Topic: Replace instrument cluster (Read 7677 times) previous topic - next topic
I'm planning on replacing the instrument cluster on my TurboCoupe. I'm going to make one and use Auto Meter gauges. Has anyone tried this? Advice on the wiring and building one would be appreciated. I do have a full set of the Ford schematics.
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Jeremy and Eric- Thank You. Exactly what I was looking for.
Eric- Those are the same gauges I will be installing. I think I downloaded a template you made a decade or so ago. I'm going to make the face out of Lexan and then cover it with a 3M dark grey wrap. The idea of using the existing back looks real good. I'll post pictures of the process as I go. The car was butchered electrically when I bought it, which I did not know. This site saved me with all of the great information. Every time I took something apart I found another problem. I am an electrician, build high rises, hospitals but that car kicked my butt.
That sounds like a cool plan. Please post photos when you do this, so we'll have some examples here in future searches. Also, if you run into any snags, let me know or post here where we'll see it. I found the custom panel to be frustrating but also rewarding...had to create a custom wiring harness to do this, which necessitated cutting some wires. Hated doing that.
I just found a 87 TC gauge cluster on ebay for $50, free shipping. Should have it by Friday. Wanted one I could cut on and not cry. I'm going to try and re-use the printed circuit film and plug. If it doesn't work, you never know, I'll build a terminal block similar to yours. Thanks again for the help.
Instrument cluster
Check out this detailed install into a T/C:
http://jrthecar.com/JRsPlace/articles/cluster/
Rick
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
Quote from: gtbird;459417
Rick
Didn't realize he'd changed domains. I had to wayback my favorite (in post #2) to get it. Nice to see it still exists live!
It'd be nice to replace the stock backing assembly with an additive manuf'd piece to get that little bit of space on the bottom so the gauges fit in better. Lot of work for minimal functional gain though.
~$650 for electric gauges. If you're nuts and go with full-sweep gauges, you're over $1k! Woof
Rick
Thanks for the link. What JR did to that cluster is pretty good. I think the black face gauges would work in my TC.
I'm replacing the gauges because of accuracy issues, (learned from drag racing), and the present location of my mechanical gauges. Right now my mechanical gauges are located where the warning panel is on the console. Too hard to keep looking at them and I don''t want gauges scattered over the dash or on a pillar. If there is a problem I'd like to know about it now.
I will be eventually replacing the 302 in my TC with a Ford Racing crate motor and spending $650 and a little labor on gauges is cheap insurance.
On a side note- I learned the questionable "value?" of relying on factory gauges in my 05 F350. Almost destroyed a $10,000 6.0 diesel motor. Had a bad EGR and engine oil cooler and didn't know it. Factory oil temp gauge showed just past middle, engine coolant temp gauge showed the same while towing my trailer from San Diego. I was blowing coolant out of the degas bottle. Lost 2 gal. before I noticed it. Actual temps were probably over 240+ degrees. It has a $550 Banks engine monitor on it now. Cheap insurance?
I'm an "old guy", not rich, and can't afford to replace motors because I didn't have good gauges. Just personal preference.
Quote from: tommym;459431
It's nice to be able to monitor engine parameters with OBD-II. You no longer really need a bunch of physical gauges. You've got Scangauge, Ultragauge, and various mobile apps that work with OBD dongles. Ford engines have some of the widest range of PIDs available to view.
This is an update on my cluster project-
Below is what I'm using for the cluster face. It will be covered with either 3M matt black film, 3M matt charcoal film, or 3M carbon fiber film. I haven't decided which one yet. .11 thick.
[IMG]http://www.foxtbirdcougarforums.com/image/jpeg;base64,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 fwKgAwABAAAAABJ8gQOgAwABAAAAgA2Dgw6iBQABAAAAvhgAAA iBQABAAAAxhgAABCiAwABAAAAAgCDgxeiAwABAAAAAgCCgQCjBwABAAAAA4KBgQGkAwABAAAAAACAgQKkAwABAAAAAAB9fwOkAwABAAAAAAB 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 FwAAOAAHAAgAAADGFwAAmgAEAAUAAADOFwAA0AAEAAEAAAAAAAAAAAAAAGQAAgAAAAMABQAAAAAABAD//wEAAAAAAAAAAAAAAAAADwADAAEABkAAAP9///9AnIgT6ANrAMsA//8IIAAAAAABAAAA//8AAAASABIAAAAA//8AAP9//38AAAAA// gAP////8AAAAAAAAAAEQAJwDAAEQAawC1AAAAAAAAAAAAAAAAAAAAFAAAAAAAAAAAAAEAVQAAAG0AtwAAAAAADgD6AAAAAAAAAAAAAAAAAAoASU1HOlBvd2VyU2hvdCBFTFBIIDEzNSBKUEVHAEZpcm13YXJlIFZlcnNpb24gMS4wMAASAAAAcQIAAPsBAAAAAAAAAAAAAAAAAABIAQAAJwIAAHYAAAAAAAAAAAAAAAAAAAAAAAAASAEAADcCAADB////AAAAAAAAAAD2////NQAAAAAAAAAfAAAAKwAAAAAAAAAAAAAAFAAAAAYAAADOAAAAmQAAAMkAAABIAQAAHQIAALH///8AAAAAAAAAAJkAAADJAAAAAAAAAAEAAAACAAAAAAAAAAoAAAAvAAAAfwEAALL //9DAAAAAAAAAOP///8AAAAA f///wAAAAB AAAADwAAAFIBAAAaAwAADQAAAOcDAAAABAAAAAQAAA8AAABSAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGgMAAAAAAAAPAAAAUgEAABj // 5AQAAdQAAAF8AAAAAAAAAAAAAAAAEAAD AwAAAgQAAAIFAAAMAAAAsv///4cBAABGAAAAxwMAAHIGAAADBgAAxwMAAGQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAABIAQAAFgIAAM4AAAAbAwAAqv////7/// 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 g8AAAEAAAABAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPT//4UAAADCAQAAwgEAAAAAAADMAAAAAAAAAAAAAADAAAAABgEAAAABAAAGAQAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADHsa5YzrGuWAAAAAAAAAAAAAEAAAB v0RZ1zYAABy/RAAAAAAAHL9EAGIAAAAcv0QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFj2RFS8BQAAHL9EAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABy/RADkQAMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFQAAAA4AAAA0z bgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAABAAAAAgACAAIAAgAAAAAAAAAAAAAAAAAAAAAAAACKAAEAAAAEAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgAQIAAQAQAAgAGAAQAIAC4AHA/i7/QAHSAAIACACAAQAAAAAAAAAACwwMDQ0MDAAAAAAAAAAAAAAAAAAAAAsMDQ4PDw8PDg0MAAAAAAAAAAAAAAAKCw0PEBITExMTEhAPDQAAAAAAAAAAAAoLDQ8RExYYGhoYFhMRDw0AAAAAAAAAAAsMDxEUGBwgIiIgHBgUEQ8AAAAAAAAACgsOEBMYHiQnKSknJB4YExAOAAAAAAAACgwOERUbIygsLS0sKCMbFREOAAAAAAAACgwPEhYeJSouLy8uKiUeFhIPAAAAAAAACgwPEhYeJSouLy8uKiUeFhIAAAAAAAAACgwOERUbIygsLS0sKCMbFREOAAAAAAAACgsOEBMYHiQnKSknJB4YExAOAAAAAAAACQsMDxEUGBwgIiIgHBgUEQ8AAAAAAAAAAAoLDQ8RExYYGhoYFhMRDw0AAAAAAAAAAAkKCw0PEBITExMTEhAPDQAAAAAAAAAAAAAJCgsMDQ4PDw8PDg0AAAAAAAAAAAAAAAAAAAAACwwMDQ0MAAAAAAAAAAAAAAgAAAAAAAAAYgACAAkAAQAAEoANABKADaUCIE4TANABfgDQATwAEwAQN7ABkIWQ0dw2YOp0egAAdDYAe H KADQ0QAAEwCA0SBOAQBSAFYAHwAAAFQMVAwAAJRRpDqA0QEAAAAAAAAAKAAKAAEA//8AABAAKgABAAAAAAD//wAAAAABAP///////wAA///////////kpetzbfv3c3uWsJkIb2/TJgD/f/9//////wAAAAD/fyD /////////////////3//f/9///8iAAEA////////////////////////////////////////DAABAAAAAAAAAAAA5rNPEDBK93N7lrCZCG9v0xAAAAAg/v///n8AAAAAAAAIAAAAAAAAAAgAAADexwMAAgAAAAASAACADQAAAAAAAAAAAABJSSoA/AIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQRgDyAAAAALw0ALYAAAAAEgAAABIAAAEAAAABAAQAAAACAwAAAAAAAP/bAEMAAgICAgIBAgICAgMCAgMDBgQDAwMDBwUFBAYIBwkICAcICAkKDQsJCgwKCAgLDwsMDQ4ODw4JCxAREA4RDQ4ODv/bAEMBAgMDAwMDBwQEBw4JCAkODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODg4ODv/AABEIAwAEAAMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5 jp6vHy8/T19vf4 fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEspoogeNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4 Tl5ufo6ery8/T19vf4 fr/2gAMAwEAAhEDEQA/AOqVGBLBe Se9Spklz98t6DimjBZQXHPALGp13ArtYZHYDivmEShyquzDDLHkgc1IFwCGHHrimbSC5bv0qchy/XIAHGOtbJlD1ALtnjHtSrndu3Fj0/pQvEpU/MnrTgoBLDoRxzSsh9B5VcgHJx dWBuZzg5UDB75pi469yM4PWpFO5eMBu2O9TawhURgD0BPGe5qVAyjjBGelNUAlVY4qfC8sAcd8VTV0A5ZAVIIG3 lTrlkK9SRnOKAvBKk gBpVXaQDjP06GpURkoX5h3Ge4qTGVwc 4/xoXBXCjJByKkVWEg6nJ7cU7IhjVwQVxgY4460qkKpOfm9qlIA4I3HPXPWkC/OMd6roNaiLn5Sq57VYXJXikQYflsYPSnhiHIPA9TxWdrMm2pIitt3McN6 