Topic: EFI or Carb (Read 1865 times) previous topic - next topic
EFI or Carb
hey guys, I got a question and I'd like your opinions...Should I convert to HO intake, computer, MAF, injectors, or should I go to a 6 pack or dual 4bbl setup? A guy that I know builds carb kits for like 1500...
Re: EFI or Carb
Efi
Re: EFI or Carb
Quote from: Chuck W
Efi
 what do you think it'd cost to do a SO intake to a HO MAF setup?
Re: EFI or Carb
oh one more thing...how can ya tell what size your injectors are?
Re: EFI or Carb
14lbs are grey in color 19 lb orange or tan color
Re: EFI or Carb
Quote from: 86Tbuzzard
6 pack and a dual quad is much more carb than your 302 would ever need, while it looks cool, the car would run like ass
just go with an HO setup, stuff is only as expensive as youre willing to, its not hard to find stock HO stuff
Re: EFI or Carb
You really won't have to go to mass air. That is unless you do the full H.O. conversion to your existing motor or swap in an existing H.O and do significant modifications. If the motor is going to be basically a stock H.O., it will run fine on speed density.
Heres the info on converting your existing motor to H.O.
http://www.coolcats.net/tech/advanced/ho_conversion.html
Re: EFI or Carb
i would suggest going with a carb
a holley 600 vac secondary and a preformer or performer rpm intake will work just fine on a mild 302
Re: EFI or Carb
Quote from: 88SptCoupe
all grey or just the tops of them?
Re: EFI or Carb
Quote from: 5.0willgo
it's gonna have a cam, maybe a Supercharger in the future...I'd better go with MAF
Re: EFI or Carb
the 14 ones are all grey the 19 lbs are orange and tan if you need a pic of the 14 lbs once i can get you it
Re: EFI or Carb
might be helpful...mine are grey but I think part of them are orange
Re: EFI or Carb
yeah they're 14 lb injectors
