Topic: '85 AOD Crossmember Bushings Compatibility & Part Location (Read 2891 times) previous topic - next topic
I have a question concerning a 1985 TBird AOD cross-member bushings compatability. Will the Mustang bushings fit the Thunderbird for the same years? Also, where can these be located to purchase for the 1985 Thunderbird? Thanks. Images below are just examples downloaded from internet for this request.
X
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
They are the same.
You can use the double hump cross member out of a Fox Mustang in one of our cars so that should tell you what you need to know.  Usually have to grind the tack welds on the tubes to the cross piece but that is all it takes.  Energy Suspension makes them as well as the transmission to cross member mount.
http://www.energysuspensionparts.com/4.1102
http://www.energysuspensionparts.com/4.1104_v8
Thanks folks. I ordered the Mustang poly updated ones prior to the question, but strangely auto-parts places never add the Thunderbird to the Mustang parts lineups and I wasn't sure the compatibility between the 2 cars. So, I guess I will just consider that my Thunderbird is just a Mustang wanabee under the body panels.
X
1988 Thunderbird V6
Mustang with slightly longer wheel base basically. When I replaced my ujoints, I had to order then for a 2.3 n/a stang to get the right ones.
Quote from: BradMph;464473
X
Yes, and no. There are differences, but some parts interchange.
Lots of discussions on these subjects around this forum.