1POFfryeDk5qMElF3cH61IcfKehxyK0RQ9RgBVI919KcgyRuI4qLLI2MbVA9aergnB 9jtT0GSZJJb04Ap6ZKjJJXpj0ppUgd8/rQABj0PtRZASgggFSQckU/J56YPfFRj7gyePftUyEPEQcgHrTAlTaYyd3zZ5z3pQMocrtzTOQPRQPWnKed3Y tICyF2jGflp FKsMcnrz0qNWIUvnIIxSqWZhk8dB70tx6olXG0enQ5pwwGHHHU8VFjgAA/n0qUKN2TkYPFLSxd7gANhUcdsipFPUgYx2PSmgckAcZpV 8Dnj9KVrMCTPK4PUVJgBSQTn dREj7w71IoJf7xXv607Bcco44OBjr3py5JJPJB601WYIOzA/jT8lue3WqE2OH3Sc59RTgDuwB2pox0Bx3OaFOD/nNPlZIrHLHHA9qa2AAc5HQ4oAOcqcilxl8A59h2rSyRLGKMZOSD/OnAkYH6UEADnoOh70i8SNnGfWmhXJlIwcH8O9AOGJx3yajTAUYHGe9TKBnPANMLjwoI g7U7IPP3ee1NAIUgYA7YNOwdvbA6CnuUZ9/l9HuwAdphYYH0NZXhAGX4Y6AxALGwi46/wAArfnjD2EylcqUOcjtisvwagh F2hbwGkFmgwPpS5feOlfwH6nQpCFjV3 X0460j5 4AFB7AdqkLMyZbnjgYpCAuD/AB9Kq1jlbsZt1axXWnSQXEfmRSIVdSOox0rnNMyksmh6iBcSW4327yDPmxg8H6jgGuzKfLzjGKwdb0 S4t4rmzYf2jbHfC3ZvVD7HpU2OmlNfC9mc3rIQeOdCBkNuWSVVdexwuBW0EaW4 y3Euy8j aGUfxj/PUVhT6hZ6l4i8PSEmNJ0njdGGCG2jKn3GK2biWKFPs19ceVInME5/Tn19fWpa1OyUZWjF7jHhu4Lt5EQx7vvGPkH3xR9rEfztLE7d0cbT tQw6tf3LPFZWou0xjzh8qZ p6/hV0aFNfSCTVLlplJz5MfyoP6mr5ZdCW1H JZfmVdCmS58aa7cR/KhSFefUBs/0rt0wDgckfnVO3s7e1txHBCsKDoFGM1cTC5LHOKLWOCrNTldbE42gEjDMPelG1ckjp3HY1GmCDkYz1p7YIyTt5xSsjFu5KP9Zu7dwanXb5eCPwx0qrgc5B lShd2eoYdc1nygiUE42kcYqB OQeO9SljgqAMelQSktH8pB lFmap2Pj34j7ZP2oYY5DuUywKAfQkf419eocRjnHbk9K R/jTatYfGKx1MKRvgRw2O6n/8AVX1Tp11Ff6HZXkWDHPEsikHPUA1w0Y2qSR93m6cssws47WsSavKYfCmpTc5itJH/Acumo/D8Yi8DaLGeiWEIP/fAqp4qlMPwz8QuOf8AiXzbR/2zNatqpi0q3QHDJEqgY9B0rrcdT47/AJdW8yccr8pBGeMcVzGqgn4h HOP4ZwPb5RVTw3BrsGq3T6mWMJTHzsCGfceV9Bir rN/wAXB8MnOMmfP/fAqdX0NFDkqcqd9DoCchQv3vrVWbk4POB3q0xyMYwM9CKxdXvY9O0C/wBQuW2xW8Lyu3sq5/pVyaUdTKim6sUu58i/DEeX 1ZeRxBfL825XI9ATj VfTev5PjjwihH/L5ISO/ER/xr5r BlpLf/GHUdWdQRHbszN6M7f8A66 ktYdf Fn E42G75pmz/wACuLDxtTv5n3eftLMIx6qC/I7nqqrjI9q4nx d3wp1kcfPEEx65YD tdqTk5HTOcZriPHYD/D ZSMCS5t1x9ZkFdTV0fDUNa0fU c/wBoW5ZvFWgWZYsqwMxJ6ZLV9K F7RLH4d6HaKuxIrGJWXrj5Rn9c18zftCRtF4v0K52ZDWpUHHcNX0z4aukufAmjXUYwkllEwA/3BXDCNq7Pu8zbWSYbl2bf3m8yfMdnr1rOvrS2u7SWC7gWaFl2ujjINaRbjcePX0r59 LHxWTQLebQ9CmEusSLtkmTnyB/jXTVqRpx1PmstweJxuKVKgte/bzPHfH09p4K ItxB4N1Jo5JoWS6ijOVj3dvf8ApVv4b BGvbM K9UCTx2zl/ssrYLBRkk mK6H4V/C2XUrtPE3iiJnR2MkEEo5lPXcwPbNe1 J/CcGo/ZYoLn zIrq4WK9WM489Ou36nH5V50KLl77R nY3OKGDh9RpT5p2tKf6HTeGdVj8QeDbfVILd7e3lz5SuuCVHGcelbU0YMTK2ChBBBHBqW2hgtbCG1t4xBDGoVEAwAAMCoLyVINPnnlb5I0ZmPoAK9LltHU/KHJSxN4Ld6Hxt8Kd1n 1JeW6EmFvPjGPQH/AOtX1FqxNt480TUZM/ZgsluXxwhbBGfrjFfL/wAEIm1P9oK/1Uj5VglkbPYswx/WvsO6toL7TZYLpPNjcYIOa5pen 154M v4jmoY Ce/Kr/cc9NaXumaveajp0X2qC6cPNAD827AGR68Cq8XihbrUzAiLZshwRctsY/QVn6NqGtW9reGaE6jZQXksKlBmVVRiBkd B2roEvtD1Zdk6wyOOTFOgDD8DyK1Wu2h8pJWfvq/midJNRmjLLJbIvqCWJrOW7u3kDm8P2dW2mZYvk9OtTv4c0/ymNlPPYk8DyZjj8jVBvC pRaKbG01wi1MQjCSxAnbjHX6VTjKw4extuvmv HNh7W6h1WG eVrxEUqqKgBXPf8ApRDb6h/al1eo8dus 3ETgkgAdTjuaiC JYTtVbSdMcAMVJrLlfxUviCK7Ngr2qIVMEc45PrXPquhpCMpaXibch1GPAnvYEduwUjP0qnf/wBpjRZWk8m6iVd2xM5YjmvI/ET I9R8R3NzLpcirHIRiSMssSjG1QR3PzEke1V7a 8ctOLSzS7u0AJG3GI1zwMsBzWTnJO1j2oZdJwUlOP9eZ7Lp1xqQ0i3KaekaFNwTzMEZ5/Oku7zTdR04QXyyQrncyMCpFeYI3xHJIFnc4/hyycfWrkMPj X76MhOT8zJR772RhLAJO7nFekj01tZ0tbZ2N1GqqMnJAxU9tdwXtolxBIskTfdI/KvMpNK8a3MJErxvHjBVgvP6VHbeF/F8UTRpqItoSc7RIABz2wOKUpVEYvB0VG/tVf1Oj8VNpVloFxqlzMlpcwIzRyJwxbHA98 lecaVdLqPxS0S9htfsySFFuCFwN wk/mePwrpz4LtVmN94g1bzVTklm6evLdPwFb i6dBeaza3NnafY9GsizQFlw1zIRguc8kY6E9c1KjJ p1qpRoYdxi3J99kd3t4AAA hxiuK021tk M uz28So32SFZNo6kknn9K7cJjPQjHNcj4cZZvGHiy5UFl 2rED/uxj/GtJX0seBCTUJW7HYZAOM5PYGuA1WSVvjPYLbsivBpzud/T5mA4/Ku/OFVhz6D2rzp18/4vavIbUXQgtIowMjgnLHrTmtLhhd2/I6b7XfpGXaCOTb1KzAHAH0qh4TD3un3euTIBJqExkjB7RD5U/Mc/jWPrxjfSo7C2tLi0vL VbeN/MIC5OWPB7KGNd7Z20NlpsFtAgjihjVEVRgKFGAP0rLRvQur7lLTqTgENg9emBSg/MMYNSANkHGOeSaQgbDuHHpWljzdyLDByQPbrVdgcnPPrxzVs8xnI75zUTJJ5mR0zxz0qXdAyFiQSV69RzStIkkfz/I/Zs9aceCec4qrKw2ucDAz1rfornicatesUVc4PxNa6hqXifTNIsggjh/0u4MgOx8HCKcdeefwrSsTrv8AaEaX0dsIcffic5z24NZmg32oTG/1drU3lveTlrdfN 7EOFwD6j5vxrpmu90DyC0nGB0CZ/lWV1ex6NRySVOy0JmGOOq455qBgTKUVckngD0rKn8RaRbLtu7kWjkfdmyjfQA8ms TxhpESM5eZY1UkzG1kVD OOKd1eyM40Kv8rMDxTANQ1Y2tszwyWls013NG2DswcR/iR ldH4fjSLwHpaKBhbRFQD02jisKxjlm GurapMu261KGW4bn7qMp2j6bcfma6fRgV8I6YCPm yx85z/CKmW9zevP8AdKHZl/YQmNoztwfaoDwSccg9asF/mwcNk8e9RMAVdcZI54FXqebfUrkp95hnJzjPQVCxbaccZ6sBVx0VZQ5 bJwp9s1mzyxW9rPNMwjjiRmdj0VQMk/pQUtdDndVA1DWrDSw2VVvtFypPO1T8oP1b VWNWDHT1hHIklRTz1wc/0qtokZmgn1e4Uie/YSBWH3Y/4F/Lk 5q7eDzPENpEeFQM5BHWk9zd/HyroZF0iXHjfT7UbsQRPKwA4GcKP61H4iZm8NfZuM3NwkQHoGbn9Aalsgbjxzq9zFlViVIUBGDkDcf5inaiDP4k0m23pen 15slbHTgYH86WzNErTS7Gf1IYgAHtT23 YGOASetpen 15sjD5BXOAKcfnBx0PSvoLHz7Y5csyhgVI6gHmrSxnfgj5ehNQqjbz/Dz0zU5QFcqQSMjPrTYkwwPKIUc1MgBjCsdyCmxphycYwO9TAYY5x78U9yxCpUb8ZIGCSc1IF ZFxkHvjNGR5TADORxjrUwAMZz2445qUiLsQDJOQdv61ZU5IwuT1P0puPkGFz FSqMADgKR34poLskGD8qjjPSndyDpuppiesWkiOEHU89cVYRd/3m2qR2p7BcEyD8pwB0xxT1Dc9SOg9aUKAxAOB7UoUKnTk9yeKSWpOrFYcHuc59qlRRsyCN3PI70zBPA79/epApMYxschlongV0OGFOHyB3p/Rt3Vew9KaMYBHpxmlZhuPGMDOM/rQ4rcrzFJyjEgkHrg9aC2Og6HOaiaRAnvj8awtc1 00XSJry9lWKKNcncRUuUUrtnRTpzqzUIK7ZqX p22n2TzXUqxQqMsTxtHeoNF13Ste037VpN5HdwiQqzRnJBHY18b MPHmreNdb/s7TkdNNEm1ETrJ2Ga98 FHgu88L6NNc3kpjlukG6A9F75PvWFGcqktNj6/E5JHA4D22Inab2ie2R7n/iHPXilwd4Hp2qONsRhepI60/cSQQRkV2NWZ8WSr9xcHgc5J71Ko7Yx6YNRgj6HHA9acp2sGxg/WkwIri6S3tpXlcLGBliTgAe9QafqdnfBza3Mc4U4YI cVyPxDEsnwl8QrE5VvsbkMvpivnX4BXsqfEu6ti7NHNatlSc8jBrmdSXtVA mwmVPFZfornicatesKlbk6H2epymBjPQ5P6VMhUpnGCTVRHw8f8AET6mrCnJBIyeuewroPndicY3A46daf1bnkVGCTg9BUigMmFOD3GcUaMiw7GRksPwpRgLxyKZtJQAjH1NSqcMB2ApFJjlOCO2PenjuO2OaaACScH6U452cc461dgY9Qcgjj8KVeSec8YximqxDAnkU7eQp6Yxke1VYmw5crHnkNnilB UEngml3EKDnIxyRSeuOvQe1VqTcUABw/JBppI4JHX2pdygcZPoKTPBIxnPBx1qidxpwD39hmkBHmcg4HTinHDKQeSe9NUDPIJPoapRux6D9xDFgOKm/QHn6VEARj IVaVPlXHTrjFU0RfUVUXOeg9T3qZI2bHGF mBShUWQE4JI9KkYjAGcjvxSQ7jZXjS2dY0BP941yfg5nk GGihuGFsBz3rp5cm2YcE7SOuK5jwSpHww0cOSMQEHj0YintI6U/3L9Tr0GMgcn19aULuLfKCR70ihN2Tzz1qRVwSScHHSnY53qMC/u89Oxpuzc20DODjNWCB5YKqc tJtZmXJ46cHrV8pKPPtU8LXMvjKDUbCRI4mDmaOTOAxAG4e/ArUg8PQF0kvZHvZEIIEn3R9BXXlOPu8n27U3yvmHy/LjnPehRO6WKqygo32KUcITaEUbMcCpViIGcbQRz7VZVdq4A6dc09kO7AAJ7 1VZnHzNsgEZGDxn0p20kHmpGUHkcY6UmMuuOVB5OazaJYiH5hwcHjI70Hkg478ZpeRuwvHvSYJAJ4PfmjkAkRsFdx47 9SFtsY69efaoAAVBHBzT35iPJ49T1rNoaHhxu 706 hqI8KW/HbShhuIGSAeKYykuTyQfxqbWNDxD42aC qfD5NTt03T2L5cj 4eD VN DPiiPUvAK6NLJi9sflCk9UJ4r2K8tYbrT57e4i82GRSjoehB4Ir4413TdX FvxYXUbAM1gz5hP8LqTyh9 1efWvSmqi26n6FlcoZnl0svk7TWsf8j6u8XFpfhpqkUSM8rw7MLknBIH41XufFCw2XnjTro2qEeZK0W0KCeTzzxVbwr4w0vxVoMd1azDzMfvYWPzIe9dBe28N7ol1Zy4Mc0TRtx6jH9a6lJTjzRZ8nOEqE/Y1oapkep6xDp01nCsElzNPnbHEuWUAcn6Vzz6pBqPxC8PLCJFkiE3mI6EbcqB396peD7m41a/a/ux89lbLZZP/PVT 8/UCu9GwuH2qHHIbbTWqHKNKhLla19SWQjHzfl614J8c/FyaZ4CGgwS5vdR VlB5WMdfz6V6D4x8b6T4T0Ka4vZle5ZT5NurDfI309K XvDei6x8Vvi  qaruXT433TSDoq9kWuCvUUn7OO7PpMjy9KX17E6Uoa r6I9n B/ht9H Fp1KeMpc6i3mKCOiDp fJr0LUAW MPhpTxi2uGxj/dFdRbW8NvZw28EQSGNAiIBwoHAArnLkD/AIXdo425C6bMxx2yyiu2MeWCR4mKxcsbjaleXW51 D5R3Dv0rifHPzeF7CPvLq1qg5/6bKT/ACruWBCtkBv0zXDeMQ32XQYk YtrMHH0JJ/lV9Dy6D/eo8s PmitqHw3ttTiTMlhL82P7rcH laHwV8RJqnwjtrJ3DXWnsYmHfb1U16rrOl2 reHbzTbpMwXERVwfcda Fpb3xD8LfHmrWVsfJmdDGrMPlYdnFedW/c1PaW0P0bK6cc4yx4C9pxd43/E gvit8V4/DlpNomjyJJrbr8zDkQj1 vtXAfC74YT65qS K/FCu9u7 ZDDLyZmPO4 1YXw5 G0/i95PEms3J8l5cxGT5jKwPJOfevqKLSNYhRIYNaQIowqmEYAHAxzWFOLqy9pNeh2YuvhsmwrwWDkvaP45fojrFREgVEACqMBQOgrwn40 IrzRtU8Hw2avtW9FxJtB baQAPfOT deorZ IgTjVrdgPWDr tYmqPdw30ceq6VDrV2AG0 RIsgSehJ 7jrmuub5lbY IwPJTxHtJWna l/wDM9ERt1shb5XYDOe3FeVfGHxQnh/4O38Svsvb5TbQAHnDcMfyz dbmpalrWkaRNqF/NYxWsKbnZmYAYr5N1HUdc MXxjtLKMFbWNgkaICUhjz8zmuetV5Y8nVnuZNlft8S8TVaVKnq/wDI9f8A2fNAey8Gahr9whDXsgjhJ/uL1/Wvo0DnIOOPWqOj6Ra6P4ZstKso9lrbRCNFHoO5 tae0j5VxwOK7qdNQgkfPZpjXj8fOt0b09OhyXhshag62p4A1WX1x2PT8a17vSLDUBi6tY7hsYBK8j8etZnh3I1HxGhAyNUbj6ohrqSNrYIwe TVJHkzlKFS8XY5Y GkUk2eoXdn2UebvA/A1H/Z3iGDAh1OG4Uf89IiCfyNdiArqDgDHpSBcOT/So5I3NVXqLfX5HJGbxTECzWdtcDoCkpBP5imrquvKg36G5OcEpKpFdjtyF5GOmTxmkYcZzgdqydPU19vC2sF P ZxT6vqKu2/QLrAP8JU/wBajOt3nIOhXgx0IjHP612zDIP8II6etMZQCPQ9RUOm31D21O3w/izjv7cvQMjQb0e5Qf4006vq fk8P3JOcZZ0H9a7L5QnK8Hp3pCvy7xwM9aFFrqWq1NfY/FnF/a/E03EekwwZ5zLOP6Ch9P8TXBUTalb2anqIYtzAfU12QGckjLZ70whjkHnHNJxi0P6xb4Ypf15nmN54dtv E40C3mkl1CTe88rXD7lIVcD5enVvTtXpKqF424HpXN26m5 