cap off and make shure the rotor turns.
then take a test light and put it in the positive side of the coil (orange or red wire) turn switch over it should light the test light if it does you have a tfi problem possible wiring
yes it is 2.3l. i do have voltage at postive term. on coil. 9.87volts at coil. i also changed the dist.
it should have a full 12v at the coil
sounds like a wiring issue that you have. between the tfi module and the computer
i will check that.  thanks. will check in fri.
any luck?
