Topic: Smog ports (Read 1769 times) previous topic - next topic
Smog ports
Hi guys,
Ya know those smog ports on the back of the cylinder heads? yes, I know trick flow makes block off inserts for this. But what I wanna know is, can you install those WITH the engine still in the car? Or is the firewall too close?
Any help is appreciated
Kyle
Smog ports
You can just take off the existing pipe with the engine in the car.
You can also flip that pipe (or cut the pipe off and pinch shut or seal the ends) and reinstall them instead. I've also heard a spark plug is the same thread, but i haven't verified that.
Smog ports
Yes, you can do the flip with the engine in the car
Smog ports
I broke spark plugs off and used the metal threads before, I also cut the pipe and flipped it to. Both work.
Smog ports
They are 5/8" coarse thread, you can use some short bolts in that diameter with exhaust cement on them, a bit less ghetto than busting off spark plugs.  LOL
cheers
Ed
84 Mustang SVO
95 Jaguar XJR
Smog ports
Thanks guys!!