LF9Mp3CzskiwOzOdx/QV1P3R8w7VnbsFatOVlJ9CJsCNucD1rkPBgZtK1a5YDE2rXDAjuA 0fyrspSPJLHAQDPHpiuQ8DAf8KysLlus  Zj6l3Lf1qmtNSI/wZfI64ngjGMdOcVwGkWgvfGvii4LyxsLtYlZGI 6g/qa7wglOTwvBrgPDFxctaavdR2pljn1SchlYZOG29/92s5K6NaHN7OVi3a2hn J7B53uItOthsLHOJH/wDrD9a7dVH3SOvQVyXhVnnj1jUJI9klxfyAZ/uphB/6Ca64ABuOc 1KK0sY123Kz6DwRtHJyO elMfAX 8PU1IFGwcdDgikKhge49at2OUYcBSpx9DUeD5J5xnqafx8pQhjTSBk7u/Ss7IrQhdQVOG2gelcf4vuWj8NLZwhxcX0i2yFPvBW 8R77QcV17D5OQQDXEeLoJTeaLcbZvs9vcM8phQsy/KQD0P TWLVzqw8U6qTIhb2kFokS293ZqqhVCFiBgccDNYxvb 81E2vh28mkljbE08yfu4T6dBlvarsNhrGr3DGa4uNO0kjBjcYmm/ JB/Ouvt7W2srCO2tIlhgVcKiDArFxdjulKNLXRszbDRNPtrkz3a/a9TI e8mGXJ749B9KzfGEBHgm5t0Y/6S6Wwde3mOEJ/Imt /uYLKwmuruQRwRrmR244rzzULzVNTvdGlmWTT9KbUU8uB1/eS4UnLDsOOn51XK7aEU/a1Zc7eiOo1CBF8H3kIwifZXVR6DYabomX8I6YDwWtozkdvlFbDxCSApKg8twVOR1B7UyOKOJEhRdqKoVEA4A6Dipscc53jy9SEgibbtGeoxzzQykuSpDZ/u8VKync2Pmbt VRsCRk/L/eHr71XqcyRWJO7a2Sp7Vyut7tS1WHRIizxH97e7emwHhT9T ldFfXSWel3F3If3cUZdsegGawdDtpUtJdQuo9t/eN5koP8A/hX8BgfXNJu2p0wtFczNkDYvALArge1ZMeH8T3b4IESqmT69T/StkFlgLFuCM8cYNcjc3v2bwdrWoovmSsJZF9yPlX88Cou7hBXdxPDbJJo9xesD/pVzJJx3G7C/oBU0UXneOryVsNHBbKik44JO41f0y3TT/DFjaqAfKhVS3QsQKzdCJmW/uQci4u2Iz3Cnb/Si99TR/akVASRtI5zwM08AABdu3j5sioxgSHdgr2ap49ucgZUjg pr6NHgCoCckFsZ9eKlC87iQ3t1FJtUgHaQx6cdamBGANnGOp61TRSETlMspPue9SsysgCjLDHAPUUqg5LD6j2pyfK4ZQNpPXFSMUgeaAp6/w57VYjH7wlckn VNPyv7sOO34VOisCUBA49P0oJYuHyNoJyfwqRAdxwBngmhEZQGJCkHtTxhmXacc9fWkJDgCZ25OR2FSBlMfIJHt3oK5Ys4BP061LtPmFQMn37U2gFUBJiSuQemalQZbknj1pqrg8nGBnk9KftKyYHH0oECsfrzzUwUBgQNwJ6 tR7WA29 3FTn7xwMkdRQgSG7flIYY44qDJ2HucfLU28PJjOcDpmmSY34UjP86DVI4zxX4r0/w1oEt5fyiIqMKvdifT1r5G1rxDrvxC8XCCLzRamT93bp2 teyfGzwrretWun3emQPdQQhhPGg3MPRsV4Jo1r4v8PXk02nW1xDcMMEmAk/qK8arGcqvvK8T9i4cwWDhg3iYyi6vS72Pp3wH8PbHw5Yx3t0I5tRPOSM7P/r161EwBBDZHpmvi0 L/iYkYCGcHHJ8jn VWY/HvxJT55GfcOu6cumNdxVlB2OLG5BmOOqurUrQb9T7YVsgEY4PNWVIOeSpxivh6H4u O9P1WJbx4nVSNyPDjIr7C8NazHrng3TtWjGPPh3Mh52noa66dVVT47MskxmWQU6tmn1TudGWBjBYAYFKzKFGOPXFQlsR5IB4xXgnxX8fa14T17TrfSxGBKhZmkXOeelVOoqcbs8vBYOtjaypUt2eseL18/4da3CDy9nIoz2O018mfBO6KfGe3QcB42HXrxX0vomsSeJvhDHqNwqpPcW7CRV6A8ivlb4TuIPjrpy46yMrduxHSuWdvbRZ iZNSlSwGLoT3SPvSME5DZYY4OavgjnBCjNZcDbSVB4wO9XVY7sHpXe0fmL3LBby3Bxn0qQMN/cHHPtXI LNZl0LwDqmrKgke2gZ1B4BwK80 FvxPvfGes3un6haRwSJF5iNGck881k5pTUOrPRo5fia GniIK8Y7nve4 ZnJ6Uqt8xyCCe4qsj5bBHzelYfiPVzonhDUdVVDJ9mgaXA74Gap 6rs4KcJVJqEd2dSGw2B1B9Kfu RSWx3FeFfDL4qy M/EFzptzYrazJGZEZXznn3 te378O3PzHt6UQqKcbrY68Vg8Rg6vs60bMsF cd lSKTu b5sH1rxr4ifEz/hB9WsrYWZvGuULY3YwO9eh FvEMPiXwRYazDGYkuY8mNuSpBwaqNSM5OKeqCrgcVTwyxEo 49mdMOCOwPSggqPWowf3ZHB9qeOW4 92rpSPKYEjaCcjmk424B447dadtw D09KVh8pBxuFUokEYJ3Y 7zjrSgNyDxxnNKPugAZB7U4cPwCR2FaJWVwJVxyf4gfxqTccBVOCRmokUb2H8Pv2qVAQRxjHSq0C5KoyTzmn4yOOf5UcDBViT3GeTSqv4jH50rIBkihYnyBgDjBrmfBIZfhrp2cY/ef jGrqnUsGJ5 WuC0X 3NI0RdOfSGnELuVkWVcMC5IP5Go21O2nHnptJq56EACnL8mpdm7BOd2OgFctHqmrFdx0SUH13qatDV9UyM6HcE46h1/xrVWI9jPy 9HRqcMoA69hT/LyCM7Rjg1z6azqO0f8AEkuR6kbf8acNZu94D6PdZPTgdPzp2RHsanY6FY84ByR/CcdKUISCF6fTNYia1cjk6NeDnBxGOKcNbdUUHSr0AnGPKyBWiVifZVLbGuVPGTz06UKDgZHy4PWsj 28qC2mXi88/uDUZ15BGCbG7JH/AE7tQ7MPZVF0NrADYPTFN2ZOAMc1jf8ACQWjRk/ZrlT/ANe7f4VGPEVkrf6qcAjvbtx lZ2H7Kr2NogeaVJGSeOKZn5iAfl7GsNvEmm7QzeYDjOfKb/Coj4n0ryxmcpgd42H9Khtdx xq/ys6PgZ3cnjBpHYFsBsAd81zZ8U6KOVuwMDkYP8sUHxRom8gaggB7McVLcWP2Fb V/cdCcqSQ2OMcmnfLwe3Uc1zY8T6I4KnUYAc93FPHiTRSq/8TO3b1/ejpWblFj9lVW8WbrKHOB17VzPiLw9p3iLQZdO1KISIwO1v4kPqDV9dd0hiCt/BkjI/ej/ABpG1jSXxtvoMnpiVc1PutWZvRdajNThdNHyVr3grxf4G1s6jo80stsh WaD07BhWvpHxz1OzjSHWdOFzjgunB/Kvps6hp0kbK11CwPBBcc1x qeEPBesF2u7K1Ejcl4mCk/lXnyw0lLmpTtc 6p51hMVFRzGhzNfaWjPNIPjd4cs7aVLTS54jspoogeGC45ZuSa5rW/jtq92j2uh6YLdm4Er/M2PYV6ePhP4EaTf5RPOcCbiuo0jwX4R0hlkstOt/MXne43nP41Lo15K0p/cafW GqL54UZTfm9D5u8O/DrxZ4410ar4hllgt5GDtNOSWYeiivrDQPD n HdAh0/TLdYIEH4sfU 9asbx7RsZQOvarO6PeSJB ddFHD0qPw6vufO5nm2IzG0bcsFtFbDwoxnHPRa5OQZ ONsVOfL0hsAe8g/wrq1kTy8hxk9/SuQgIf45XpHPl6SnQ rn/AArds8Olf3n5HZkgA9z7muL8Vsr6x4ViXq qg8 0bmu0wA2VIxjrXFeIMN438HRk4H22Vsn2ib/GnYWH/ifedRIuRkctjmvKPiP8PrPxnoO5VWPVYh 6lI6/7Jr1o7DJlSDnpVdxksAB05561MoRlG0kdOFxVbCV1VpOzR8A2moeKPAHiY6ffpdx2cTEGBZCoYeo7V7joHj3wdqlsol1  06fjck8uMfjXtWt GtH1 wNrqlnHOnQFh8y/Q9a8Q1f4AWM8jS6TqTWx5OyUbsV5zw9WnrS1XmfpjzXJs1gvradKp3WqZ3B1rw5Hbgr402qPW6Q1wviP4l6DpcbLZeJbnUroDCxxKCCf8AerlG/Z31bzFX 14lUHooOa7HQ/2e9HtbhJdWv5L0g5KINoNYcuKlpypGcKXDeG/eTxDqeSijxWXU/HnxQ1mPSImluLbzMqgGI1Hq5Hp719Z/D74e6d4I8PLDEBcalKoNzckcn2HtXWaPoWlaDpQs9Ls4rSFeojXBb3J71uAZUkE4HXA6VtSw0KcuZu7Pns1z361T rYWPs6S6Lr6goO09j79qRiok5PX9KUk5GP5U3o5JwCOfrXoXsj4lPU5nQwyeI/EyHp9tDdfWNf8K6lV3Y/vE1yej7R468Sr3E0JPP8A0z/ tXUqCDuPQ9BUGtX4/uLATbHyuOOaaRuPt6imjBBbOc 9OQgnCnFMi5Kcq4O3Izmoxu2jcPmx3oUnZgkHnv2pCTnPT61LQdRjDJxjn1NJkE7cgADrTmLDqdo9c0wkDb3z7VOhdhMYKhj8p4FByCqkAgdKV2wAwOR3ppYbt3PA4zWbSKGkdscgeuaadxcgc4GfpT2PzZPAI4qle3SWelXF5IQI4ImkkPqFBP8AKs3oXFNuxz3hz9/NrmogZNxqLqOP4Y/3ePzDV1ONxyT9B61geGLV7TwBpUUgCTm3Ekoz/G3zN pNbxDCIjsefbNSndXNKjvUdjL1uc2nhXU7jhRDbSMc9DhSaqeGLY2vw80W35/d2Uec/wC6Kp NWZfhdrQGA0lsYh/wL5f610VvD5FhFEpA2RhRg gxQa/8uLeYspCQOc9FJPtXJeCsJ8LNPuX 7LG1wxz/AHmLZ/WtvXLpbTwZq1yWAEdnI/X0UmsqxhGnfB2KLftMWlY5GBkR1L10Lp607eZa8IRN/wAK4013A3yw a5x1Lksf510AB28kEgcd6yfD6mPwPpIUcC1j6/7o61rjG3L4xn061CVjnq/GxwxyR0zke9DLlQc4Hcd6YW QA9/WgOMFWY8dKbMgUnjH8qazFnJCjGO1Lkb155xwAKbnGEBAB65GKz3AYcE4JyD1qJ0XbkHk9DipAxOfmwOx9KYSCAdxJ75PWokimRFcYZCOaydQv7XTrFrq9uI4Ik7tx9MVDqerta3CafaQm91SYbo4 yjuzHsKrWuigTLearINQ1AcrkYji/3B/XrWDd3Y64RSSlPb8TAgkHiC/iv7wiHTonD29pIRl2HR3H8hVzxA0Ym0SVucaknT1IYV0cljZSsrT2sZYDGTECef5Vy/iXTra38OPdwxnzIJ45VG444cdBnHTNRyvozeM4SmuiOmJJAUnPoKY4G7KjnHapQAIhu uc81AdvlkjIA4xVp6Hny3AAFickH09aruAW5YjjsOam bbzwM5NVz8zsxBz0HHSkI5LxC7TXOl6XHytzOJLj0CJ83PsTgVufII8IwY9MVyQltrzxnqNxdxGaG3At4W8ksoI5Y5x6nH4VfVNFaY7Jxbt/CBKVP8AOhqzO6ULRSNC8mEGlXEhx 7QnJ6HArl9Th8vw7pWnK WuLmGMkf7JDEn/vmthrCGeIINRlcHG5d4II/Kqd5ibxzpdqAwFvC8vHY8Af1qNyIpGneTi20W7uSSohhZz Aziqeiwva FLBJE/eeSpfP94jJ/mareJDu0EWmWL3U0cA9wWAP6ZrcULHCRgkLx16UJOxN2oepzYU7hjKselTIpyG/izx71HsOcjkdDx1qUKwKnHHYV9EjwUThQAR3xinxqDGVYgnGQOuKPlydoyRzz2qRCNvHykHuOaoYoTLAqO3GD0qVTuZsKFAJ49KAGWMYbIHcVLsBXfjHHX1pFIcuCNpHP6U8RnftJx654pi/KMnJI5HvUyhXywb6AGqSKHEbm5GB0qZAAAcHj170i/KvGcHtUig52cYP6UmrC0HruGSV2/1p6nLLgAndzigZAwT AFTRna3PTPTHSmtdCLkajJOBhqlGSeOTjpmnfKAcAFsk08A4G0lmz607CYjMMrj19aeTGLd cMo6dKYqgvxhV6getUNRlkg0maaONpZEjJVRySQM0pKyuawV2kTl0 zncenWowylgucMK TNX8S/FS81J2tba5soixCRpbHIH1IrJk174soGG 96E5Nt0/SuBYid7cjPuKXDdepFS9rBX8z7GY4QNu6DrmoJUjZgzAKxGQc5r4/bxL8VVjCl7w8cE2359qaPFPxTU5L3LKOM/ZucflVrEy/kZ2rhjExWlaH/AIEfYHlRK5 VR9BSGKAOCqqWx6da Qz4u KMYJzOQextuR lKPGXxOCKT5rEHjNt0/Sn7dv7DNFwzjLfxYf BHRfHa0iXWdGukUA7GVsDGcV7B8JLszfBnTckEoWXP48V8t6/e MvEbQLqcE8ojztIhIwT1HSrmheIPHXhrTDY6YkyWpfdtaEnafUVxRqyhUcnF6n1NfKKtfJ4YX2keeLvufdIbMRH8GOK Xvj/Cx1DRJgMnDLk/hXKr8SPiUuAwyh4/4965rxBq/i/xfcWq6rAZPJ5jEcJGM1dWo6kLKLPJyrIMVgMbGvUnHlW p9K/Ct3uPgRapkEoXXk182eCD9i/aK09PuhdSMfP  RX1F8L9GutM EkFtexmOWR2fa/UA180 NPDeueGfjBfX9tbSbTdm4tZ1XKtk5/n2rWonFxlbY6csq0auZYqgpJc97H3XAwCE9R24q354I2nqe9fFcfxe8dRR5NkjlD1ERq0vxo8Zhjmwi9v3R49qf1qHVM enwpmd/d5X/ANvI mPH 6X4R Ik4IOnyEZ/3TXzD8Brlovi60QIw9qw579Kh1T4t LNT0O706azjSO4haNmVDkAjBrzzwzrGreFvFEOqWUR8 PPDrwQeorCeIi6qkk7I zyzJcVh8srYera89tT9HEdWUdB2PPSuV8br5/wn15CODYS4H/ATXzOnx08TKw3aVEencg1DqPxq8Q6j4cvbKTSo0W4iaNmBOVBGK3niqUlZXPpuppiesDOa068ZKKsn3RF8CZzD8YlXgeZbuMdM4xX2qsn8RIJPUmvzl8J6/e FvF9rrNjAZ5I87kbowPGK9pX4 aoX3HRFXB7vUUK0I07M m4hyLH43FRq0I3VrbouftCqD4i0B VbynAOPcV7F8GnZvgRpaZ 4zjB7c18peOvHF146vdOaTT/sptwQoBznNfV/wdsp7H4K6fDOhDO7OFYdjWmHalWlJHm5vhqmD4ep0a2kk9j1lGHlgkcEc5qTcdhO2mLnPueMVIUIBzyewr3Ej8jYKcvtycDqetOb5jkjGe9NxluBjvUi5H3hwMVSSJQ0KSu5epxyKdGoDk0AkMQD1POKcoJGAD070wHpxHhcD2p5yBz3P5Ug5UYGOKlj 6C2R7H1pCJcMw5IzTwmQOcj2pobDFjlR7CpAOCOgHYUxjDhQcnnpwKcoBOQNwPI4pzfcP8fvmvPrz4jeHLDW7mwupmW5t5CkiiI9RVe6tzqo0K1eXLSi2/I9GVQDwM98VYQZOCCPavMI/il4WMg33LjjqYjxWpH8SPCobP244xxlCCspoogeovqdcsvxq3py 49DjiIAweg6VbCZViR06E9q43TfHHhzUb6C0tr9XnlcKilSCSa9Bjj/AHRz1PvXTFJnnVaVWi WcWn5lRYh8oAzz0NSeSd NuK0o7dg5YLkBu4qf7OxYZHy559q1UTjcjGaEAgY79xUZgBHIzW81tknIPTFQmDC4Awe9U4ApmH5GOMAgVC0K7MbQcdMitx4f3ZAqtJGMYIz6DNYuFyudmO8APVf05qu1upU/Ipz7c1tMjY9D39qqyR5fnPrxWLjY0UtDFeCMsD5YBPqtQyWkO7c0UeB6qK1JI1CZwM