Topic: 87 "coug" resto winter project (Read 139080 times) previous topic - next topic
Reply #60
progress pics below.
All welded up and its in its final resting spot.
We need to drill two drain holes in the bottom of the core support, we just thought about that.
We now have the tow & lift point welded in as well.  We will simply cut the bumper cover to allow it to be used.
Reply #63
I have all of this new assembly "ahead" of the first major crumple zone so hopefully it isn't a safety issue.
the sway bar mounts are just at that point and is where our new core support rear connection is.
Reply #65
Now subframe connectors!
Your next project :)
Reply #66
yes, thinking that part through as well, I don't really like the existing designs out there........... WHY THE HELL DOES OUR FLOOR PANS CHOKE OFF a straight shot from the front to the rear!!!!!!  thing needs to be offset!
Im going through the floor up front with bushings and up inside the rear tubing in the rear.
so yes that's kinda next along side of when we drop the tank to do some PM work back there.
right now we are blasting the front end.
Reply #68
Quote from: jcassity;441743
Nah. you just need some 1"x2" flat tubing. The two subframes are actually level with each other. See here: http://www.foxtbirdcougarforums.com/showthread.php?31082-You-need-subframe-connectors&highlight=subframe
Reply #69
yes I understand that, the rear and front frame openings are on the same plane but the floor pan blocks off the rear opening because it dips down.
I want something to go inside each opening and to do that is to slice open the floor pan.  that we are not going to do.
something homemade will go on ,, something that makes sense hopefully without going overboard
to be honest the next most closest item I would like to fix is tossing this stupid K member for something else ,, im open to a used k member in lighter weight.
I hate how much real estate these things take up.
maybe Ill post a wanted ad
Reply #71
now its time to drop the gas tank out back and see whats going on back there.
empty the trunk out, and prep out the fuel pump access panel.
Reply #72
Nice!  Keep at it.
I'm getting old.  I remember the V6 rebuild on this car.
Reply #73
This guy happened before I painted that part lol.
Reply #74
Time to take care of the gas tank area
tons of sandblasting and such ,, was not too fun
