Topic: Random Engine Dying Off (Read 3081 times) previous topic - next topic
Replaced my fuel pump the 14th of August and everything was running fine. However as of now when the car is idling or running at a low speeds, 1st or low 2nd gear, the car will die off. It is not all the time just here and there. I am thinking dirty idle air sensor or bad fuel pump relay. Just wondering if anyone else has had this problem or if any of you have any ideas of what it could be and how I can test for them.  Help much appreciated!
Does it sputter-sputter die, or just cut off?
CoogarXR : 1985 Cougar XR-7
Just cuts off, was also thinking a fuel pressure regulator since the system was starved from the old fuel pump having a hole in the submerged line.
Could be a bad fuel pump again .  Just because you replaced it down not mean it is now 100%.  You need to get a fuel pressure regulator in the cab with you so you can see what it is doing pressure wise.  Cleaning the IAC and getting a new fuel pump relay are cheap so no harm in doing that but I would still check the fuel pressure so you know where you are at.  Have you ran the EEC for codes?  Just because the CEL is not blinking or on solid does not mean its not throwing a code.
Darren
Thuderbirder85 and I found the problem this past week.
Faulty TFI Module.    Replaced it, and all is well!
Dumb Non-Motorcraft Parts! ;)
To laugh often and much; To win the respect of intelligent people and the affection of children; To earn the appreciation of honest critics and endure the betrayal of false friends; To appreciate beauty, to find the best in others; To leave the world a bit better, whether by a healthy child, a garden patch, or a redeemed social condition; To know that even one life has breathed easier because you have lived. This is to have succeeded.
]Ralph Waldo Emerson
I soooo dislike these TFI modules...... When i had my 87 t-bird, i would keep a spare in the car; never knew when it would go out on me.
How fast is fast?
I keep a spare in the trunk also. The mounting just above a heat source was not one of Fords better ideas.
Definitely not one of the great Ford ideas. Thanks for the help guys!
so tfi (icm) was ur problem? mine has been basically doing the same thing. did urs run erractic a bit at times or no?
think i might have a few other issues also
Quote from: 88tbirdsport;437447
TFI Module was it.
Funny thing is, the car ran and drove perfect up until it would just die off.    Nothing erratic at all, otherwise.
These modules are know for their "Fabulous" reliability.
If your car is doing the same thing - it won't hurt to change it.
Just make sure to use a Motorcraft part.    They seem to be about the only ones that actually work.
