Topic: dash speakers (Read 4273 times) previous topic - next topic
Re: dash speakers
3-1/2" with a max depth of about 1-3/4"
anything else ;)
Re: dash speakers
bought mine at best buy pioneer brand 80w max sound good. must re-drill mtg holes as t-bird are of set fromthe aftermarket version
Baylensman 97 XR7
Re: dash speakers
I just mounted mine in the factory spot. They are rockford fosgate also from best buy.
Re: dash speakers
Quote from: 88turbo
have any of them by chance?  :D
 :giggle: yep infact i do. and not even useing them anymore ;)
i had these in my dash
but you can buy them real cheap from here...
PYLE WAVE PLX32 3-1/2" COAX SPEAKER
these in my dash now
AUDAX AP100ZO 4" SHIELDED AEROGEL MIDBASS
Re: dash speakers
Can somebody tell me how to get the dashboard off? I have a 84 thunderbird, I took out 6 screws from the dash but it still wont budge, do I have to remove the trim peices too? I just got some new 3 1/2 coaxials from kicker and Im tired of onl,y having rear speakers because my subs drown them out too much.
Re: dash speakers
check out the coolcats write up on the heater cores. ALso I htink thtat there is one under the steering colum.(move above it)
Re: dash speakers
That year you just remove the top pad, not the whole dash (I think).
Re: dash speakers
should be:  a screw on each end on the outside of the dash, one or two on the top, and a few under the lip of the pad. then you have to pull it loose from the clips that is probably where you are thinking there are more screws just be gentle and dont try ripping it out or you will have problems,  I remember having the same problem on dads 83 TC.
Re: dash speakers
Quote from: Tapester
It just doesnt sound the same. All you'll hear is BOOMBOOM and very little highs. Trust me i faded mine and didnt realize it. its not the best sound.
