Topic: Burning rich and stalls out (Read 9326 times) previous topic - next topic
Hey guys, I just finished I guess what would be considered slightly more than an HO conversion on my 88.
I'm running explorer intakes/injectors, gt40p heads, B303 cam, MAF conversion with SR CAI and A9L computer, and whatever else is listed under my picture.
My car is an AOD and will stall out sometimes at stoplights and if I'm in reverse.  It's also burning super rich to where it burns your eyes if you're around the car.  Any help is greatly appreciated, as you guys know I'm a 19 year-old newbie.
'88 Thunderbird LX
Engine:  FR B303 cam, GT40P heads w/ Trickflow valve springs, Explorer upper/lower intake, SR cold air intake w/ MAF
Exhaust:  shorty headers, BBK O-R X-pipe, glasspacks w/ turn downs
Misc:  8.8 rear, Saleen SC replicas 17x8/17x10, Mach 1 front springs/SN95 rear springs
'74 F100 Custom 351W
Codes would be a good start.
The biggest effect on a/f ratio on an SD car is the map sensor. When you add mass air, the computer sees both the bap (map sensor without vac line) and compares that with the maf sensor to calculate air coming into the engine and verifies fuel ratio with the o2 sensors.
Really though, codes should tell ya why it's running rich.
Once you've resolved the running-rich issue, you may also want to get an A9P computer for that instead. http://www.allfordmustangs.com/forums/5-0l-tech/30747-what-makes-a9l-computer-special-vs-others-ihra-nmra-fun-ford-track-rules.html
A9L is for a stick. The A9P has slightly different software. Based on the neutral safety / park-neutral indicator switch, it will command a slight kickup in idle to counter the load placed on it by the torque converter. Without this you can definitely have stalling issues with an automatic trans. Again this is not going to impact the rich fuel mixture problem you have, but once that's behind, the occassional stalling will be equally if not more annoying :)
My stock 5.0 s.o computer wasn't pr0ne to stalling. Plus its running rich.
Oh, I see what you mean zonda... Lots of mustang guys run the stick computer behind the aod. Supposedly it is more responsive or something made up like that.
Just run codes, it should give ya a really good idea what is wrong.
I'd like to know more about the hardware you used for the MAF conversion, specifically, what MAF.  The CAI will skew the MAF readings, and the Explorer injectors are of the EV1 type.  These are things that can make problems for you.  You need to tune.
Swapped computer to an A9P today. Stalled once so far, but seems to idle better.  I've heard A9Ls have better throttle response and that's why people want them.
Next step is to run codes.
'88 Thunderbird LX
Quote from: Haystack;452574
You know I'm an idiot. I HAVE a stick computer in the red car. So that's out. The response might not be optimum but it does work.
It's probably BECAUSE his fuel mixture is screwed up, let's face it. It can't compensate enough for all of the external issues being input to the "idle signal".
And I had always read that the fuel and timing curves were more aggressive with the stick computer. Basically a better tune, if "better" is defined as more power. Which we would probably all agree is better LOL
Quote from: TheFoeYouKnow;452579
This could easily be it. Need to know more details. Some mafs are really picky about cold air intakes and bends and filters near the maf. Plus there are quite a few different calibrations of maf, and the 19# new styled injectors probably will throw a wrench in everything too.
With the whole explorer setup and a h.o. cam, you might benefit from a larger throttle body and 24# injectors. This is also essentially the 93 cobra setup, so a mother computer swap, correct maf and some junkyard injectors out of a 460 might get ya away from a tune.
Anyways, we really need to know more specifics, and of course codes.
I wouldn't call your changes "slightly" more than HO, you've made major changes especially with that B303...
If you haven't increased base idle to around 800-900 in gear it's going to stall, just a fact of life with a rumpy cam... Also if your torque converter is stock that will aggravate the situation, need something looser I recommend a 2800-3200 with the B..
To make better power at WOT with that setup, you need to ditch the 58mm TB and go for a 65...
Your car may smell rich but in actuality it may be running fine. Without catalytic converters your car is going to smell rich at idle. Before you do ANYTHING else you really need to check for codes. Doing anything else before checking for codes and correcting any that come up is a waste of time and money. Here's how to check for codes, both KOEO and KOER:
http://sbftech.com/index.php/topic,2471.0.html
Check for KOEO, KOER, and cylinder balance test codes. Here's a list of the code explanations:
http://sbftech.com/index.php/topic,849.0.html
If you're not sure what a code means post back here and we can help. Once you've corrected all the issues caused by the codes you will probably have to do a base idle reset to get everything to run well (especially due to your cam choice). Here is how to correctly preform a base idle reset: http://sbftech.com/index.php/topic,1031.0.html
Mine smells rich all the time, but I can see my short term fuel trims bouncing up and down about 3% from zero, and my adaptives at about +2%, so regardless of what my nose says, my O2 sensors say I'm fine.  My injector slopes, spark tables and MAF transfer are dialed in tighter than a stock tune on a stock engine, so If I HAD cats, I'm pretty sure sure the air coming out of my engine would be cleaner than the air going in.  Don't listen to your nose, it's lying.
My car smells rich at idle but doesn't throw any rich or lean codes. Without catalytic converters engine exhaust just smells bad.
The fact that the injectors are EV1 shouldn't be an issue.  Stock HO stuff is EV1...
More information needed.  Like stated earlier MAF meters can be fussy.  There's usually different calibrations for CAI as opposed to the stock air box.
For what it's worth, those SR CAIs in the fender well run too small an air element for my liking...
