Topic: Puzzling/ Happy Motor? (Read 13381 times) previous topic - next topic
Hi; first ill list performance mods
1 headers and flowmasters
2 msd coil
3 HO intake 65mm TB
 ok heres the story i got this car with 195,000 on odometer, but car doesnt run like it, i noticed when i got it none of the gauges worked, so i bought all new sensors and found that sensors on car where for a non gauge car, so that leads me to believe engine has been swapped. i removed smog pump, car ran better. deleted egr, because it was bad, car runs better, installed headers, down pipes have no 02 bungs so no 02 sensors, car runs better yet. car has NEVER idled correctly to high or to low so disconnected IAC today and set idle, no more idle issues and car runs even better now. im wondering if somebody put in a new ecm for like a tbi car or if the motor is non roller. any ideas im puzzled ....LOL.:hick:
Well you should reconnect the oxygen sensors. The car will eventually run bad without them.
Also run codes. See what's up with the computer.
Hi, what i guess im saying is the more stuff i disconnect the car runs alot better, only thing hooked up is the tps sensor and the 2 servos hanging on upper plenum, car has never run better,oh the 02 sensors have been off for 6mnths.
Welcome to 10 mpg. The car won't run right without them.
Pull the kick panel, get the computer code, check firing order and injectors. Mileage really doesnt matter, the condition of the engine does. My car has 333k miles on it and will still bark the tires on a hard launch. My first 86 had 200+k when I bought it and it would smoke a tire till 40mph. It still had stock spark plug wires from 1985 on it. These cars are really, really easy to make run right and with the e10 here I can bump timing up till it won't pass emissions without pinging.
I've bypassed my smog pump because it locked up on me. Cant tell any difference, same with egr on my last car, it only had o2's and map sensor and passed emissions but failed visual for the bypassed smog.
No o2 may make 15-18 mpg but they'll do 25 with, I gotten over 26 with mine and 3.73 gears... A leaking EGR will give idle issues and maybe at WOT if it really bad, but disconnecting it won't fix those problems... Correct adj of base idle and setting TPS voltage around .9v fixes most idle issues...
Looks like lots of hacking going on here...
Hook all your stuff back up.  EVERYTHING.
Read through the following 3 links, please:
http://sbftech.com/index.php/topic,1031.0.html
http://sbftech.com/index.php/topic,2471.0.html
http://sbftech.com/index.php/topic,849.0.html
Have a good one.
Hey; im not getting worse gas mileage its actually better, and alot more power and idles perfectly smooth, no surges. thats whats puzzling me, its the best its ever ran since i got the car. spark plugs are nice and tan, i even have the timing at 12 instead of 10. would  a non roller motor make the difference?
Im gonna pull intake this weekend, has small oil leak at front corner, and will run block # like i said before i think motor has been changed because of the sensors all being wrong.
What spark plugs does your engine use.??? Other than '86 HO, only the '86 to '91(I'm incl full size) So 5.0 use the ¾" reach plugs...
Sounds very interesting. I'll be curious to see what you find out.
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Hi' i  use autolite platinums they are a 5/8 peanut plug
Hi; ecu seems to be correct E8SF-12A650-A1C, now i gotta get motor #to run it.
What's the firing order on your distributor?
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
order #15426378
Quote from: V8Demon;454474
Have a good one.
Do this BEFORE you replace anything.