metZV5dW1tIqzTRwlvuhmAJrFm8HN6IrPZ2TkH7JFJ25jHNRNp2m5GbOAkjP qX/AAo/tGyLH/S4z3HzikF7bkAiZPqGFYto2iqq7kZ0bSGXa2m2z565hXn9Krnw7ojsS lWxGc8wirwvIS 3zFPGTzV0ECMBMHP8XY0rRZbqVY9WYB8L HpGBOk2x/7ZioD4R8PiVgdIgAI5AXFdQobYo6GlA4Hqec1Lil0EsRXX2n95yn/AAhvh1iD/Z0YGeMZH9aafBPh5W3GyI78SMP611wClu fWpNvzBQenPNTyrsX9axH8z 847/hDNDzxHMD6rcumfrQPBmmhhslvIwRxi7fj9a7IABiMjPbiheTx/Op5Y9g s1/5mcZ/wAIbZrgx6hqEZPpdtzV3SPDVlpGqXd9DNcXF1MqxyPNNvO0E4A/OulUfLkEE o7VGdocg8g0KC6EvEVpRs5CdQMnn1xXM67oCatd2Mwu5rKe1dmjkhxnJGD19q6hhkDjj3qrI2O/b1ot0MoTlTlzR3OLPhnVuNnia8bB6mNTUf9g68JMr4mlBPQGBfyrr2kIY8fKKarAjplalwidixFXy 5f5HIf2J4jxgeIec4 a2H NNbRvFQwU12Bjnvbf8A167MHL9T9M1OgAGcbhU8qKWKqLovuRw/9m LvM XVbNgPW3Iz tI9l41Xlbywk9RsYV3SgBwccHpilKsARjnqKn2a/ph9Zl1jH7jhVj8aqnI0 TPTBYZp4k8aRo2LGwlzwAJ2H9K7jGH5/DimMeSMcetJU0upDrr Rf18ziWvfGCjB0e1kx/duuP5VGdU8VA/N4fQKO63Qrtn4z2Ynik2KY8E9uvSjk8w9vB/YX4/wCZ5la3fiaz8SapfP4eeVbrywqpOp27QRnn61sHxBrXmEP4Yu8/7Lqf612ZH7vbkg9MHjNK2dvUHPPWlyPuVKvTnvBfj/mcaPFF9EuX8OaguB/DGp/kaB4tYIN hakvHQWhIH5V14QL24xS5yMYxx19BUOMu4RqUOsPxZyJ8aWoIEmn6hGc877Jx/Sg N9JWQh1uoznGGtHz/KusJxkqQc84FMypk6ZHOBisrS2TNufD/yP7/8AgHKHxvoPG65dAeTuhYfzFH/CceHFTc2oKMH NWFdXiMoDtB7crTGgiYYMSH329aXJJdR82F/lf3r/I50 M/DTAAavbKcDgyAVKvirQGUKur2xHf98P8AGtc6fYSEbrOFiDyzRDmqp0bR5BtbS7U5 9 4XB/Sj3m7XIUsK31/AhXxBozpganbMPadf8awvFWrWE3gqe1gvIXe7kS2O2QHh2Csfy3VtN4c0Bg27R7Mnp/x7r/hVZ/Cfhx3ZX0a1YEZ/wBSKhpvRm0XhVJO7 5f5mrHd2iwognj4GOG6VMtzGztiVW79a5tvBPhkEkaXEjE9QxB/nTT4K8P/wANo8eD/BcOP61nJO2hDWHbvzP7v CV/GEyS GLe2WRd9zqFvGRu7eapP6A114XaqjqMVzcXhDRItRt7oRTSSQSB41kuHcBh0OCcZrqSuCM8HqKcU pFSVPkUYO5yfjdinwr1aONsGWIQrk4  QuP1qhMj61qiaSgB0i0C/az2mcDiL6dz VdJrWkwazor2M8jRRMytmM4IKkEfqBXKQ DHsrQxWmv30CNIWZQVOSTkk8dalps7KMqKo2btI7hWCRhBgKB0zwKcXy54HFcP/YGtIpEfia4XHQvEppv9j JhnyvEatnpvtRz tR7/YwVGDfxr8f8jtzIMjkMTQfuAKcE4NcSNL8XAf8AIbt ecm27/nTvsfjOLkX1i49DEwJ/Wsm5tbCdCP86/r5HYmXDAZByetG4lgT8pA/OuOVfGSwsWGnyMOV 8M0xrnxmhIFhYSH2nPP6UK9th/V77SX3nZudoyMMDXO6nrBhvV0/Tk 1apJxsz8sQ/vOew/nXP6hdeO5tNkhs9NtbeViB5oud20d8Ajr9aj02TXNKs3WPw7JIxO6SU3Su8rf3ie5qJyl20OiGG5VdtN9ro6rS9Mj06GWWeQ3N/M264nbqx9B6AdhW0wBVvl5HWuNGv6woLSeGLssOfkdD/Wm/8ACU3gXMvhvU0J7CIHP5Gpi/IydCvN3f5o61iCpPTPRTXNeKpAnw/1LgEtFsjyOrMcKPzIqo3i5Ax8/RtUiU8Z xMQPyrndb8TWV4mnW5truOFbxJLgyWjjYqfMO394LU8yuXTw1fn E9CRcQKJDgAck96iwuwA9R1rmG8a HFZd1 I93OJI2X Ypn/CY G3UZ1a2UnjBkwazi1YwdCvf4X9x0p5QZJbI5OazdSuEsdDu7tmJEMZbjvgVUj8SaHIgEeqWjFuceev8AjWN4i1XS7nw4tvFewv51xFHhJASAXUnv6A1Sd9iY0anPrFl3QrGSx8NWsUwC3DDzZyf ej/M36k1pyRRSDDorxk85GaSK4tmgwsiBj/dagzpkhSRxwego5l3HK7lcwpLS2XxJaLDBGjlGdyMA9gPr1rOsf33jvU7hchYlSBfTONx/mK1Y3DeJbxwwIhjVOvryf6Vk HpEl0u4veAbm6kdSP4huwD QFWjdXUHcNWAm8VaJbBSVjked8dtq4H8633CsSQQucZwOa5 3bz/iFfOSALe3RFIPOSSSP0rccoY p29 OtLW5jNWaRiorKhIBbPqKlGfMTHAxggVH3YEBue1WFwcnJLDtX0LVkeETxDZEucgNkDmnBRjs3pnrURUE4HBHWrKKhjznLdaz1Q0h7BhGGHAHUVORk5YYBHrTV/wBVy2OKnRB5YUAYzxipTsWQIqlgNwJHTJqXaODgL6HsalAHmnAG0HGCaCQU3HOcdK1uyWmKis039M5xUwfO0YwehHakByCdpIHIHrQqhoiSOQecVd00STlNvAOMcEE9qeTsGMd6jG0neCMHvUyEsxDEdM1KauS0KXX5F29e KcPlGE4yMc0DbkMBz3PapB8zkg4xWgWEIGSuBu7cdajKEuTjPrxxU7Km8Meo74pW/1nGc569qPUrYqeWqnrwOTmjyQYyxUHB6GrHCtzwp4qUomAQckdDRY0UmUFizkbQB9OKkECrLkLwevFW1UBCcY46dKeF YFc5A60bFc0u5SNuu3btXp0xTvsyBgTGBj2q6IwSGHOBkihVGcNjp25qkWqkl1KDWsPy/u1PGOVFMMEQi3mNSMfMB0xWqFbaP73Y1BPC0lrIgO1yMZ9KqWqNFOUmk2eb6j438JaT4ph0e uY47qUgHChgmf7x7V3kNlbZVhDGT2IQV8p6b8J/Emo/Fad9chdIVuC8lznKyDPY19dWkIgsoolHyxoFA9cDFYUZVJRfOrH0GY0MLhadP2FXnk1r2DyANoCcD0qOW0hlUefGsi54DLkVoBF bvx0pVUBjtO3noe9bHzPM07mIukaeZMfYLcgHoYl/wpf7C0xshtOtyvUnyl/wrcAVZMj5ieMVzmreKdC0K9t7bV9Qjs5ZziLzD97tSk0tzshPESdoNtk//CP6QX3/ANlW3vmBcfyo/wCEZ0VjhtLtCh5wIV5/SughZZIFkjYMjKCpHQg9DVgKAoYrk46UrJh9YxEX8T 9nLnwr4fyW/sWzzjn/R1wP0qP/hC/DZyW0Sz3Hr 4XmuwIDA56/Wl2jgockdeapRj2LWLxK 2/vZxp8D GDFn xLXHp5Ipf8AhB/ChwP7CtM/9chXbIrFjnnceBnpS7VAOAAc5PNKyD67il/y8l97OPg8D FonV4tBtEdeh8oZrroIVihWOJAka4ChRwBUioAp7frUqjCZPP8q1SRzVK9aqvfk36sNpDhd2CDjgVKv3WH8R6c0gAb5uhJ7UAcNgA8VocbYqAgLgjdnjjrT9mGIGPxpMZb6fnUhBBzj6jNVsTcaIznOflPfNSDO4gdAetIAOGPTGMUqj5TweemOwqrAyT25HPIqUDegyTiowByeT2NTLg55/8ArU0iSVcfKDj1BqQ4M M85yGPWmx4Ix0B6YNT Xkjac8fnV2QDP4mJGRivkDxZo2pj4t61cJYzPC902xljJHI7V9iCP0XI tVriW0tXRrhlAbIyeueKbpKW57uWZjLL6rnGPNdHx3Fp90NwbTJuUA5iPGO9W20y8leJlsJY8KOdh bivsOKWwZM bHgDnJHHrWxGtotwEzGHx04zVxpLufQviSonf2X4/8A UfCGlXsPxE0eaW0eOJLtGZmXAxu9a x4mgeLcGU4GBzS28NodgIjPOK3oI7YyeUpTcBnjHArvhSSW58tmeYvMJqbjaxTi8hkyrADrwatCOPZkOpz2rZitYGQKFU7unFW0sI/ eSnjrtrpUND5uUlc50Qx45IJPvSPApXhwe5NdQdPVYiTEvHtULWEfLeSD07U3TIUkcg0SheqhexzzVF0TGTtIAzXXS6dEIeIlwOelZsulW23mBR6Y4rJ02aqcWco67QTkDiqZBwMEHPpXQT6VbF2/crz3xWebSOKNo41CjPIArllE3UlbQw5UIU7RzXzH8dTKusaIkbHmNySPqOa qpY/lOB9K5DW9B0rV5Y31KyiuzHwrSDoDXHVp88bHuZXjIYPFxqzV0j4RmaLzAftUqDaA2HPpVQsy20hS/lDFNyHzCNpwTj lfZkngDwmQcaRAAOcgGs T4ceDm ZtJjBHJCswyPzrzJUJH6ZHibAdYP7kfFB1PU4Quy8uFJPXzWr758NyO/gHQzISzmwhJJPJOwZzXJH4aeDW4OmIvGeHIP866 20i3t7SKGGaaOJFCIvmcAAYAp0qUoXufPZ5m2DzOEVRjyteX RvK/KnPHrShgRgEcjrWQdM/dri8nHvvH FPGnkH/j9uN3 8D/StXJ32Ph7R7muuA2ScjpSnLZPQYrGGnTE/LqE Md8HH6VI1hcbSy6jKB6YBp7j5Y9zWGME5yalIxIcDdx6VifYb4cDUGPplBS/ZNQAONR6dcxjBpNWFZd/wAzXGc wFMyCxIHJ9TWd5GpBcG9XdjnMX/16uwRzRqRK4kc8bguMVLYmvMVztRuv5V4B8Z/Hmt DE0YaO8SNcl/M81Qc4xXvznKY79 K8a Jvw3fx5d6bKmoC0 yqwCshYNmsaqnKm1Dc9zJ54OGOhLFq8FueAD4y Pto2i2lbAJ/d vIH608fGvx6JowLO2kDDsn/166ab4B6mtuY4/ECsAMAeWcY/xqqPgRr0cm6PXYl78of8968j2WLa6/efrPt EpdIfczCPx/8WQ3Pkz2FrvJGRyMA819kaXcyXXhuwuZcLJLbpIwHQEqCa RD z3rkjeYdVgZ8gDIPQcCvqe0bV7Sxt4PscTBI1TiXHQY9K6MPGvFv2lz47iBZJJQ/s7lT62/4J1IY7DzlugpSwIznB7571hfadUCjOnL6588dPyp632o7QDphI6DEor0G2fB zk9vzRtH7pycA8UzjaDnvWSL6 5B0uQjth1/wAaZ/aF2ODpc4IHTKk/zpXIdOVjWBLAMeAe9NI3OfX64NZS6nPn59PuFx0 QH tOOqZxmxuRkc/uj2ouhckzRAwBz/9amsQcDPfB96yTq0W/wCe3uVbHANu3 FaiOJLdJQpXcucYwQPehNMTjKO6FfBTIwV9v5V5trHxS8IaD4lm0jUtR8i8hAEilCcEjPX6V6I8mAMA4Pevg74haXq1x 0FruotpU9xaC6IQ SSpAUKPwrhxEqkY3gfXcP5Zh8zxMoVpcqSv0X5n04nxf8DM5P9txjnupH9KtRfFbwPIwH9v24yOAWI5r4nNnsQo i3IO7LfuiCfauav7G5a7LR2UkK44XYeOeP0xXl 2ro/S4cG5ZUdlVkvmj9G9K8aeGdY1dbTTNYt7y6cZWKOTJwOvFdYrhpM 9fDXwEtWi M81zcoYlSyfaz8ckivtqGeHcCkyHPowNd1GpOcbyPzPPcsp5ZjfYUZOStuXiVYgfdJ4xSdFwSMHnr1qAyQjcS6kjoQaXzIwu4EbSODW6ep8vyskYDAUEc9cdKCBjgYI65pqunPI54NG/PzBhz15ptFrYeQNxDYc9RTQDvIAwDTQVLcn5iO1ODElTnbU2TAVgqZABJ6dKRkBcZOfahjjOTvHrUbj5QAMEnp6U9gIJHUttP51WeSMNt3deteIfHLxhq3hfwzpY0W7NrcTzneyqCcAe/vXz6vxJ8fAIya0sqlAXyinGfWvOqV SVrH22X8N43H4ZV4SST7s 7TN8hAOPfNOjYEEjkj1NfDS/FH4hpN8l9BIATg UPmrd0j4seOpvEGnWdw1vturlIdwj5O5gOOax tpbpnZV4UzGnTc7x08z7MAyp281IFBk5ztB79qqw5ESnO4kZ/SrBIYc9OwrrTUlc/P2mnYQrnk5ZiccdDTeQ4YfLjjFOB68HPQ/SlBAIGACB2FJ3FqIADEecj2pmOQdvIGeRUgLHaAcfhik4MRHCj0xRZX1KWgwEDqCR/KkGTgM2O M08jEecE lBwWDAc9B2oaTQO5A2AMY6HoahbHlDonrVluFy/wB4nniuO8SeK9D8MRQPrV6tkkxxGWUnP5CudpLdnRSpVKs1GCu/I3GRCv3UPHOFqi9rZuWDWsDZPzExjpXDx/FPwRNh4/EFuB2yxH6EVYX4heD5G/d6/Y4b/putR7SK2Z6bweOg7OnJfJnQyaPo84 fSrRuP fdf8KzpfDGgSqTJo9oBjjFuo7e1OtfE hajdLBY6pa3Mz52pFcKzH6DNdAuAgYrkYq000cs5V6T5ZNp/M5N/B3hvBf yYI2PHGQB Rqi/grw VLJbyQ4OW2TyDH5Gu3kUb1UfNnnnjFQMi4K4GRxzTtfUy sV1qpv7zg5PBOkgP5Fze24brsvX5P51DF4Nt7WJYLPVNQtYUXCAXOQuPYiu78pdm3IIHX3pAgICg4Pr6Ux/W8Q1ZyuefweEpra7llttevlMr7pdzK25uncVINA1kSEJ4mmGDwDbocV24RBktgkHjAqIqVA4wc/KTU6y3J s1ZPX8kc RvQEcBfanDcGI4I78dKQEkgjp7dqeyqygYAJP1NfQ2dzwbq5Oo6MFHU/SplXbwTjJ4ApiDdICCQD0PpUoOGCj5s9SDScUWT/ADBQVBOOx61Ng5C7zzjrxio1yFIUDLVZjXccggEH5fSs7dyrMRcAN1Jz1I60/C V7Z49jUhb92Qy59aCuVwBgdMntRexIDBQnA9CM9Keu3cV2lcjmowApAKlye2Kkx 9B7jr6e9Wl3ExR/FliOec1Kp2jDEnjjNR/MXwflGelLknJYYAPaqcSCbeSclgD1x0/Chcbgw4qNHLDGMgn060 MFXyePanqgJdzFw5J569qByclunUU0cMO/HJ/GlG5lHOR3PrVDHhlK9gQeDUik44 6elQr1469vepRzzyMdeKARIcEhSuSOue1SBiUGW5HoKhyj/wAP6VIuAwJIwR0ptFNj8kYzyf6UNtCAqmeOcumCWyxP1z1pflAPzfXmiwkx5JTtnPQ4prbRkqevvzTS3KjOR3561FJNjBYhR3zTuWtST5ScqSAf1qYcKSOh6Vz11r2lWAzc38Nsvq8oUfrTdP8AEuh6lcmCw1W1u58ZKRzKzflSU4N2ub xrcvNyu3odKXUEY4OeOOhofAkB4yfU1AZV2DLjgZFZt5qtrZRF7q5jtwB1kcD dU7LciMW3ZGsz4hVRxnmvln9oJR/bnh fsAynt6Guo L3jHV/D2naJdaJfCOO4c5dMEMAAR FcP8WrybV/hP4M1efa08q5l28DcV5P5151eSnFrsfe5Hgq1HE0sTL4ZNo ofCdw83w20OUn5zYxN1/2RXTKwxnOCegzXmngPVLX/hUvhzzJlVntFUAt1xxXoEcq7VIYOO3tXdG1j5PHU3DFTTXVkl5eRafYyXFzIIYUG53c/KB3JrD8NeL9D8Uw3DaNcicQvtkAGCM9/oay/HGkL4j