Topic: overheating issue (Read 7022 times) previous topic - next topic
overheating issue
Okay I have an 88 turbocoupe it's getting hot really really quick. At first it would get close to the red then come back down. Now it's not coming down at all and gets hot after a 5 minute drive.i thought it was the t-stat replaced that as well as the water pump while I was in there. Flushed coolant didn't look that bad. I've also replaced the coolant temp sensor. I've also noticed that the fan and radiator do not belong in the car. I don't know what it's from but it's zip tied in also changed oil and it looked fine. I found someone with an electric fan and radiator out of a fox mustang for less than $200 would it work in my car?
overheating issue
Does it overheat at freeway speeds? If so, its not the fan.
overheating issue
No it doesn't it actually runs alright at highway speeds. I drove it all the way from Wisconsin to illinois and it was fine on the highway but would get hot in town. I didn't think it was kicking on so I just ran a power wire straight to the battery so its always on and it still gets hot.
overheating issue
Probably a bad fan or something blocking airflow then.
When i pulled my radiator back, i had weeds that had grown between the radiator and ad from when it sat in the previous owners back yard. It didn't overheat after, but ran a ton cooler after i cleaned all that  out.
Undo the two 3/8 bolts on the radiator tie down brackets next time you go to a car wash and hose down the radiator inbetween.
overheating issue
overheating issue
when your running again and your dash is saying hot, turn off car and then fell down the radiator top to bottom everywhere you can physically reach.
half the core could be blocked off or something,, at least this will tell you if the rad is circulating all its individual channels.
next with a cold engine,-remove rad cap then start car, if you see water flowing then tstat is staying open,, some people are easily tricked and put the tstat in backwards as well.
overheating issue
Have you looked down into your radiator? Mine over heats quickly in town because the passage ways in the radiator are blocked by hard water build up. I have knocked off the build up I can see up top but I'm sure it is like that all the way down. Saving up for a new one.
overheating issue
Jcassity I did what you said the driver side of the radiator is cool and the passenger side by the upper radiator hose was hot then cool then hot.so it's the radiator?
overheating issue
Sounds like its at least partially blocked to me.
The radiator on my cars has always flowed passenger to drivers side, top to bottom. It should get progressively cooler with no hot(warmer) spots as it gets to the drivers side.
overheating issue
Nobody seems to have answered your Mustang question.  You CAN use a Mustang radiator and fan, but don't use the 4cyl radiator, use the V8 radiator.  Both cars may be 4cyl, but yours has greater cooling needs.
overheating issue
If your car is mostly stock get one of these parts store replacement radiators: http://www.oreillyauto.com/site/c/detail/MHT1/433556/01386.oap?year=1987&make=Ford&model=Thunderbird&vi=1430183&ck=Search_C2465_1430183_3405&pt=C2465&ppt=C0331 It should work great. Radiators do clog up over time. My factory radiator finally decided it had enough after 25 years and wouldn't cool the car at highway speed. Replaced it with a aluminum radiator with 2 one inch rows and it's been fine since.
overheating issue
It's completely stock it's an auto :(
overheating issue
Quote from: SR7188;449399
http://www.latemodelrestoration.com/item/SVE-RADKIT79M/1986-93-Mustang-50L-Complete-Aluminum-Radiator-Upgrade-Kit I was looking at this. I plan on doing a t5 swap fmic more boost later down the road
You don't need the hoses or thermostat housing from that kit. Plus the fans in that kit suck. Your stock fans (operating properly) are much better.
overheating issue
I thought the hoses are the same? They say you need that housing for the duel fan setup or at least that's what I read in the reviews. So I should just piece something together if their is a fan you recommend let me know.
