Topic: Wanted Parts (Read 1175 times) previous topic - next topic
Wanted Parts
Hi guys,
Im looking for the RED door pulls for the interior of my car (86 tbird), the little red plastic pieces that go over the door pull, the black plastic triangles that go over the side view mirror mounting studs, an AC compressor, and a few cans of R12.
Thanks!
Kyle Burrell
Wanted Parts
I have some red door pulls and 3 of the covers IIRC
I might also have the triangles
Pm if your interested
Wanted Parts
I have two of these red door pull covers that are obviously not from the 87-88 Turbo Coupe. Can someone tell me what car they are for? They were in the trunk of a parts car.
X
Wanted Parts
1985,1986 with standard door panel..
Wanted Parts
the smaller one is for the 87-88 tc door panel the has the chrome trim on the door pull/panel. the bigger one is 85-86 tc.  The standard 85-86 door pull screw covers would have a groove in the middle of it
John
