Topic: lowering springs (Read 4597 times) previous topic - next topic
lowering springs
Anyone know what mustang springs will fit my t bird 1986 5.0?
lowering springs
I used '99 Mustang springs in mine. My Bird is an '88, but would work the same in your car.
lowering springs
I also have 99 mustang springs up front and moog cargo coils in the back for the 83-86 picture.
84 TurboCoupe with 302 .010 over - 9.8 : 1 Forged Pistons - Edlebrock Goodies:  Aluminum Heads #6037, Intake #3821, 65mm TBI/EGR #3824/3827, Camshaft #3722 -  Interactive System & Technologies Mass Air with 24# Injectors - A9L - 3g Alternator - BBK shorties, Cat Converter H-pipe, Magniflow lers - World Class T5 1352-169 (1986, V8, WC, 3.15 3.35 1.93 1.29 1.00 0.68) OEM Clutch Cable - 7.5 Trac Lock with 3.08 and slapper bars from 82 Mustang.
lowering springs
thanks everyone
lowering springs
I have fox mustang Steeda springs in the front and turbo coupe Moog replacement springs with a couple coils cut off in the rear.  Also have Fox Mustang shocks/struts with Chuck W shock adapters in the rear and Fox Mustang spindles up front.
lowering springs
86 Mustang  GT springs here.
lowering springs
I got these ones:
http://www.americanmuscle.com/forac.html
It dropped the ass a bit more than I liked. Hoping to get CHE control arms with the threaded spring perches
lowering springs
What is wrong with cutting the original springs and setting the height to your liking. Dont get me wrong i change many springs in my career but cutting is a viable option. have a great night guys
lowering springs
^^Cutting springs will lower the car. But with lowering springs you can get stiffer springs. You can get progressive spring rates or constant spring rates. I noticed that my car dives A LOT LESS under braking with stiffer springs
lowering springs
Quote from: kylesburrell;436488
But cutting the springs does change the spring rate as it is a function of coil diameter, number of coils, and thickness of the steel used to make the coil.
**SpringRate = (Thickness)/(nCoils*CoilDiameter)
So with all things being equal reducing nCoils increases ones spring rate, so yippee!
**This functional relation was obtained from the internet @ http://www.therangerstation.com/tech_library/coilspringrate.shtml and is being posted onto the internet by someone someone on the internet no warranty written, expressed, or implied.  All risk is assumed on the part of the user.
lowering springs
Removing effective coils  increases a springs  rate as explained above. Cutting springs is totally acceptable and done all the time. have a great evening guys
lowering springs
I got sn-95 something or another springs um gonna drop in the bird. i might go with some lowered rear springs as i plan on che adjustable arms later on.
lowering springs
http://www.bluecoilspring.com/rate.htm
Load rating is just as important....
