Topic: MK8 and mass air sensor tied to an a9p eec (Read 9481 times) previous topic - next topic
also,
if i change to 30# injectors will the a9l or a9p eec be able to manage them?
i know they are low resistance injectors,,,,
the CFI 3.8L are high resistance but are 34#  (green tops) which i have a couple dozen of).
i also have a dozen CFI 5.0L 54lb which are also high resistance but what i have seen is the sefi 5.0,, all the injectors are low resistance.
Quote from: jcassity;465554
when you say stock electronics,, you mean the eec ,, correct?
No, I mean the from the MAF sensor.
John
Quote from: jcassity;465555
also,
A9* all require High Z and as long as you have a MAF calibrated for 30 or whatever you end up running you should be able to manage.
John
Quote from: Skunk;465557
John
reword pls
you mean -use a stock stang mass air sensor?
Quote from: jcassity;465561
reword pls
I mean the electronics from the stock MAF get installed on the new housing if you go the sample tube MAF housing direction.
Just reading Thunderjets posts....he brings up a good point about needing larger injectors. Yes the 24s will work fine up to around 300 hp. The problems arise at high RPM where there isn't enough time to squirt into the cylinder due to cam events. This is where you need a larger injector to deliver more fuel in less time.
John
C&L MAFs reuse the stock electronics from an 89-93 5.0 Mustang MAF. You put the electronics in the C&L housing. The C&L unit has different size sample tubes that change the amount of air passing over the MAF sensor element, "calibrating" the signal back to the computer to compensate for larger injectors. This process works well for up to 30lb injectors.
I discovered that the 24lb injectors on my car were too small when a friend hooked up his quarter horse to my car. Under high load, high rpm conditions the 24lb injectors were hitting 90% duty cycle. It's better to be in the 80% range. Swapped to 30lb red top injectors (used in 89-92 Thunderbird SCs) and I've yet to see over 75-80% duty cycle under the same conditions. It's a bit overkill but it's very safe.
As far as a stock A9P controlling 30lb injectors with no tune, yes it'll work. Here's my car idling after a cold start. It has 30lb red top injectors, 76mm C&L MAF, stock replacement Motorcraft fuel pressure regulator, and NO computer tuning done. https://youtu.be/Z92w1Y0-E_4
ok,, so i have the ebay maf which skunk said its for the sellers application plus for late 90's / early 2000's trucks.....
and...
i have 3 MKVIII mafs....
so..
dont i have enough mafs lying around that if i buy the C&L,, one of my maf's  should work?,, assuming that i also upgrade to 30lb injectors? and i work in the correct sample tube??
am i tracking this right?
also,,
the larger the sample tube,, the leaner you are able to calibrate,,
the smaller the sample tube,,, the richer you are able to calibrate,,
and,,,,
do you feel like the sample tube could be fabricated "as-bult" in my own shop to achieve a better running feel?
here are the maf's i have
the ebay one -xl3f-12b579-ba
two MKviii-- f3vf-12b579-aa
one u/k  which i think might be a stock stang one,, smaller tube than the mk8' -  f5uf-12b579-ba
which one to use on the C&L?
None of those will work for you. Your unknown is for a 96 truck. For any of them you will still need to define the Transfer function in the ECU.
I took a quick glance  and any of those meters will run you lean below 1.4 volts and pig rich above that voltage. If you run Mark8 computer with Mark8 MAF you can tweak from there with sample tubes.
John
Quote from: Skunk;465573
John
just to confirm,,,
if i find the mustang maf,, and move forward i am going to be able to run fine with the right C&L sample tube,,
correct?
Yes but specifically an 89-93 mustang.
John
Or this and this.
Ultimate control and part compatibility.  I have a similar setup, I can share my tune with you and you should only need to swap the MAF transfer function for your Specific MAF and set the displacement to match your 331. Maybe a couple other small tweaks in the timing tables.
Quote from: TheFoeYouKnow;, I can share my tune with you and you should only need to swap the MAF transfer function for your Specific MAF s.[/QUOTE
thats nice of you,, and thanks a lot!
i am avoiding going down the road of software for my youngest son,, this is going to be his car and although we both have to deal with things geeky all the time,, we'd rather keep this as simple as possible.  this will be his daily driver ...... soon enough hopefully.
I think it would make an invaluable learning opportunity. Digging your hands into a tune is the best way to really understand why an engine computer does what it does, how it makes it decisions, and what information is used and adapted to influence its judgment. You learn how it thinks. What I've learned tuning has made me a more effective technician, especially where an ECM becomes involved.