H95pLXv9nvKAFlLeh6H61k/DjwjYeEPD0kdtcJeX0p/fyKcj2FReo6llsaU6GFeDlUlJ899F0PWgcZ9cUu4FMjqRVJJiTgnC49aUXMcaEyOFxznNb7Hj2ZoZGzkFqeC2wkDI2ms K5jmyI3VsHnBq4j5xk4GOfcVotRPQnB TA/WnY9QCTUWAwJJ4x2NTKMnOcjrVWMncUdAdvXrjtTgTgZGT60mdq5x71ICvmHJ5 lMQiEknC9PWpBgYKc8cmkbATjgk lABBHt3xWiHsSrgZ4xzUgyG TgZ59qaF UDvjr61Mq/usCqJJo EXH5VOv3vu5APAx3qsvCqBz688irUYcSDa3atEkTcmjBDkLj0JrO1BrIMEuYDLnJBI74rWj 6MD5e9MvDOrRbLUTKZAOecA9/wrdIqD945q1j0aSWBzbyrlQAhGcjAIJ gFdZB/ZVxpen 15sjdWJx37AHp6UI04vI2TT9wIUuCPX/OK6a3aVZG26fkA4VgvTFdMIm9So33 8j060sD5caq7FjlT3OK6u3sLPyyvlsDuI69x3p2nrJhW xhGzkjbzXaWls7FCbUZK56fjXfGFzz6k2ZllaQK5YKy7RgjHat1LeIRbidq9yV4rqNP01WjGbTaccjHOa6GLSwVA zD06etaOcYaM5eVz1OBFkgQlgcDOeOtQtp4NrhBk45GK9SOlwtES9vg96r3Gl7IGCQDaOw796yVaD0G6U0jyOey2q2Fwff2rCntm3kHg55r1G szH5jeQWTHPFcTeoBdSARHGCeR0FauKaujD3locZPanyiO/vWLNCVL8E 5NdbNwyqyHkDB orIuYMFi3K9cYrjnFHQpWOOmRvmBBGD6VzWtwQSaVJ50zQxkjcw/3hiu2nQ7SR1HU1yetJAumTLOnmq23gDnlhj9cVwyjodlJ  jgpNMQxTRR6u2wgoct0B4P4/41UW2WfR5IRqxbeSQ277oI4HPbBq1c/2MYpnSBmZZCXUD JQSaqi00GaW3EUb/wCkqUVuRwq4xz7VxNHvJ97/AHFI2Ept18rWcR8KG38 gGfrU6Wl9vJGrB1LkgZ7ccfofzqnG3h2O2l2eZ  2ErjJ 8MHp68VSjHhp2eHzpNjgBS33eQUwPyNYtI3tKX/wCybTQ6mLOCNdTVpVdtzEfe4 UfnzU0sOoyvCE1BUkj2ljnqcHOfYn VZNzY6FDDbu08iC4wyuGPTDHJ/DNQi30JmmmivZfljZ2AY8qAxOPzNRZNmFovX/206rTftyXMgvbhJvlGAvY471tGdDJt3D6Vwl1HpA003UmpSRIsbRNtbn5UII ozn8qVrPSg5WPW2iIUkYl5XkE4/L9aNUYukpO/6HerIuzqD NTAgtnOQeOa88FtbR21yF1 QR26HzGDcpwR/Su0sJ7b7ElvBcpcyxoFb5wWOOCaXM2zGdLlV73NIcqBnLHoKGBCEnk/yp6kBmHXA4yKRslCBkD8qWrOZ3sQsRtwD82emKxdSa6is99rCskm5RyeBlgG/IZP4VtsDkYyVz1rn9dhlk0lliuBabmX5i23owOM /Sk9DalrJXOWGoeIVgid9LyyxEyKG 820HA/HNTSalqomjYWDMrQhiqKTsY54/l dRvba6fLRNViOSMZ/iGcng 2BTYbHxFFE8P9oRShSOoy2Nx6/h/KsbtntKFP 7 JA3iHUbVVkvdMdVCfO4BCqQcE/TuKsnxLfSPH5WlzbSM4Kn2z29CfypVtvEZ0Zo5biGeYMQBgDjYRk/8AAsGmyx I fIljAJwAcE456fpUNspRovSy 9g/ix47kw/2bMzI7bwq5O0E4OMd8D866HStTkvrqWNrV4VVAVL pwf61z6/wDCSxz/ALuG3ZjGTJIQASR0B/IfnVxZvFBkDfZYlUsM88gbuT VK8upnOlTcbRsvmdlk4A5UDnmm55O49ehrkUvPEXnBn09duBkK3PbPf610FlJcyaarXcQin5BAOcc4FaK7Z5dSm4dV95bCqrfKeT14pNvBwcj3pVBMed2W70jcg vvV2MCIL85K vOKGwVyTjnGaUgfT/AD1pXwcBQQOvWpaArsoAPPHoe1YeoajptjIq3MiqWHGe/IH8yK6EgFcE4weRXD6tqGlHWDb3Wnb0VAwcpz1J4/LNZzdlc9HDR5pdfkXftelPCtx5sAXjliOO4/Sqpn0MSEM1qFHXIXnPAH61zd1qOgoDajS5mjdsyHBI 6D JxUTT F1CkWVxGpYEkKfYjH FcvOz21SaV/eO0jh0NmBRLNiTzwvOamkt9DiiEstvaqp 6xVQK45o/DFrPJCRLB5MgiLY79v50hbwxL9lLTzeXCgWPdnHQn0571LdzGVJyd7yt6HZLYaNNEGigiYEdV4zUw03SB8vlBWPT94w/rXDzReHri6lMV 8UhcEMQcH5s4A/MYpy2Ghyok8esSN821Zd dpAx1 h61N7PRGfsbfaf3M7QaJp7HOHz22zP3/Gn/ANh2Plld86/7s7/403TLmzjjjsre6W5ljU/xZY88mtpnydxOTmtIuLOCU6sHa7Mf yoSoAluVx3840v9kqM7L66GT083P8xWwNu3ORweKYTlgcfhiqUYo5/aSRUtbRoCM3MtwW/56Y4 mBU02CeoKk4qfIVh0P49KhkGdwBwB3xUNLYq99WeX Ovh/pvjaa0XULmWFLfO3YPXvXlsnwF0cQhItWuVYnPQV79rQvfsjraSxQucbXc8j/9fSuZgTX4bhg88brt6tjgnGP61zyjTe6PrMFmWY4eioUqvKl0PID8C4UhKR65IAeASgzj0qzpPwT/ALN8VafqK6z9o ySiRY5I8Kcc4r1Mv4lV9xWJ/x9/wDCi3m8UIzmWCORQRjP86y9nDsd9TOM2nBxdZWfp/kdCjawmdogb0wTUpm1sR5 zQOM4J3n/CsSPUdaSG4J04SupAjG4Ddk/wCFOl1bV0tYpP7OLsQSUz0xSSPl/ZSvsmbAuNYUg/YkIH92b/61Kt5qgJB0/oe0wJxXOp4jvWdS2mTBXzkgEjrit3SNTnvspoogebR7QgD7wxnIzQku4pUpU1eUUTC/vBIQdOlPHJDL/jQdRuAvzabcLz3Cn ta3BJIGRnqP1oYsDjqenSm15nI5R7GUdVbbhrK4X3MeauWtwlypwjoV7OhX8s1OyhpMZJ9cCjC7nOccY XrWajK5m2uiGOcq2Bk84r5U P1rqF/rekQ2trPMkMJZikZZQSfavq0rtbjPXiue1W/srGLzLuQDLbem7nGaJRi9Ge1lWMeBxarKPM10Pz0msDGwefS58gc4iKjPpWZPFbLbtEtjJHKV6kdDX6CHVtFNqJnljMZwvPv04qH7R4eKbpHs2UjOSFNcP1eDe5 lw4tqL4qD 9/5Hx/8ABmwaT4228siOv2eB5AXBAzjH9a 3Y5U6CUDjJGaxlsfD0m7FpYljyfkSp003R2TKWsG1uRtA4/KtoQUFoz4fOcwjmmK9s4uPS2/ Rp5VW/dnkcGmSOAR83Hp2rL/ALJ0mWMhYxsYZ WVh/WoDpGnEH97MOwxcvkHt3q Zdz5vlh3/A0y2SMEH1HrTWbEYPHTjBrMOjQqwCXN0D2P2gnpUcukN5pZNTu0BJ43g/0ou3sQ40/5vwNEkgHPH04qIZYYJyQep7VQ/sm6VcJqtxx3ZVwfrxUf2TURIB/aZbJ YNEOfbrRrYXLH YooSASBx25qYEbgN2O5zTIwGjAGCe2akA UfLnscV9EjxrEqfLJn0PJFWACZt2Av8AWolA2scY9zUyYDBWGz3I602CdiYH5hg5OOM1YUDePlyexFRxqVJ5HA/E1MGPG0fQVmzW hOuAQDw2AMUAAtyMkiiIZK7uVxyc1MVBIUHOOnFSIj2tv5659KcFOSjc56n1pw3FAWOexBoYjYqqQDnvWq0Ab8wRtx4PXmlGRIQD82KHyDn7wB5 lHLMxHB9PWqJsKGyMDjjsKerAuAGxt7VG3ysQMYz2NSL94E4x9M0rMkcGLNzye/tTuQOABnJzUQBXgYOeRUhCA7ckn360xDwW6ngY9elPQFeSNwJ7 tRqSinPIz27VKSc7u3pTBXFwyEH37VIDhDn0qMltiqoz6nsam6bOcfhVpASA5wM/LnHSmNkEZIwOTxSE9FJ5z69qQ58rKjPqfWm00Va5VnkWG3Mjnaqgk/SvlbxZ8UtW1vxW geGH8iPeY/PU8uR6dsV9Nane6fBp0sV/cpBGy7SZHxXy5c/CzwvJqUr2fi BY2JKK7qWHpznmvNrqUmknofbcPwwMakp4pPTbRtX RDZ/C261SQXGt Io/Mblw029h tek Dvhno geKrfVrLV2upYeqDGDxjtXmQ fornicateGUBfGMGAP744P51ytrDc DPjnptta6sb2HzUZpYpDhlJ5U4rnhanNXgvW59xUVXG0506GJ6fDyWVj6o8c NrXwn4YMxxJdy/LBF3Zv8K WNfs/GGueE7jxbqlw62CsMISQME4GBXU Mb2LXf2k7PSL248uwgkSIBzhQSMn eK g9VsvD2seCJtDmuIVsnjCbYpApUCt5Qdebbei2R4uH5Mkp05unzSnq3a9l5Hy14hle6/Zs8LzSOZPIu3jB6 4rpfF Jv2WPCMpORG4XJ7dR/StT4m6NpGifAmz03SrlZkjvA4G8M3IPpWVqmZv2NtLkwGMNwAQRjHJrOatzeh9BTrxr06dWCsvafmdDaeBLvxp8FPDV5p pm0u7WJ0CnO0/MfTvWVpvjjx38NvEMeleKoZb/T92A0p3Er6q3f6V6h8HdQtm Ctkkk8aPHI6kM4BHPH867TxNo i KPClzp2otDIGU VJkbomxwwNbOCcFODsz52tmChjJ4XF01Ond9NV5pmL4o0qD4mfDKym0XWPIiZxKsgY4PHKn/CvIfgw99p/xr1LR7i5eVY45EYFjtJVsd6d8GtWu9D Jur DLuUyRFn8vByN6Z5H1FQeBZGtP2v9aiYn95PcDH4k0RknOM p308PLDUMRg004cvNHTXU988c PrTwfoIkP8ApGoSZEMGeSfU14ZaWPxM IiyXrXj2OnHJRQ5jX8MdarAJ47/AGppba/mBsbaVkCFv4UPI/OvrC3a1trJILcxxQogCquMADjAqlTliJuUnZLoeM/ZZJShywUqsle7V0l5I ZvgzPqmm/HbVNIvLuSURxyROpkJUsrdea v0z12gkjFeQ6L4D0zSfi1eeKYL4tLcl2aDjCluuK9ZiZexJGeDXoUouMbM fzvF0sdiVVguivpbUtgsQOufapwWKj IkcCoFJD5HI96lA3bj2963PlWSg4I3DBHNOKru4A46VGGGc9j2qUjr8vGeQKdmIViQM9h75qVCzZGOB1NQKAH6/rUiN8 MZ9OapIW5ZQqD2HbjtSrwwAPbk1HGNrg9CakUggZBx39quwFtNoAyePfpVlAuxSQcgelVwBuspoogekd 9TqWYA/5FbxMS7G AMgr7ZpblZpLdVtpRE4cHPqO9EWMA9TUN01uqwtPKyDzgFx64PH5ZrZDjfmL1lDqZJYyo3zKCB0x3/rXX6XDqKQhTMjkjGG9fX Vcdpy2sEUaf2hnnhs  a7zSLaIpbsLoytGcM27qO2a7qb0HU/rQ7XSIJl2ecNzNg4UdPUV6bpmnr5CozAErg46V5rpgjd4l 0NhhlSfTH/169c0yFDt fK84we/pXROTjC7OBR5pnSW9sI4uepHNWwAOlIgAjXHIx606vEbcndnrxioqyCkIB60tFSWUri0SWJxtHPPSuE1nTtsMp2BkPBBX8K9IrF1OJWXAXcWB3fQD/HFdlGo4uzOKvTTXMjxe/tFifO3C4/CuWuI18puMZ4zjpXperReV5iBdhClQRXB3kW0t8uOMgV6U7PU8yJxd0nOAfrxXJ6qZIdNmmjhNxIoyEHc12t0oWQjG3B/OuS1eJ/sMoWbyzsxuLYwa86otTuotcyuefy3s0r4TSxuYt82ztuIP8v1rMe/u1trfOj5lyNx8vAjJxk9PQmuka11WOUKt0jwZLEnlgC2R lYVzHrjwSQ/aoy5THoVJXr dcEtj6CMqb2t97Mlro WpOifPsycR4xxux09a2orCye0ikFrGnyghdgBHcYqpJFrnlYE0RxwGIzkVnzf8JK7SbWhT91tXB43bev4NXM9xyTl8LS ZuNpli8SB7VGVBhMr0 lImmWQXaLSPHllMbf4T1FO057ttM/03ak 4jCngDtV4n5GAPIHXOaNDjblF2uZUmh6bIyKbVWRSzbOxLdc ueKhfw3pTXEzPaht4wy5ODzkn9BW uDxkNx2pQeSCAOwpMSq1Fs2ZZ0TTmhmh zgI4w2CRnr/8UfzqzZaRYWN281tD5TtncR7nNXkJD5H3fSpFBz169qiyvcbqzatcfgcHoe4AoO0D1FOyMEE5OfSmEjj L0wKDC gmdpyeeOh7VzeuJaNaBrnexE0ZAQ87s8ZH1rpDucDHB6c1y vXT2trCYrA3m6dFYAZwP734UmrnTRTc1Y4uS08PTSQpHqMqyGMIJFJO3IAAz2J4prx6B5qzrrEqt8jNsY5fHQHHU81bk1O1UROPD7RRkq7LswV4P68D86rLf6akwZNBeOLzc5KdwwwcfjmuZqx7yc1vf8CSSHSb2e52a3JAJS29d5H3i ePxP5VpDwxJcBrhNYlJkQiJ1bIRT0xz6Vm2raDqQ x2umyR4J2uo4GCRkH8/zrX0zX4RosdtBZyhLezVlyc8BF4J9ecfUGp31M5zqx C/wA7Do/DV3FNmLVZVQuWYbid2TnH611VvE8GlQQPKZnWNVdyOWIGCfxrnE8VWP2mIOrRwsgKyBeOoXH51pabrNnqUgW334wWw644DY/pVRscFZ15K81 Bqso2YP405ch8E8nrx1pRyOM5PvSZOOvA9RW62PPELbSTjkjoDTSSSCOcegpG YFjwO5xSAZyuNo6HikA4ng5BwfXvTH4dcHpUnBj68 lQ5BDEcetZvcBG4UgZbPQetcjqD6/FqUr29tHLCQAibhxgEkn8cCut 6OBz6muF1K1mu/EV28Ot/ZiBsaLdgKCOB dZSPSwqTn/n/wAAjhn1z 1HSbTY2tSpIPGRgHj8eKgS51V7a4MujqZFGYsqMH5jx WKsfZby10q4Metow8xWBZh8iA5YD1zzVFLPXplVZtVWLaqk4bGSVOf1Nckm0ewlB3vZfeOkvtQa9kEvh5JU3cny87j03dPSoIr2VoGF14Z3HaGf93gfQZHPf8AA1bkh19ZmT 0oI1EYBywznHX88Vo2sPiFriB7i4haDf84Udsf41EdRuUIx6fezMubu3tkXb4cd5CocFE6HGfzBqKOayOizwy6G6GNyPLjQgEnPT8F/WvQgg3BVwT9KUoMAEjPrTcWzg sx7fizgLbXtHtNWJhsJYJnwp3DHUbsDP41t2Xie0vripen 15RmlICfu DkZz QNb0tnaTgG4t0lwCBvXOAaelvCkIjjjVE27VAGMcdKFBpaEyq0Jq7i7 pzg8W6W0chQu5SMvtVOSAM5/Ktux1C31KBpoNxCPtYEYwfSpo7O0iUIlpFGq8fKg6flU6xxxKwiiEYzyFGKpNpmE3Ra91P7yT7rBsDHb1qFvvbt2Tx3qQ4TdkYGe9McYQHHGaUmcySbOK8SfY2Ecd1dNbvvLAr2wvJ9utco1hYXHlomtS8IW3A8DHOT7iuu8Q3EMRjWXTzdRPlHOOev/ANauZe 0tYFJ0mWFWUfw9M4OB6GuZq71PfoOagkr/gQrZQvaxzxeIXEYIG4yH0zzzx/9epbi2Z7mYW vCP58k78lRUMVzow054f7KkiVTuKLzjGACfwxVNpPDAmKtbXEezoozyee1LbQ7Vz32f3I2I7DUiHC64GAORzx9DTWsdeBQx6vGyB MnqK0dN0fTLrQM28ciRvITvY/MSCR/jUjeF7GSKJPNkXYpVGDcjnJot2ON1oxk03/wCSooTQa015bSx30HlxIomHbP8AFV 