Topic: 88 TC aka Bad Decisions (Read 7162 times) previous topic - next topic
Some background, bought car in 2004ish, it's been a Michigan car it's entire life and as such is rusty as heck.
What's been done:
-Driver floor pan replaced from kick panel to rear well
-Gas tank mounts rebuilt
-Front window frame rebuilt and windshield actually attached to body
-Rebuilt motor and transmission
Went to pull the motor the other night and found the passenger shock tower attached via hopes and dreams. Spoke with scottrodfab and ended up ordering a repair section, mostly because I'm too stupid to declare defeat after dragging this thing around for a bit over a decade. Tomorrow I'm pulling the motor to see what I'm up against.
XX
Wow you got some work to do there! Where in Mi are you?
Brian R.
88 2.3t Ranger
I'm north of Detroit, Great Lakes crossing area.
Got the motor pulled tonight with my 6 year olds help, had the fuel feed line hang up but it came loose with some persuasion.  Separated the trains/bell and got the old motor supported off to the side.
Got a better gander at the frame rust, and it's a bit bigger than my patch piece from scottrod. The inner tower pieces will be an invaluable time saver though on the fabrication side. Current plan is to cut somewhere halfway up the kickup and rebuild the rail until the rear stabilizer bar bracket
X
X
How in the hell did the car not fall apart?
Like he said.......hopes and dreams. Hey, if Jerry can do it, you can too. :D
It's really a feature, think about how much work it is to drop the cradle.  This body has optimized its geometry to the point where the cradle can be removed from either side of the frame rail.
I bought a TC parts car years ago that was rusted so bad in that spot the hood was only thing holding the car up! I popped the hood and the strut pushed the hood up and broke the safety catch on the hood and the whole car dropped 4"! And I drove it 5miles to my house. lol
Brian R.
88 2.3t Ranger
That whole area is kind of a piss poor design. All the gaps let water in and it just sits there. When the area is repaired it makes sense to just weld all the seams solid, so it's harder for water to intrude.
Found a bit of rust on the driver side rail as well, but it's small time compared to the passenger side. I do think I'm going to just seam weld it all together.
Went through the s bin at work and pulled a workable pile of 12/16ga sheet steel, should be enough to make a solid first pass. Little bummed I moved the car into the middle bay in my garage, I can't reach the car with my tig welding leads so may need to borrow a small mig for the bulk of this.
Dug this out of my pile of books, too bad PB sucks. Would love to share this in full resolution.
X
I've been using Flikr with good results so far. If you have and old Yahoo account, just use that to sign in. Just have to be slightly crafty with the codes.
I actually sped a TC with rust half as bad as yours in the same area. You're a bad bitch to even attempt trying to get that back together.
Made some decent progress today, all the brake/fuel line clips came loose.
-Pulled wheel well liners
-Got the calipers pulled and hung
-Dropped swaybar off the frame hangers
-Broke the rear K member bolts loose
-Broke the strut bolts loose
Tried to drop the driver side front Kmember bolts, promptly broke the tabs off the nut plates. Got them turning with a breaker bar, but decided to let them soak in oil for a while and try it later. Or borrow a nut splitter.
Passenger side I'm just going to cut through them via my engine bay access hole.
The work isn't particularly difficult, once the engine is out. If you have a welder and the skills it's something that can be tackled at home. Now paying someone to do it is where it gets $$$, due to the labor costs.
Do the mustang floor pans fit these or do I need to just get metal and patch them in?
Zach you will need to patch them, the mustang floors are different. With that said, it's not a particularly difficult pan to create from sheetmetal if your existing floor is there to take good measurements from.
Quote from: thunderjet302;462740
Isn't that always the case ;)
