Topic: Megasquirt for the bird on the road to having her a turbocoupe again. (Read 17918 times) previous topic - next topic
Reply #60
One for posterity.
Reply #61
Haven't been here in a while. Cars still on the shiny side up and have not felt the need to toss a match at it. However it is running bad a every time I touch it, it gets worse. Maybe time to park it for the winter. need to get ready for SNOW.....
Reply #62
Got mine fired tonight! Injectors are pouring fuel though so I need to tweak EVERYTHING!  Just a bit excited. The garage was smog city after 5 seconds runtime.
Reply #63
It was a 100 degrees out and car was so rich I could only run it for a minute before I couldn't take it when I got mine started. Good luck and have fun.
Reply #64
Have you gotten yours to command a sub-1000 RPM idle yet?
Reply #65
I don't know what you mean by command a sub-1000 rpm idle. But it idles at 950 ish. I've kicked it up to 1100 to keep alternator charging. I need to replace it.
Reply #66
I got it sorted. Seems I had a few gasket leaks! Smoke machines are awesome, by the way. Currently idling fairly smooth between 7-800 RPM. Now I need to sort out why TunerStudio isn't displaying my Wideband correctly.
Reply #67
I had to calibrate the voltage. Using a innovate mtx wide band.
