Topic: 1988 thunderbird v6 problems (Read 13520 times) previous topic - next topic
Reply #60
Oh ok how do you check that?
Reply #61
OK so I followed the spout wire to the inside of the car and found a connector unplugged? I used a voltmeter to make sure it was the same wire. Is that supposed to be plugged in?
Reply #62
Quote from: Boothcody22;455644
In the EVTM, I don't see any connectors between the SPOUT "shorting plug" (jumper) and the connector to the EEC. Is the wire yellow with a green stripe at both ends?
I think you may be fooling yourself with your meter.
You say the car runs ok with the spout jumper unplugged.
You say the car has no spark from the coil with the spout jumper plugged.
That tells me the EEC is bad.
Reply #63
Ya it was yellow with a green stripe. I hooked one probe to the spout connector and one to the plug and the sound when off. The one plug was male and had two female plugs you could plug into it.
Reply #64
Well unplugged the battery and plugged that plug I found back up now she runs again. Thanks for the help everybody
Reply #65
Run codes and see if it's actually fixed. Nothing worse then an unreliable car.
Reply #66
Only code it gives me is 41