0/tz 0Y1llj yFyd3fb2H8hUKeE7KKERrczum3HL55x1pJPDDPHEsepTqybiHJ5BPf8KlrsZynRkrXX3HZeYoUjeB9DSM67jtIyOuDXITeH78wQQxatKMZDkkndnn8ccYpBoOpw2bxw6u 5n3AsOetTdo5PZUf fi/E7FZOCOMnpTcsSRnae9ccNH8QefvXVsSEYwBnkDjmuuQERoOWIABYjrVXZz1IRhtK5MWbbyMMB17VxHiC7jS8WCbTmuoHB3DaTnkdMV2LZAPc9cEZrk9Uj1r7Us1rLGyjA8snA45P8AQVnJXOnDJc93/kcm93oxXyG0aTa7KzPgkA44/LNQBfDU935Q0uWI7N3A64UnPtW9IdfNpK0YiklZhtHA2jvQ0uuxwxMNPjlcx5kAweeazb7Hte0Vvdf/AJMYcf8AwjMO3EM0ErHc3c5PBzSrNoKhBHcTqu5mAwQCWGM578Vde51vy8NosbrjkhQM 30FXJDKZooZNCTGF3NsGAT1A47VGpEnr713/wBvI51LfRp5lFpqMsAxk9QW4659qltrfTGMc1vq0vyOEbLnJ578 1aEc4iS5LaCUfzNhHl4Dz6Y4/Gs0XmmEywNocqJuG4bSDx39aTp8upMnJqyv B21vcRXe/yJVlZeCU57VPsbOxeWPX1rjbPWLSxsriOGylhEfPl9znjGT3rp9Pv49QsY7hFKB m9cZqkzxatGUNbaE7oAyHPPeotw5BHJ4OasEErhWByevrVd2Jwcc ta2RzrXQ5uPcORg/XqKsKduCSuB0WoVHGBnPqKeigsSRl 3vX0Gh510SIQzHaeh/yasxkhAAe2Rz0quFVSccZ6GrK528YLY7CjclomRTvBB69yasjHysOPT3qtGxLKCDnHSp8nBBG1s vapsNMmU4GAOKsAZHGR PWqyHIXrk8c1OBh8Dqal6GrZM23qfvHnNRkgZBxuHtSgBhkZJ6YJ9qaUYtjODxQmQ79BjD5vl5IHOKVSfMzjORg4ox 8BXv3NLnJ U89KsjcQLjj1PahQTk9fTHenbH2BTli/WkGcYB4HGK0TsIlDAqRgbs4Jz1p3ARcVHlQwHXNOHD/NjBPFC3BD CwGc5HrUqthRuxj0xiq6soLAZ256etSKxLjJG2rSuMmXB5BIOOmKkBYsMLhRxmoeMgEY9xUgbA4IHc1fLZi6kpAEfA6dKQ5KdsfTpTepXJXB9e9DMVG0Y5HPrVWKTseUeN/hjB4y8QC9u9Unt0RAqxL90e9cK/wA0zAP9sTccY2CvpAKOMjgnnAoeNSmMg7e9c31ek3do jw eZlhaap0qlkvJHzV/woOx3jbrMx46bOlaGl/A2x0/xDbX8uovcLDIHEezG7B6V9CtAoIA4z696d5RLKeB68Ulh6MXflOiXEWbTi4urv5I8H8WfByy8S L59Xi1BrOSYDzF25GQMZ9q5lv2f3YMDrrZ6H5Tj dfUBjULwOoo2DbnGRjuKJYejLVoVLiLNaNNU41NF3SPmEfAFiqpJr3mRj Eqef1r1Y/DzTH ER8JyyM0DLxL3DZzuH416OqbZMkDHXFTCIF84wM8ZFaRo0oqyRhXzzMcRb2lTZ3Wy1Plsfs/XKTN9n8QFFzwFUj tOPwH1gNlPEhTg8jdzX1P5ZI7cnj2p/kkLzkDvxWX1Wg/sncuJc1/nT S/yPn3wZ8Hrrw549t9budUF20IJARTliRjnNbOnfDOay O914rW7Q28rs/lYwwLDBFe27OoPU0gjwAOhx dbKjTikkjjq53j6s3OUtWrbLY ZdX B17ceMdQ1LTNXFv58zSLnIdSxJIyKoL8F/GCFiniXOTyfPevq5YxweM980oiUAggAfzqPq1KWrR1Q4kzSMFByTS7xTPltPhB47hiATxOwAGeLpxivXfh7oHjLQbie11/Vk1WxZcxEyFnRvTJ7V6ZtATpke9TKBvzjHpzWkMPTp6xOPE5xisXSdOqo2/wAKuTJyQencip9uZCMkkH8qjUAYOc tOB49uhNdKPmmSqw74HvUh44GBnuO9R55GDg/Wn45wOuOcGqFpYe2PmwOB2Apy/e3Dg5zUQAL jHipBgNuOM tAidPlIPOT0qdMZCgc 1QKRkgHPpT ozyD2FWkS2XI2xt5P0NWFIztHXPUdqpoTlTyDjNWYt2TjkjtWqINJMBQAeM9hzUrWtvcRoJo1kG4HBHeqiMMHce/enSJK4Yxy Su37xHANboFvvY3bSwsFwn2ZdgGAPTtzXaWKQpbBQu3I4AJ9K82tZ7kXGTdRDHJ2kcD3rrNPu5Q6I08bnOBgiuyDVzKcZvqen6VHbrJGXjwAQAM9QO1esaS8bRRkNvxznvXg nXx 17XnUoDwAenNeg6VqbRx7EnAbnLHjHvXXKLnCxxJyjO57GuPLXHTFOrDtNQMqL  jb5Rkg5FbSsGQHIP0NeJKEoOzPahNTWg6iijNZmgVn35HkY44PWrEsxjTJ2j1ya5DUNRlKS7Su8H8q6aNOU5XRy1qijGxga6VMRDZ3hxnFeeXkiuX3Nk9K6bVLyee/lDINhBwe59K5C6l/csSPmA5969SSsjyE9Tnr35pSMj61yWp2i3EZQyMgJX5hz0Oen4V1dycAgnoT FcnfSOkh8tN42HZx39K4JnZSve6OPfQdo2C9mROhGecYxis 70ESTLLHeyxyBVDEH7 ARz dbL312xKmzYc8ZNZb31ziTNqww2F nrXE1E9iMqvRmTJo06C52XkrO6uBlvuk9x9Koy6JM8X/AB/ynkHqe2OOvTj9a2JNUnKSEWUuc8ZXFUodUnd1EljIrEgMT05rnaVzoUqy1/yMVfDupectumqyfZ1G4sT8xbOf581dTSNQihdW1JpmJUqX9mz tXDqpW2R2spS7Lnbjnrj/wCvTDrG20Mj2swGT/Bk8HFZOKvcrnryVrL7kT6VYyafbyxyXL3OcbWc5wAP8c1rhtrKD2GcZrnRrMLSIgt5tzMAMx9M v505NcjkaP/AEeYEnoU5FIwdOpJ3aOkLd Mn1qVWyM9f6VzNvr1lPKmC5LnjKkZrSs7yK h82Ld5W7HzDGaV0YShOO6NUv8vTn2o3YUe56VAXyOO3egsdw2ggcYNCM pLu2x9OfX1qnLNAjkvKuOPvHoe1TlzhuSwHp3rnNZtLZ7N7mSCW4JwCkZIJ9KDopxUmkzXMkLOFDAt6etN/0d43AZXI685rhytirIzWl2rBeuSTjJ/rUHl2X2NhEl3aPuOSM5x7 3NYuTO9UPNnfLHFFGqxoiLjACjFN2RcoyqNw544PNcTJJYxWsSpPeNvQNHIjEnB461R83TJCBLc30YUZXcxwCKjmGsO3rd/ceheRascPHG2euUBzT0ihhnLRxJFI33iqgE1xTyWgtricajcsUIDAN8ydaz5rmBtjprl0VztbC/d9eTRzISoSlpf8GemBsDjnnNNLE5GcfQ1w8F7DGsif2w/3CoDJ0yODTDeRrECmvZI Xcy8H/Jqecx ryv/AMOd2vO5TxmnA5spooge371ytjczNfQqdUSZsjdGF5bjNdJ/Fzxg8g1pF8yOecOR2JPQHg0hxkDqM0mQcHJOPakOMYOQO1JmYydk8vaenfHOa87luNBn124urm0mjlSZlEpU4Yq2CR K16J93IzmqrQW8igmFCQcgbeh6/zrGabR3YeoqTu7/J2PMUl8LssRWOcRgDeNmVXuM/nz/8AWqzJbeHYrZELzFWTZvP8PJXPtgj9K77 z7HJBs4gc85QUNp1gy4ktYmGzbgxjp3FYOB6X1qPRv7zhY9F0J7tonvpVlmBJjc4I3DOPy7VsaZq iWGni2j1MXGXJ3uxYnqev4Vvyadp0l0J3tYmlwcOyjPII6/Q4/GoBo lqFMdmile2PeSrwqK02/wI31/SI0YnUIQUB3fNyMdasJq1gYjK9ynl88g/T/ABFU/wDhH9IKSItmmCck5NTHRNMWxMC2wEbcHbnnkH YFTaV7nO1hns3 Bct9Rs7md4raeOaRBkhGzir2SSCeh6 lY1ho9hpzmS0gMYIwTnNbBf5SRz7GldvRnPUUFL3NiQY2gjkYycUHnPRh14pqsADzhenJ605QACehPvTZldsafornicateHA/CoiRtJyeR0p7g7gpOPxqN/kyx5wOxqbX1Y1ucrfw64dRaa2kj8gJgQsM5PP8A9asR5PE0UwaS1jZMjlRyM ldO2tWi3Ko4YM5wp28Ek4xVYa/pj3bRCfa5OApUiodrnqQqVEvgv8AI5 3fxEbRzc2Cl85BXBJBPT8qGbWIrH95pcdzMXwwAA4Azn8en4V0D6tp0c2x7lQwODmmQatp8ssojuVbB2nNQ W5r7Sb15PzMY6lrEFrBH/AGSS7sQRHwqD1qAa9qqSmOXSJFAwOAeD9a3l1fTXI2Xkb xcUp1TTy24XEYAP3j0qOW/Ud01rT/Mzf7em 0WsTabOBKFJbbwhOev0xVIeLNsqI2nTpz83yYwMc100V7bvJ8kyOe GFTpKkgby2Dd oPek4dmYt0o7w/Er2F6L 2M4heFdxXEi4Oe5q/yNpxSgIE2ngDBOKeVUA4z1xk tNJnC7X0QiqN/PB9KeyDzBxjHWnjocDaexqNxhv7xHWm0SRTkKhdsKFHfsK851NLW512f7Rq8kABw8YbAGB25r0CdgkBzGXJ6rjNefXVzGzvcXmhMJJCcEdSO2aykrnq4W6bf X6lJorWFIfK17bGMfLu5fJ46Hp9Kk y3AhEcfiEBio2/OCfpTftWkPE0n9lyKQDt9yAenPWhZtDms5jJZSRJEhZmBI49vfmsXFtaHfJyS6/cjptLuI47QW8uoLdThiSQffpWyQHUk4z1yBXn8MOgQ63BCsM63COPLA6E9QD ddIniKweWQB3SNELO5HAX1/UfnUbOx59Wk a8U/uNplXarFsHt2qttXO7YC3c4/nWeviLS/IE5uQIg 0Eqevp lQrr kyySKl4qkAH5uP51as9zn9nV7M1vKDREBNwB/KlZQybsjcB2qmdUshtzdRbWA6uMnNSQ3VtM InWUjhthzTdlojKUZJaiOACMYPPGDUTKGXPQjrx1q0xUEEKAR1qtIOctjBHPNS2Y6nKx7t3c7ql ZCMYX0OOtQj723ODUzrhg2M vevpDzSzGq7ju6nuKmDEpweB0OKpjJIAyFPOQMVdCblAzj0oKvfQeu4jPbvipRxwMk8ZFRhiHO0kDoSRUgIwueRxk9c0E7E8RUdSWxnPHep1ADg9x1NVVIUZzjPIz29qmVtwJfAyeDSZd0W9x2A45z0FNbqp 7xzjvTP4eeSDUmPl YZH06UihjyYBAXr6UxMg8DA68U9 nqvtTXbCZIOeoBqrEWVwJbepzkdSKOBHuOF najICkMAR2NKSBhcDOecCmD1GgMQGx92pM/KPk4703OCMNjnvSc4IxgZrRIzt2HngehzxmnMcgAYA9qTqwPReOfSmgAtkHitVYCZehzn3yacpAGM5B796TOeBxx dNXhSOmKrQNicHPygn8RT9wJOeuPwqMkdSOmOtPAXJC9xzR5gtx 4lQDwDQQRx1PTmmDCfL hqXIwxHJHTml6AOVTtBHDg9M09ASCT6YIz1qIOcj175pQxLEqeAeaqzBMmVd0pHAA980FRtIPp6cUinBI7k9TTiMIMjIHQE9KBbCY QZwM9SakXavHO3PGaaCD2 bvUi5PBAIppBcftGDkBffvQCMdN2OlLtxxkdeRjrQMlieB6cdKuw7kmAF6E/1p2CcnnOOhpF5BBzn6ZxSs20joeOTmkxjwM4BAHOD3qQNhm5JH0qMHJyp4/MUuRnPQkcmlqhXY8E5OefTJzU2AXJzjJqADK8HHFSg8Y456GnbuCY8McntUm/0 Y0wAlQeRSnPzYBx9KroJkwOCpAxz3qXOGGD34xVZQAoPTPtUpBKg5x9KNREmQc p9qepGRlsA0wHaDjgY9KFOcZO4 tVbUC0OgOMZ4wKehxwceuTVdT0NSI4BbqF9TV2B6l1SSrbTx6etWEkIVSTleOlVI8lc9ulTrwq7sY9KtbmTTNBW6cA/WpXYfYn2L5jqMhT3NU1fAY7hRNcRbPIaYxO68N6cda2QtWx9uSYSDpyhGHzKT6Vu6cUjmTfp/lgYIYHpgVzCS2Yt8fb8EA5YNzmtq0ktWtSEvjJ83J35xxW8HqayvY7a1aOOeQxWpByG3A9ea7GzmVZFkMTZKdB69f515raTQiFNt8VUjKtu4Cmussb2KJExdeZ2O416EJWaOKa0PUtM1NYZAUhJwAeCeRXY2mqgLtWJwmOM9xxXkVrq8QIHmr2BOeldBDq8ahgZMHqea2nGNTc5FJw2PU11aIx5WJse3Y1FLqkQkbbE5PRm lcGNZjYfLJtwe5qKXV1CNlxzznNcyw0NzX6xN6HQXmqxLK58th8pJIPAHeuSvb4OZPldcMQSDnvUM2ooxBSQc9getY89yCPlbBx1BreyjojLmb3IJr8tMUKsuBgHtWLczjbweCcetSXE ATnisWeRtrHdn61zNstWeiKVxMvzLk7QM1g3rg28p3bU2nJHYVbmlB3c9axbtm yyKrhZNvBNcM3c66a1ORuJI/3u3UZVPfAzis0XEEFrKGvpSdpI3AnAHeta6hv2gQAwh9 WJHUVWaO6WdlkjhMW3AwBkCuJs9qMlaxjGYIJd99Juw3BXI6EcfQishrlfs/lRazIjebw5XdkdcfTmtyaPUWslZYrd5iCGyOB1xVJ476MECwt3KgZwAM1izpjJW/wCGM7yrwEsviBnDkogaMfePC/kahCXS6ipbxBl2YbY2QAHmtUR3vlQsbKAMAWcDsQOMfpSbbkyh30 IlRkOCMjA4xWbjcftPT8Cgn24wzn 24ShlPltsHGc4H5n9KlR7uIlZNahllKqTkDj6D34qwkd0zESafEoB3IRjjpj tU2tLtpFabTYJWwd7DjJHT VTy2Gmnvb8Cz9omFmzjUYAxYKrjGPXGane8uIo4oje24kbAPP3s96oSQ3YVUh0mN1O1mweAf8RWnbWVvMTJc2CQyfdwTnIxj VFmZy5Fq/0CG6vZdUiVL62eMHLIvUrXT7mY5659qy4NOsoJw0UAiYf3TWgHPljsO9JJ9TjqOLasPOQORn61lalMIrND9oFsC4AZl4 laTE7Tzx355rmb69uGRwunG6RZdoDDkr60NaFU03LQzDdBtytrgfzlwjBcY54NJuujEwXVoZmDANuX5eeP8asvNGLPe2i5YOV2hM8Z7cUkM0UhMTaQ0eMnGwY68VhZN7npc1lovyITdTtYsY9VtkhCgByAoRsjA/EZpjXNxJFKItVs3dl6hhlfenyy2J0g dojFFfLRCHPIHXFV3t9JWJydDK5bb8kWCQVGen5VLjYqLS1a/IbFLOblol1Gxebf8AOnGT9f5VZZblhcmKa0MW7EfA4Oeh/AVCLXQobiKT yJFYgFW2njdzzz71Shi8PyJMjafOkbMSQ2QMcY nT9Ki11obNp6pP7l/mbNvFf TIStpcN0TAHH1p0lhfNKxksrZsIwTA4J7cU20m0rTZkjtIJITcEEjB69s1pNrlkudzOAuc/KeMVSjc4ZSnze6jMW31JZklWwt0dASoTjk1pC51jzV/0EFW64fpQ2u2CSEO5jO7GSpwf84NbEbGSFHHRhuGe461ajYwqSlvKI8ElMHg4oILYyeM maQcnj8OaVsZPGADwMUmcxUuoDc2DQFzGSBhlOMHtXBzanpFprEqNqtxE8chDx7Dgkdeceg/SvRCxIGAOO1chMLprhxBd2rjfxvwT15FctS/Q9LCSV2nt/Xkznn1PTItpGvzkS7SAAT1PWrkOpQTSQ XrrEyNmIsMEjtmp0S/UkO9g