Topic: Swapping out the 3.8 (Read 7237 times) previous topic - next topic
Hey guys,
I recently had a head gasket blow out on my '85. The engine started to overheat as well. My mechanic says it's probably going to need a new head.  My thinking is, what's to say that I won't have another head gasket blow out sometime. I've been thinking about maybe going a different route and swapping in a 5.0 I'm just wondering what all it would take to make it work?
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Cool, thanks! I think the same basic principles will still apply, but I was actually thinking about using a 70s-early 80s carbed 302.
Cornfed85
So, the 5.0 swap is definitely happening. I need to find a decent, halfway low mileage engine.
Cornfed85
I was just offered a chance to buy a turbo 2.3 from the college I go to. How easy would it be to put one in a V6 car? Can my C5 hook up to it?
Cornfed85
Quote from: Cornfed85;451224
Going to/from the 2.3T in anything other than a NA 2.3 Stang or Ranger is far more work than from/to V6 or V8... You'll need all sorts of unique pieces like throttle linkage, intake plumbing, VAM, computer and it's wiring(that's necessary for any swap) etc, etc...
BTW, no a C5 won't fit a 2.3, even T-5 are different(input shaft & gear ratios), but can be made to work...
Ok. I guess it's back to finding a V8.
Cornfed85
There are literally millions of 5.0 engines out there...some of the newer ones from say, Explorers, etc can go several hundred thousand miles and only need basic tune-up parts. My '97 Mountaineer has 260K on the clock....I'd get in it and not be afraid to drive to either ocean, and engine wise, it would make provided I stopped every 120 miles for another tank of gas.
(It's the rear that scares me...lots of play in the axles and she's got a howl when I get in it. He he he...sounds dirty, but... ;)
I am looking to get a 1970's 302/351. Will it bolt up to my C5? Also, will my wiring (alternator, etc.) work for a '70s engine? I know I won't need the ECU anymore.
Cornfed85
Yes the C5 will hook up to the 302 , but it will need to have some work done to it.you will also need to change the flexplate and torque converter.
If it were me , I would go with the c4 , you would have more money in the C5, than you can buy a C4 for.
I am running a C5 behind a 1969 302.
I just found a 1968 302 with a C4. What all would need to be done to make the C4 work? I assume it probably wouldn't just drop in.
Cornfed85
Actually, I'm thinking about going with an '80s 5.0 swap. I found ECUs that aren't very expensive. Now I just need to find a V8 ECU harness and '86 V8 motor mounts and then I'll be set to get the engine.
Cornfed85
I've heard mixed reviews on the AOD. Some people say they work fine, other people say they're plagued with problems. Early overdrives have a bad reputation. Not just the AOD, but the early Torqueflight overdrives, and the GM 700R4s.
Cornfed85
