Topic: Iso harness (Read 7122 times) previous topic - next topic
Iso harness
Looking for harness to connect temp sending unit on 87 cougar w/electronic dash (two wires) :bowdown:
Iso harness
not looking for the "pigtail" i need the harness
Iso harness
Yes its a v8 car - conversion from sefi so the harness used has only one wire - when the swap was done i didnt realize the temp sender would not read correctly with the single wire sending unit . so the harness has been lost over time . the lincoln had two wires i belive as did the electronic dash t bird.
Iso harness
Temperature
Iso harness
left front of intake next to therm housing XX
Iso harness
May i suggest that some people that ask questions here are looking for information. if it is too hard to do that then please just refrain , I am a seinor master ford tech trying to find a harness to correctly repair my car , and suggestions are appreacheated but no reason to try to belittle people . if you have a HARNESS i would be interested in purchasing it at the right price .
Iso harness
Master ASE in heavy truck and automotive also - not everyone is a novice - just saying . i thank you for your help .
