Topic: 88 TC aka Bad Decisions (Read 7171 times) previous topic - next topic
Managed to get the driver side Kmember bolts out, it was a battle. Pretty happy i can just cut the passenger side, cause that was zero fun.
X
On the bright side the bolts are still pretty much the same diameter as when new. I've seen some very rusty K-member bolts that were only half or less of their original thickness.
I'm blown away by what LMR and 50resto charge for these crossmember bolts and j nuts, I understand they're special, but 200$ for four bolts and nuts?
Looks like I'm getting some used ones haha.
Quote from: Sancho;462773
Jebus. Yeah just eBay it. I've seen all 6 K-member bolts from a Fox Mustang listed for $50-100.
A grade 8 or better hardware store bolt wouldn't cost more then $15... you car cutting and replacing the entire area. I wouldn't be worried with originality...
One word; "Fastenal".
Check these videos out, this guy kinda shows what to do on frame rails and shock towers. Not a write up or how to, just showing you what you are getting into.
https://youtu.be/CykDm_pen 15syI
Been there bud. I sandwiched a 2x3 .083 piece of box tubing in what was left of my frame rail and built off of it. Its all a challenge but I think I rebuilt my frame rails and strut towers for under $50 hardware included
Did some work today, removed the spot welds and pulled the sway bar bracket. Going to bend up a U channel sometime this weekend and see how it fits in there.