DkYAH0FSmCQwAyW1kZRhoiFGPesbM9duna3 X RXlv0n1IpD4gRXeUGNAOxxgf/XqZrm7eAeXrkLKpG5tmam z3Ac7bSyUhRuKAZB tBjult1RLG3xs ZFI654H5VOxj7j0X6Ci7laR5INWiMbjgMBwcD/AOvTrfULkRlW1G2lYMuSD1HfH6VT2TzQ7F0m3dD1CsOakgt2S5jjl0aNFDD5g/TnOaLslwp22/Itm91MHclzaPgjKlv1qS0vNSNyguZ7R4d37xkk5/z0rJewMl9L/wASUmE52ZmwKkOnwo6zpo7M/wDFhjkY6f5FS0Jxpctv8v8AM7gErFnPXpxTslcZOCeCayrW mnlRHspYBj5mYcA lanGMNwM9c1UddzyJRcZWYx24HcnkfSo3HGG5Pc1PjcCT3qBlG4dj9K0ehSON1htTXUyllNYxQjBUTD5ie5/lWM51ySAJENONyc5YAd la9/bs2pzyvpH2kklVcNyRj9Kr29r 9Vk0l4GUgbg3asZLmWh7dOSjTW34f5mZINYjhUPDYTy YN/III/GpTHqgmUx6XaJHuG7DDjBpr2cBlAXR7g7ejAkd6ka2jWPyRp9z9nYgnDcZxwP1rF6PU1vpp/X4gtu8tyc6RbiM9SGAJqpLBN5cMY0RHVTuUB AepNPa3s4ZOLO8L5JxzgmtKw063ugs0L3MLRnpIx579DQtWU5KCu/6/EzYYF3ODpGweX/AHiMnHSr9ldy2cflx6W8SM3Y5xWgNBQNIVu51Lnccuc0xNDlS7SVdRl4bOG6Hvg 1OzRyOrSle7/ADJE1n5499jMoYfN8v3cetSHW4UTcbWcY7eUfzqH yLkSs0d/IQCcA 9LFpt lx5g1A4/iDLxUvmRhy0H1OhSUNAsoUknnB6il6Nk8569qpWUM9vZ XNcGVi2d5GPpVpuUYYz6YqlqjhaSehWmlREBdhHzj5j1qs9xbvys0bJ/eyMGpr2GOe1HmrnHK471xDW1shaQ6U6OeCB VDTO6jBTW51xkh5bzF4z3pv jkHITB7cYxXFi3t5po1ktbiFT/ABbuBxjmmLDZQfKIbtQOVJNYt2On2C7/ANfedv5EBfcUXnodoH61Va0s1idPs0QyMN8gGRXKS3ELXJZ7m7QKoyq5xx7VBvjDLt1C7yF3bWzjA9awfNuCw877nVy6Zp7LGr20T5O5QUHB9aoNomkSFT9iRmU9hisGW9imvN/9qTxMT8sYQgLxUltK1u4kbWGlUnJVkximpOKuX7GpFX5vzNx9E0p3iZrdWMeAg3H5ccdM 1TWWnWmnvKLRNpc5bJ 9XNrdXUuJE1iJepyyY/OtHTrm4OotHPqEV0QuQFGDnrn3GKLvqc9WNVRs5fmdENoDcb2zk tVJSzEgHgdBVkZK5zg/XgVVlOQQPxI71LepwLQ5pSDgscL1JxT1J8sgZC46UxQQoBwfenqoWTIwDjk19OtjzbKxKMtEDnBHoaenQv1OevamDJXaeSOKnT5W2H5hnqe9IkmiZjjJJz2qQYPC8D 971GCSnTge1ODNsYAY74oEP6BQ/Kg8/WpUdwxG4be1RlznvQpy4I6E80gLivmQL36Gph98kdjg81VBw2SckCpVYk7iO3X1osjRbExKhTg9OmfWo89s8 tOLgsGAw1Rq2EI5wAQCTS2AQZBO7qOgoLMUK859PSghQ/ByeM0KcRnB5PWrRAAAgLu/HFSAEOCckE5pmVYErgntTjliGwPp7VaYmBOSVxyelGBGuMZpBgMpzgYHendG4IPHT0rZWJEJG0gfTinDAAA5/GmspoogeuMDGMg0A5UDbxiqSHe5YUMowOCfbikBA 8wx3pu85APHbg9TSgnJULuP8AFjtTsJuxIx3MT6n1pwKgbjnOODmoA7IScU/sq8HPOB2qkibkytwMt Rp 4AgdfQVAAWkILbQDTwRkdgOueaoLk6su7IGcH161ICDnPHY89KrgsJCe5z1pSTnBHftU2QFlCN2DyAccHrT1OdxI gNVgQ2MKSalDAAZ5p2sMl3DDHBOelTbgV4xyOvpVZWyynbjHBzT0IAwOuKeoFlGzHkdCetP46ZwM4AxVZScKCeDTyAwyM4HUUbD0J8jB6bTSgFY oPvVcEhRnOT2qTJZsE555ING4EpbBGB GeamDrkEevWoQ3GMHB7mkBLv8AezzxgUWAsBgQeM9 aUMQQPuiouR2x7inhhtBPI9qEriLAHzjIGOh4607gkheR61ANu484IqdT8nJwadrATKfmA6Y7etJuBYEcfjUaOShwNuelKCS AcE 3NVEdyfPy5JFSJjIGc56VApKqOcn0GakU45JOR39a0I63LakKAM4/GplcFweSMcGqW48dvQZqdCcYwc vpQJl5SNh3H5vanrDbvJ5rrubGMn09P1qorgAHpz1HapFlAfaO9aonVO6LiWVmYtht0wc87a0ra3tIotiwhVIwcDn2rMjm XqQvfmrsU DhhzmtoOxLlJrc2oorYxqBECV6ADpW3AlttIMYLdPpXMJMobaD34Nakd1tTKt25rqjK5g3I6yBbfcT5YwepzWqjRMS5jycYNcbBfYl UY9ccVpRXecDf171umc7budMrwgAhNpHI amERbWUjGeTzWKl0oTa3A459KY12GXk7eMkZrfnsRqaTNCGEgwrAg5zUclwfNI3CsmS7Axg/Ke1Umu GwwzmsJMN3qWrifEpBbKjjmsqWUu5 bAPvUctx3J5649azpJi TxyeTXNKRso2HO2XwT tYV7bR3Eg3OQcumKcVekds81RlkIY7TuI/CuSWp2QbWxhS6RDncLiY9vv9ahl05TeyzJcSASLjAb7uK15WDZBOAP0qmz7eO49a52kdanPuYraaQJR9qmBcc/N0PXNQtpmLwzrdS7zgHLdeMVuFlyMc9jzUDlt/BAA4xWTSNPaT7mK2mXHlyBL6VSzbi2enHb9KYdLuSJT9vlAYFcenFbYIK4YkD6UHiLIP6VNhe1mtjHTTrxLaVVvWJIwCwzt lV10 8Vomkv3LgHcAODXQqw3gkfUU0Z6Y/SpaTL9rP kc0 mak8DL/ajKNoGdnPv/8ArqaOx1QNk6hlmyeUGOnH4dK3eNuOmOlAPygAj0xUONyvayas7fchVLKgyR0qXdwRkHjGaiG0jsB2oBwMHB98dKdrHPceTiIgL68iqN3ayXKIEnkgIPOw8t7Vc3YOCcf1phO4cN3pWuUm07mAdJuMuDqU7A9ielRW j3UU7yy6jI43DC wHFdAT8uc89hSAnHGc96XKjf2s7FCytJoLiWSS6NwZGJ2sOFz6VqYGD657UxQfL44Un05qZfm45z2xRYzcnJ3Y0IoUsq/N6EUjAMOeg68VIvI5IOOozQCAWxx75paMTbREUG4HbnHTNBijIJZRyOPl71Ng9cc9scUjYU84Htms9jPmZWNtDyWiVsnutTKemRx2FOIO4Y9OQKaw TJBP1qg5mxd3JPU 5zUeMjjBpc7QBnNKOT8o471my0Z91efZXiQoZC56j0rlo5NMMAebSJYd5w3yk59jXc7NxUnBIHemlPmJKjngYrBq53UqigtvxOLgTR2u1VbGYO0mcshABznNJM2jrHE88EytsG3gnaOors CM4wO3vSeWO65x0qHE6PrGvX7zjLc6E8LZSVA67sPkHpk0x5tEfUHRXmQSOWLKDjdj1rtjBCcExoSM4yOlIYIvMB8tQv8Au1lytD sRvfX7ziQmhRTyRm4mhdQUwCakKaUNUlma6mjm3YO4nHXGAK65rS2LljboW9dgoezgcZkhV8 qik4XNPbxb6/eZkGs6ZJjF0rc4HHWrsV5bXDkQSiUr1C84p39n2QUYtIuBgYjHSpYbaCI5jhVCRzgYzRaRySlT zclGBwOcetLgc929aNue2M lKMCPI496rTY59eoxvmUZ9OM1n3sMs8CxxSGE55I64rQKnfx17VG2CGJ579KzeuhcZcrObGm6gJZWGouQWJRWXIHtT1stTUEG/Vt3Q7MEcVvdS2B9MUBsbcgj1x3qeh1e2k 33HMrZarGr4vUfjAGzHPr/ADqB7TXSSovIthXGSldVjI4GSe3rUbJtIIHHPFRZh7eS6L7jmTHr0VsH/czuAflHAolGt VGqJCcjls966TJVPl/DNNHKqR2HUUrWGq7fRGE39sJGGW3iLgcjdwTVYXOuRja9lH0xw9dNx5gJ6jtSHaxBJ tBPtV/KijZPNJEDcxGGXqVzmri8gYwo9KQKSRwcds0v3RtJ/KkYc1xrEFwB90UjFW24PTrRnDHOCPWmlvmJK8Zx14pO6GkUr6RYbCTeWVcYG3qK4a5eFcs2oXSMzEZAyc/wCFdFqMupJO7RGJIBjb5rYz61RS51Ig ZFAygnBDdfas220enRvCN0Ys91aQQoZdWuIw6bgrIScDv0qKLV7WG3eT 2Q4bIyylcH2rX8/UHv1D2sDQbRnB71EZJmUGTSo3Jb5CNp461i/eZ3pq2q/Ff5GYupiWwEkerqp3csy4zx0xVp7kqix/2pbNOzYw2PyxTt7ywjzNDRDn5UIHPpUypDiJxoK bndkIMg0nd7jbilovyF was0iuZIMNxnyqlktNQAYxpAQSdikY47U59anjcKNLn2 u3OKc ttHHlrG5BIyB5fNQ1F7I5JOs1sik1lqW0xtYWgXGcqvU/Slhg1C3nRxp0O7nJQ4Iq3LrVugR5YZlUqGY7OlS22r299di3hV mSWQgcfWjQzbmo6x0NBWOxN3yHGWHuaryKSHYEqCfTjFWt2Mt146YqhKW8luCA3SptZHnOxzoK49MD64qYBeowc/wAVRRKAx XFWAjbx2TORn2r6SYKSWzkMPrU2T5ZDDpwcGok2 cQTgfpUoGZDzwehoC5MpxtySSR1zSgl8kH2qIseOCRjinhv4VGD2GKQyQEbxvx NPDNuOAevYUxARt4IPtTlI65IGeadhEwAVhz1H5VMrEQ5HNQDATn73bNPjwDknnHPGKLFIlaQbQWHGPxpwYYGMbc1GuTwR8v5U7jGBnOOOKLFEh Vske5xSZwuAcHoMHrSrkKcnnpj1oYkEA/MT3NaJCeiG8leB1HQU5cnhePl6UhChAMgc8DvTuFGdpH44zVamewmcg4HbpjkUhxuwV4zzzwKcTgE54/nTc7txz FWrDYbS0h9B6U5WJ46AdzzTeMNjn0OaCDjKjcvrVrQkkIwflPPofSgk45 XPpTF2kleME9 1POMjdz261oGg4gl1HXNPwARtPI7 hqPI49jwc0ucOAV6c lNGbJlLD Lg9acQVfGCTnHIqEY2KQcj I9MU7duOQec96egWJs5cB ORg96cS27vjtURJGTjJ7cUZBQkHHtSHdEgYbuOg9DUikiUjOee3aoiDgDBzj1pyjJJJyD1z3o1EmyyS2OuOfWjJxlcj2quW3JyOfXGakEg2Aucj86eoMsK 2MArn69qk3EEAkkCq 4lVPIzUiuDyxBB70a2C5ICTngsM9utSBwSMYJ6YqBXIYgY/KnA5JXPHUmqSKTLGQCR HNOCqARnAHeoeu056dMily27IOVzRZkFgMSeD VSLnaOR1quCD8uRmnhjyOnv0qkrAT4GR/OpQ4z1xg1WDDaOeKUEc84Oaody0rqBzx lLnJ7A56mq4OFAxnPAqQsxBI5Y9aVhk45fvt65FSbuCcZyKrA5GSSAPenZJcZOB7mqE2XBIPlyeB0NP8xuCCATxzVRZDkpShsPxnOOmaESWxJgtjjFV5dQtoG/fXCRuegZgCajdzsOcmvmL46SMnirRsMVzbN09d1Kc/ZxuezluC v4pUHLlv1Pp5dXssEi7j56HzBVyPVbUMoW6iBPI/eCvz5hmtwGZp3UdipOcepqeSePyQ0cz793HzdawVd9j7V8KRvb2v4f8E/QtdZteQLmMsvH3xV6PVbZowBcIW/36/OqK9n25ErnB/vGtKO/ucriaQL/ALxrojXfYxnwl/09/D/gn6KwakhIUSjJOAQa1orsjo3fnNfCXgLUbhfiloge4fDXA4LnB4NfZsF15mCZAcc8mu6nU50fFZpln9m1VDm5r R1a3g2BS27A70jXZ2sqscckjFYC3S7gu4Yx1zQbpGcAtuz710XR87y3ZryT4KgEsO TUUk ZBgEDv7VktcpvPzYGeaYZ ScdT61nKXYvlNCScbhg9apvJ8hAbB9e1VzPlcLzj3qu8oEYbHFczZvGJJJJtBI4IqjNcBTtyPx7VHNMdxJ64718kfFHxDrFn8Z5ra11K6tbQRRnZFIVHPfFcdWp7NXPoMry6WY1/ZQdtL6n1ZJcgkneOuOtVzc9TnFfDE2va Rvj8T3Sn/r6b/GoX17xOlwir4qu2OMsPtLdfzrh tJ7I x/1TrWuqsfuZ9zm6UAHp9aZ9oJ69frXwBeeNfFlrdvGviS8kIPB84kVVT4i NPLGNfusDr 8zmsXio32OpcGY2SuqkfxP0NE3PXGOfrTwwyM8nsfWvlr4LeLvEeveOtSttW1KW9t47XciSHhTu619PK 4kEj lddOaqRuj4fMcBUy3EuhUabXYtcndg5GOBSEnhu/0qIHAGSA2OgpN2QCe3cVozyNSYN85Oe1NXacHg5NIGHBJ5pm85549eKQh6kAdQKUthOuCeODURY845FLn5MN/OkVYViACGJPp3qLzVHfj3NY2vXslh4Q1W jxvtrSSVQemVUkfyr49t/jX4 uIGZBZsAcYMWOcZ9a5KteFJ2Z9Fl2T4vM4ylRt7u93Y 1WlPljk4FOWfcmATjpXxQPjT8QkQP9lsyrDdjy xGR39KsxfGnx8Nxaws2xkkbSDgHGetc31une2p7r4TzRL7P/gSPtNJMyYB5HSpVbLZ79 a dfhV8TNe8Z NtQ03VLS3toraEsTEDnduxX0JGx3ds9z6V2QqKpG6PlMbga ArujW0kuzuW0b92RTSSRjkjHXNNBPlkjkYwBigt 9Dbsk8YNWzzbMl68 3rSHGNxI3d6YW5Hc0pYAHtjofWpFa47cyjpxn72etNyDJjJJB4pCTsJIHrxTS3Oc8mmOw9j8xbIz60hkb1z9aaHAHcDvnpUZdV3Z4/GsZMpIl8wjOeDTPOBGO5PavEfE3xq0Xwz48u9Bn0 5up4ANzRAY5GeB9KwV/aE8Ns286ZfKFba2EB59K4pV6admz6ilkWbVqaqQotxex9F7wTkck0u7cp7geh4r54T9oPwj/FDeoc8qYwcfrXceD/if4f8a6tNZaUbgyxR7382PaMZx61Ea9OTsmRXybM8NTdSrSkkutj1JRwOc5pSeijqO9Qq3IOSOlSMVAwOcHua26nhiqSTk84pQdwGTgdKTdheBwR1zSMTkMDyOBzSZJIOmQePUGowx5A6ZpAcDGcZ7Z6U3/lrxzk80DJCMoo56d6bzsOAAPelZj1z NDEnqcew71DYEYPJyeM80xsnOfyx0prsQN2MEHvWDf JtEsL9rW91e0trhcboXuFVh BNQ5Jbm9OnKekVdm7kbiMjpyBTSQGHYdu2RXLf8ACV6DIN0etWbfS5X/ABq2mvaa20rf27DHQTD/ABrPnhfc2eHrR3i/uN1mydxP1pCcgHp FUIr22mPyzRzd/lYGrpK8beTj8au6epzyi0xrAFCfbBpFwHGV2nPWncj35pCcg7uueah7khwYzkAHPBqspoogeDK4NPYsMgDj1FRAZUnOR2zSDckOM5HBAHSo8lfr3GKcNuQGOWz1zTccE /U0h2EIwpHO4dqYVwFz8wJoBABUHj1qJmVdpZs46fWkykrlO/s7e8CrOhkRTkY6ZrNbRLCSR/kxk5J3Y5NajyKCM85Pp0qLz03ddxHtUtROqEpxWjMdvD9jvYqH2nggvxil/sGz3R