Topic: Irrational case of the wants for this Continental (Read 9747 times) previous topic - next topic
Quote from: TurboCoupe50;453248
Those heads are better flowing than the E6...
Really! Thank you for continuing to be a pillar of knowledge. That's like the best "useless piece of trivia" I am now gonna piss my buddies off with. And I don't myself believe it to be useless, just using the cliche.
Really!!
The cravat is they probably have larger combustion chambers than E6 or E7 heads, '80s 5.0 engines up through '85 only have a 8.4 compression ratio... Still the 4bbl carbed '85 HO made 210Hp...
In the coolcats h.o. upgrade it lists e5 (or whatever the codes are) heads from 80-85 as suitable if you can't find e7's.
"If you cannot find E7s, it's perfectly okay to use a slightly older Ford 5.0 head (E3, E4, etc.) but avoid reusing the E6s unless you cannot afford E7s or cannot find them."
- See more at: http://www.coolcats.net/modifying/ho_conversion.html#sthash.sppqDrDf.dpuf
Quote from: TurboCoupe50;453267
Really!!
True. One advantage to the 85 engine is that the pistons have valve reliefs (unlike the E6 headed 86-87 engines). That's helpful in that one could easily run something like an AFR165/Edelbrock Performer head. Although the 86-87 SO engine should accommodate TW170 heads without issue......
