Topic: Replace instrument cluster (Read 7678 times) previous topic - next topic
This is the schematic I used to wire my cluster. I did not use the voltage regulator or capacitors shown. If you use the same Autometer Speedometer I did connect the "out" terminal to 5v IVR Return, position 10, dark green/white. Note from Autometer- "The speedometer signal output terminal, (VSS), produces a +5 volt DC Square wave signal. This signal may be able to be used as a VSS signal with some OEM and aftermarket ECM's and cruise control units."
Note- I use the Autometer GPS Interface to the "Sig" terminal on my speedometer.
I have a VSS installed in my T-5 with a 23 tooth gear, (Steeda from Summit, SDA-392STE17271D). This is supposed to be the correct gear per Ford for my trans, ID# 1352-246, and 355 gears.
I have never used cruise control. I did replace the TC cruise control unit with the one from my wrecked 87 Sport.
X
1987 Turbo Coupe, 306, Trick Flow Track Heat heads, Comp Cam, Trick Flow Pistons, Eagle Rods, Center Force clutch, T-5, 8.8 w/373 gears, and a bunch more
