Topic: converting to floor shift (Read 6000 times) previous topic - next topic
when converting to floor shift from column,,
is there any visual keyway or indicator to tell me where to cut already on the car as a template?
meaning do all cars have some sort of plug or dot or dent or whatever that tells me where to center up and punch through?
Quote from: jcassity;451230
I'd guess there is but never paid attention, I can look at my parts TC tomorrow(g rain at moment and will be dark in another 20 min)...
Hey jay, I got the pdf with the template and instructions. Is your email the same?
Quote from: Kitz Kat;451236
its on coolcats i think
I did notice that when I ripped up all the stuff that was glued to the floor, I saw nothing from the top side...transmission hump area.
I spent plenty of time on the underside as well,, seems like I would have noticed something that stood out .... but did not so that's why I was asking.
http://www.coolcats.net/media/docs/shifter_template.pdf
Thank you everyone,, will get to this soon and post up pics.
seems easy enough.
Dave, got your mail and thank you !
hey guys,, finally wanting to cut a hole in the floor to do floor shifter work,, cant seem to get that pdf shown above.
email is
jcassity@frontier.com if you have it.
my entire chassis is empty with no carpet ,, i do have a dash sill in place.
this is an 87 LS cougar platform.
need to know where to cut ,,
help
304 772 3411
I just got a 2" hole saw and went to town.
does the hole really "need" to be that  large for an AOD car.  i somewhat understand the 5spd application needing more room.
The plus-shaped hole allows the shifter to be bolted at all 4 corners. Actually 5-speed cars didn't have those tabs, it was just a big square hole. But yeah, it's sort of necessary to do things this way.
when the drawing shows the distance off the dash
does that mean distance off trim around th center area where the ash tray is or does it mean iwthout?
the trim itself is worth 1'' depth so thats why i ask
