Topic: Swapping out the 3.8 (Read 7238 times) previous topic - next topic
Just throwing this out as another potential option to see what you guys think. Has anyone ever tried swapping in an early 4.6L? I've found a few early '90s Crown Vics that are pretty cheap and wondering how complicated that swap would be. Or how about the 5.0 out of a '95-01 Explorer/Mountaineer? I know the guys over at CoolCats mention the Explorer 5.0 as a possibility, but I didn't know if anyone had tried it here or not.
Cornfed85
1985 Thunderbird - 3.8 V6, C5  :ford:  :birdsmily:
Lots of guys run explorer motors, but you will need at least the wiring harness, ecu and sensors/basically everything else from a 87-93 mustang and 86-88 cougarbird.
Honestly, I bought my cougar for $500 with a running 302 and good shifting aod 4 years ago. It would be much easier to buy a 86-88 cougarbird and either build up that motor, or use it as a complete parts car for your swap. Where you have an 85, you'll need fueltank and lines, all the engine accessories, motor mounts (85 was a cross over year. You may be able to use 87-93 mustang mounts, or get stuck with our cruddy 86-88 style mounts) throttle linkage, transmission linkage, driveshaft (aod and t-5 us the same length behind a 302, I personally wouldn't bother with a non od trans, but I driver my cars freeway several hundred miles a week) all the engine bay stuff, fuel pump, fuel pressure regulator ect ect ect.
Not trying to scare ya away, but at the very least I'd get the 86-88 parts car and hopefully mate it with the 85 body harness. There's really only a few wires to a week swap that would need to be integrated with the body harness, but wiring can be a nightmare if your not good with electrical diagrams.
Check out the evolution 2 thread, last page of damiacs build. He is only swapping from a 85 302 keeping his motor and adding the sefi stuff ontop.
Quote from: Cornfed85;452301
You couldn't give me a early 4.6 and pay me it install it in my own car(or a later 4.6 for that matter)...  If I remember correctly, make 180Hp and are huge for the displacement, approx size of a 460... Pre '96 suffer from poor valve stem seals, and will get maybe 500 mi to quart of oil unless replaced which is a major PITA(been there, done that)... Unless you are talking early '92(yes, a half year only model) that have Windsor bell pattern, the only transmission that bolts to a 4.6 is a dedicated three bolt starter modular AODE or 4R70W... Windsor pattern bells use a two bolt starter and will not fit the 92.5 & up mod motor...
To use a Explorer engine basically you have to replace the pan and all front accessories with fox chassis parts... Using std headers on the GT-40P heads are challenging, some have used short racing plugs to get enough clearance... Still It's a good choice, especially if replacing a tired SO 5.0...
BTW AOD are fine, when I had the 5.0 in my T-Coupe, I used one for nine years and approx 700 drag strip passes... That trans has only a hardened input shaft(yes I broke the orig, but are fine with a stockish 5.0), and a Trans-Go shift kit, it still shifts fine... No I won't use it behind the new 331, have a fresh AOD with Lentech valve body for it...
Unless that '68 302 has reworked heads with hardened valve seats, it'll likely burn the valves within a year of daily usage, got a T-shirt for that one as well...
Quote from: Cornfed85;452258
I just found a 1968 302 with a C4. What all would need to be done to make the C4 work? I assume it probably wouldn't just drop in.
With a stock 302 a V8 or SC AOD will be fine. I nuked the factory 120K mile AOD in my Thunderbird with just a GT40P head/GT40 intake combo several years ago. Got it rebuilt (quite a bit stronger than stock) and it's fine behind the current combo in my Thunderbird (see signature). The factory AOD behind the 5.0 HO in my Mark VII still shifts fine at 155k miles.
Quote from: TurboCoupe50;452397
You can use std headers on Explorer 5.0L with no problems at all if you use a 96 or early 97 with GT40 Non-P heads, it's only the late 97 and up 5.0L's that have the P heads.  You also won't have to have the valve springs replaced to run an HO or larger cam.  P heads aren't worth it for the extra trouble of working around their funky spark plug angle and their shiznit-bin valve springs.  I had to machine down the spark plug bosses in my chambers in order to clear the crowns of my KB domed pistons, and I have to tune for less spark advance to avoid spark knock than with standard GT40 heads.