WZAsf3RvNa3nKGO49DxThMNob8uay90t1a3cxf7BjJVvtU67OARJWra2v2WDZ5jSMP4m6mplf94NxzketSFSVBIORzwcUKzM51JvdkbKNnGRk5HrTZADNknIYdhUgyzDnIx61Hw7YA5HYUmrmPMyNogyjgMKG8sMo4BB7HpUhBDBVY4B7Ux2B3bcqCMdOtTbQnVlZ1JQ/MD9eKzZztBbBbuBV Undzz9aoXI220jMMkZwM8dawm0osaSuc eGxjJz24q0pAJPRcVAAftCgHgj0zTz8q553Do2K oseYSgjeApBP1qVM5Bycgc8VAFXuMHvz1qRciTBJx0BxmlYnqWs7otpHHYE00NsAO3GevGCaZu2A7mJ7g05julDdOB1700irokDEZwMADpmpAMJuAxxwAM1Bv UBhzgYqXkrkZznOM1soobHknGMDd708EhcqOO arcqSuTntmpctuw/PHIBrNolXJRyACuD2JPSpQAcgcH69ahPMYwOR70qviQYOPoKRVycMf8 lO3AhQCRUQICMM9 h6U49geT71onYLjs/Mc56elPJKwkMxx1PNRkgHK9/0oBz05Ppik3clj8jYMEAD0puR5RB69cnpTdueTkA044Y4JwTjAwOlUhdAP qHPb1zSh BtGMnPBphwG4PGfWlzuzxkZxgdquwthwwPmK5P0qbgq2e38VRKMKMdM lAySMjhvwzWomPwoKtu6ntTl ViU5zSbv3gKnoKXJ5wBz2FUQSnGAcjA7UZU46AHqRUROSCMCn5PPzd aXUrRj95PC8D19KdnaOuKjBXrzn0ApSfl6cHrk09jO1h24565HXmpFYFMkge KhA YEkEHpinbggbIOOtW9h3LBbdgrznk5pAFVlySwzzUO9tvTcpen 15s5p6A7GU8nrjNSBZ3ADCjJ7UqNkjPBqJcAA8EA4FIWO445wfWqQupZHqBx0BoH3s9/T1qEN8o4xj0qTccjNWMmBIUHnpUm7AXHyntmoQcrjgY4pwkO7JGSeKQD1JMfPbuKnVv3YOeo5qtkeYDnB9M1MCQpOR6CmA8g5JzjnBJp4c7cHJx2NQh8puppies59M8Cl3qW4JI9aBFgH5Dxx7d6kDkg4yfU5qoHVZQCSMjrT94D46j1xVoXUs7xzg9fSngnoR7j3qqpPm4xkHvU25vmOevQUXHqSqwLjGQw5BqQHGc8Edeaq7gw56d6N52knt6UwJmJK/Lx2rH1HSdM1N1a/soL1kGEM0QYj6ZrT3Ar1OapvIizqGYhyPkG7r FJq5rTk4u8XY59PDnhaQ7k0iwYYBBWFenalXwx4aEgP9i2I5yB5K1y8zaGmpK/m3Efz8xheQxcDH4HjFXIj4eRoZU1CWRUZZBySDt g6f1rJW6o9vnr20nL8f8zfHhfwqoIbSLJC7YwY1GT6VMnhjwsZC39k2W1PvHyxxXO XoV273P29wjTsoweN3PT/vrrTimheUyHUnieVeoJGAQPyHStfd7GbqYi2lSX4/5nZ2vhrw7b3SSx6VbQyI2UkVcMD7Guijgsyx2qQw5/1pzj8681uZNMF1LcyalMwkGAseQV XGcevetG2/sy3h3PeOiz8/OxBYK2T9OmPpxWiehyVI1J6yk3956DGlluYA9OCBM3H607ybEsMEggdBM3 NeZW76XPFIsGtTjzECiTP3cDGQfU4zXRJpQljMg1CXEgJypxwTkYq a5zzp8r1l B1Qgtnf PHciVun51L9mtw2A8g/7atz tZtqDBZLEZGfaTgsecE5x uKsLI27v8AX1qWzmu0yXyIguPMkJ/66t/jTwwQKgJOOhJyarNJ82QeKaHycsMgjkg1O7BPQmmfeo6DHrXB634J8N65q0l9qNgJ7plCtIXI4A4HWuzdvk65H16VialtOm3Iln8pGXG8fwHsfzxWMknuduHq1aM anJxfdHn0nws8GOSF0xuRx  aqcnwn8HEhfsLr7idq0hgXDQLr3lgsSil8b8YLH8wT NS2tt9mlVj4gWZUErfM4z82Tng9utczjT7H0SxuPS/jy 9nOyfCDwS55spScckzHpUQ DXgsy82k4UdczGukksbo3BlHiBQjQjywW5Oc4J59x VNS21BYAT4hjYhQMrggHbgEj681lyU/5S1mWYrbES 9jdA HmheGdSlu9Ge4tJ5UCO3mhsjOcciu2jsZDEANSuM gK/4VydrLNLp9wYddjlJkVlkwBtULz198H/APXTUsNVME5TXVZ3cvuz91hgA/TK9PerSS2R5taVXETc607vu7nZfZbgMSuoysw4PC/4U5rS628ajJ17oprlbmHU44J1bXUhjIfDEjcAQ2PyGPyrsYHUWiKrbgqheuenHWi6ZwzXIr3uQi1vN/OoE/8AbIc04216Fx/aGSf mI/xq2jllBAxQSSTjrinZGHM2U0tr4XS51AOoPIEQGf1q 0nXnkcU3JBwSKacED096LA3cydYsTqfh3UNNeQxJc27wlxztDKR/WvnlvgDZxfNFr9xGAcg WBz619KTE W23bux8u7pmuIvG8QJr1ybeWGSAyDy0dsbVwM8fnXPOnTnrJXPcy7H43CXjh58t99jxxfgU8MpdPEkrsRgs0QOO3HNQn4E3hDbfFMhVxyDF/9evXrW71260m5kmhSMqBsbIBJ3YYe3GaZHceKI5trW8MxAGVDgE1zuhR6I gjnecp/xV90f8jmPAXwyvPA v3uoQapFfyXMQRhLHjoc9q9eSTWAODa5x6niuPt5vFMcYeWBHfJ QEY6DH5nNaFlq2u/8JDbWt3p3kwzN8zKc7VC o98fnWkVGCsjxMXUxOLqOrWkpS R00cusE8pbH/gTc1IX1beuILc4PP7wirIkGAB196kUjgk 5rWx4fN5FVZ9T7W0R5x/ren6UGfVVziziI7fvv/AK1aAYbTgdOc0o5UEnJPJoYrrsZ4udTwM2CH6T//AFqY9xqYziwU88/vh/hWsfvE9aYBwM5Pr7VNmluF12I4Wklt1aSPyyeqbs4/GkkRiF5JzUvToBjtntTWwcY6j8qmwlufHfjv4XeNdV MOs65ptpFJBNJmJmlXps29DXM/wDCtPiMsCKNHikbduyJRnOeua wNa1a4sJoRBp0lyrcttX0OP6isOfxUscExXTp5Z0jLKAv3yMggfiMV5s8PTb63P1DB8R5pTw8acIRaSsv6ufHc/wi IEt00j6E24gfdkTGAMetey/BXwh4g8IeJtUvNc0me3jkgVIWGGBOcnIBr2xfEtibWaV4ZVWPbu Tuy7gB HH1psPjCwa4lWSCYFWO0BckgDJJ/z2rGNCjCSl1HjuI80x Glh6lNcr3tf/M6RdXi3fNa3WO2bdjj9KkXVoAc Rc/jbPx lYEni6wikCiGbzfM2bSmCD0x9c8V16sTbhuMkDI61177M AnFw KNig2t2g3fJPu6H/AEaT/Cga1ZlufOHOP Pd f0rSLLtGMnjjI4pm7DAAZ54xTexhen2KP8AbFiM4kZT6GJh/Sj 19N2HFyi7RzwcVcBXeDgn3pRy AM1nyth7hWGtacUG28iVuM7mA/nVxJEliEscgdGPDKeDSA5J46 1PBzhc4xTUWQ XoiCToQzBQOo6Yr89fiO/2z9oHxHdXMUkkIuSigA4O0bR/Kv0MkUiPpn68VyeoXWiRaiLe7EKTMpcgoMEZx1rnrUlUha59fkGZ/wBlVpVPZ87atvb9D85nisIxtVJxnnoePalSLT2cf6TNGgbIwDlhX6Dzf8Iu7kPHYPg4JZEIz/kVA1p4QEZElpprZGf9VGf6V5n1Vdz9B/1xg1rQl9//AAD54/Z/Rz8SNbuWmc26Wyom9iRy3/1q vElUE5YY6cmuV/szwvZsxFhZWr8ZKQqp9ulW3stERTJ5MaLgnIYjH613U4 zjyo/Ns0xcMyxbrqLjfodEGTcRuXA/UUhcMu4EHHXFYqWGkMjFB0XJIuG4GPr6Uo0vTlQlWmAPXF1J/8VWx4XLG 7 42t4LFQePSgnqByvYVipptoI1AkuFboB9pf/Hmn/2XEvHnXG7H/Pds0r9iLRT3NMldpJI lBILY6g 3Ws0aYvI 2XK47ebn lSR2LRSLL9qnkVeQGIIP6UdBWXctyDYCAefTHSuB8f65N4c Fes6pauFuYo8RMVyAxOP613rHOeDtHauS8U HLTxN4Xm0m/aWO2lIL UcE45xUvY68JKjDERlW G vofH0PxW IUtnFcR30EiO2ADEKevxf IS5Oy2JXqwi/8Ar17BJ8DfD6RbINVvI0AwFDAgVnz/AAP0yWQKms3cbDoMDFeY6Ndvf8T9djmXC8tPZL/wFnl8nxw8cWuzz7e0B642Hn9amh/aB8T VmSwtHOc5GRXa3XwEsLhFzrtxuHABjBxVb/hnu1B XW2x0z5NT7Kqlub/WuD50/gV/Rn0B4P1e61r4f6Xqt4ixXNzCJGQDhc9MV1ZOQQOT3964/R9O1LSdDtNPglgaO3hWNSwYcAYrXWTVvS2ZsjhWPSuyN0tT8hxEacq0nTty30NgFQRuP1oHDFfyrI8zV1ZQIIGwe7kf0oE rZw9pGSeh87g/pTcl1OJwa6o1CQWz0bqPrioiOCG bB571ltcalkq2nhvUiYHH6Uw3mo Y2dOOM4yJBU810TysvyMC A2FHUEVkagxNrnPJbrWk2fLjVzhtuSO4rC1KT/VRA 5rkru0GwitTPBwflBAJ4J5qwoHlfNyO461AjYTII3D165qwhwBnuePSvrFdHkajhlnHPzfnTlJcKMAn VRA7DgfdPQVJuO5fm6dQO1VdDJmwQoU4I5xSrjBB7Dv2pgcqMg55707liCCFwOcmncGHAOcHI6Ad6XJOCq5BHpTVccDOCPXvTzgSgDjB5zxTuwdyXk5bGCPUU7JEYLEH1qHjJ79/Snqfn57c8VotVqMkQrjPYDoTTgSARt4P40xTlN2SPbPWlDFAf5GlZCJAdyEdB9al34AB6DkVXDFGAGOmafuBUleuOtNxQrWJOMYbr2FAfG7sOwFMwpiDZzxSbeR2Pr0qbB0LDMeuM9enpTc5wSvbqTSdtu3A9zTkzkbhk9yavUBRjk8Yz0pTyCA3zcZzUZXnIOQD dOz 8PbB71QMkXAUY bHrTh93JPfpmmBsOcDI6fSnqQehyKtEjhgPn HGacHJVgSCccEmmBeQecHkCkBwh46e9Uri3F/h5GD060u8FSeSfekHrj6UpX59wYUxNDgwMZLAjsSKdklAMkD60wjgd2xxTh9zPQ45zTsSJuO0KOoOacCCcH8femgtj5vTrRnL vTv1rToBNllwcYyPSpBkjuOe1QA4IB 6R69KUEspbJWs7CuiwWK5zihGDMCRURIDAY/GnBjv54FWkMm3dycn2pd 0DIOR69agz8uCOM8c1Ln5QS3PpVpXYtiYPgkgkZPanq5wWyAKqfwk9z FSCQHHGAOlBJZDbX46n3p4Y7OM4qruwMDCnHBpw3EMWXj1q7IN2Wt2GXOOKcwHJB461XU5OV559f0pdxKkcYI lJIrYn3AEBRz6DtSll5PBycCoN2JPb VKzA9sc4FMTZa3tkY5x1IpSxKg89PWqofIz1I6e1LvAAwRntjrQlYGW8gKNwIP160F90ZA4NVRIQ27BCnpzS7iSSeOPXrV2ETF QQMD3HWq0kpEoIGDzzjgUPIwBIGBjvVaRmMw2sB1z70i0cdELubWC15pERR2cZ2ZBGSct7naKqNqNxuuGg8P8AlxlARvi56Hg4HqBTJv7XTWLiOy1SGVWlbETSAsn5 npUsa6/5kcrajbuH 6y8qfm7fhmsbHuR5bXdvvZMt8zXFnEdCPli55Ij UZPLEfrUj39obtpf7DL TI6K6pkNtyM/8Ajv8AKo/ J4IrVzdwmcJtlBxtJz1/Ko4R4hEAElzbLJn51XkL7mqsZuUHtZfNj/7Sj3yPFoYKhsKTGcnjOenrWs pWsUiwSaSZI4BlSqcDjdx IrBkHiVpi63FvGmPlXr1xn8uanB1 NQZJrcp5gLMW5CBsn9K0SZEnB9V97LsOqWhfI0Z0g8sZUKQy5xx Ge3pXQJ4iZbO1H2OULLHkKoxs YLikhkjYqy7SpGeKkNxH5hyVXHAXPWrUThnUi3rH8Rn/AAla8A2suTg42k8fLz/49 lXbXxHDdXMCLbyoZWwMr0wM5 lQeenLAj1HtU6TqSGG3J9KXKQ502tI/ib/nfOMNjjmniTd83PT86x1lPJJwAeuanE3ybcY9KnYwLpdVXA5rG1OWFdFvmkg8yHy8TDplT1/TNX2fAHTJ6DpWPqTXr6HeC1YJceUTAc9WxwD PFZS2N6btJHAG60aSebFg7sGVWVmIwpUAfXAxV6Cfw9drawNausty4xkHlmXcT/P8AGny6h4jWUwx6fDPszhs4BAbA/HHNTRXPiFZIw1hDKhmwzZ5C7jz WK5bNH0Dd1v/AOTGNc3nhmaSSWOGS7CQ WqYwoVVI4x6gmm258PSXEaeTN5kxyqA4wVI4/HGeetbT3GsxXUnl6TFMrTbd6EAlNx/pUTXWtpGS ixOxTkhh125wPx4/KotqCnZWX/AKUU4/8AhGorOzuJEkjVlzGu7I4Yfn90fgKfJJoFld3dnJHMrD5GAbOEX593t3pJb3X5LUIdFiD7VYHg4 6SuPxb8q3tOe8uNamW 0 OCNI JMAhzkg8 mOfxqrBJuKvJ3/7eRh28PhuaCS4RJVdIGdwTkhUDZ5PsTWzYa1pGlp9kieYxM7M0sgPBxk5z2wM10It7YPkQR7iu1vkHIpTaWbvmS2iYkYbKDkelK1mcE60ZaSvb1KieJtLNpJM05WNBnLAjK4DbvyNbUNxDcWyXETbo3GQcY4NZz6bYOY82kI2dP3YGPb6e1XlVFiCqoRF4CgYAqlc5punb3Ey0GBXBPGPSms2FGTkCmh8DrtU tNLdcsDycHNUYXIrkobYoW2J3fdjFcFfwaONR1K5kvnQx3MbT5 6rfLt59MAfnXcTuqx7jGZOegxn6157dX/wDxMZ4Z/DxlheYo7LF/rBuOGPqO9YO6PRwvM3oUnj0h7JY/ EgkcOvAQ8NgenTPf64qyV02 17zINalhmuGPyKxGThf6AVmRXumxXCvPolws0yr8pJ4IXOF/KtiJ9Jit0vRo0kMiSosYwScnjoPTFYadT2ndb3/AAK8ttHJ 8n8TqhQMQVmHA3ZHfnAFWYY5JLZGg8UHK7kJeQckcfpzWNDdaLLLHEuhSrKI1/hbALYG3n6/pU0d7ocRjup9HljnOXiAOT03nn65/GhWHaSVrP7kbjWd2LwH/hIishK4UsSMsCFwPTmu8gvLc2qIlykpCjlXB3VyOl2GjatE9zHasgiKwjLHkIMAVpr4Z0rEKpDsCOCQO4HQfSk ZPQ86rKnPSTs15I6L7ZbJA8jzoI1xuO7oDwKmF7bqUUyqCScZYZrCh8Oadb2LwRxmNGUAsG54bI/UVSbwdpJj/dCSIhh83mZ6EHv9KNTlUKPWT 7/gnUJe2zzGJZ4zKP4QwzUn2iEyiNZF3scBd3Nc2fCWjeWyKsgUoVyJPmHUdeueauWXh/T7C8juIA4ZemTwTgAk/lTvLYUo0UtJP7jdDZ65x0ApWHJGOeuOtMJwcY56U0tgMw4XHPNJs50cvqqay2qRtYzRqiL80bHjr6fTFZMcfilCcLbBAm1ETgZqLV30k I3iudVntW8pJGwflKg vvmsqGTR7W5haLXZlgikUbXbapRQCcD06c1yzbvofSUYNUlp/wCSv8zauJfFe5QkFuyBt5IYDPcL/SpDd6/50ca2EO1YVaZif4iCSB68gD8aybiO
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
Replace instrument cluster
Sorry about that. Haven't figured out how to post pictures
X
Cutting the Lexan to fit.
XX
