Topic: Stock Quarter Mile (Read 8759 times) previous topic - next topic
Stock Quarter Mile
Has anyone run their stock (or near stock) 5.0 Fox T-Bird/Cougar at a drag strip? I tried searching and can't find anything matching this. My 1990 Mark VII with nearly 180k miles and only an off road H-Pipe and Thrush welded lers ran 15.5 but thats an H.O. and a much heavier car.
Any ideas or time slips?
Thanks.
1986 Thunderbird 5.0
-FRPP Wires and upgraded ignition parts.
-H.O. Upper Plenum / EGR Spacer / TB
Stock Quarter Mile
15.5? That's pretty  good...you're right about all of that. Wow. Any idea what rear end ratio it has?
I have a G-Tech Pro (the FIRST one they ever made in like 1999) and it repeatably gave me 9.4 seconds as a 0-60 for my 1987 20th Anniversary Cougar. Stock 5.0 150 horserpower, car itself, 1/4 tank of gas, me not sitting in it, weighs 3550 lbs.
I think it would be at LEAST a 17 second 1/4 mile, maybe even 18 or 19 depending on options. I think sheetmetal-wise, the Tbirds have a slight weight advantage, and power seat tracks EACH are about 50 lbs. So ranging from an ultra-stripped down four-eye car to a fully loaded 87/88, 5.0/AOD/2.73 rear held constant let's say (that's what I *had* at that run), you could see some significant variation in speediness...
I know Mark VII LSC's could have a 3.27 gear optionally, the LSC anyway with the H.O. would have gotten the 8.8 axle. Not sure if anything higher was available. Next one up would be 3.55 but I feel like that wouldn't be a factory car gearset. Ranger? Maybe.
Stock Quarter Mile
Quote from: ThunderFox;433088
Thanks.
That's pretty good considering stock Mark VIIs (LSC with a 3.27 rear) run around 16.1-16.2 @ 86mph or so.
Stock Quarter Mile
I will also note that you people on the east coast must have better tracks or tracks below sea level. Every really good quarter mile track time I see comes from the east coast. Out here guys seem to run about a half second slower.
Stock Quarter Mile
Quote from: thunderjet302;433092
When I ran my old Mark VII that was at Raceway Park in NJ which is 20 feet above sea-level. Lol
Quote from: ZondaC12;433090
I know the Thunderbird has 2.73's compared to the Mark's 3.27's and even with my top swap the Mark Would have had a nice advantage in horsepower and some torque but there has to be a big weight difference, right? IIRC the Mark was at or around 4k lbs. I'm hoping I can be somewhere in the 16's...
Stock Quarter Mile
I g-tech'd my car back when it was 100% stock and it was always right around 17.00 in the quarter.  That's with 5.0 SO, AOD, and 2.73 gears.  I need to try it again now that I have 5.0 HO, T-5, and 3.73's...its still slow but not nearly as slow as it once was.
Stock Quarter Mile
Quote from: 50tbrd88;433097
I was figuring it would be high 16's at the most. I guess I'll find out for sure within the next month or so when I go to the track with it. My old '77 Olds 98 Coupe with a 350 had similar stock power numbers (165hp / 275 tq), a 3 speed auto, similar rear end gears, much more weight and it still put down 17.4 in the quarter. The T-Bird is definitely faster than that car.
Stock Quarter Mile
I'd hate to think how slow a 5.0 CFI car is haha
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
Stock Quarter Mile
My 86 cougat does about 12 seconds to.sixty, no idea on 1/4 mile.
tbird does a bit under 10 to sixty, but it has a t-5 and seems to run better then the cougar.
Stock Quarter Mile
I would think high 16's@ 82 ish....if it's a sport and has working posi that would help with the 60'
Also a sport will have 3.08 vs 2.73....
I'm impressed with the mark7....that hauling for such a stock setup...
My bone stock 93 SC auto super loaded....i.e. fat.
That ran 15.4@89.
Travis
Stock Quarter Mile
That ran 15.4@89.
Travis
Stock Quarter Mile
I originally did just an H.O. swap, with full 2.5" exhaust. I probably could have swung a GT40 setup, but I pretty much learned what that was after the fact. I also learned about rear end gears....and confirmed what my seat-of-the-pants-o-meter thought: it was not the major improvement I had expected. I was 17 and had no practical knowledge of power. My uncle had a '96 Vette about that time. He gave my brother and I each a ride once. He never actually...went FAST with it. Mom would never have approved. If only he were the wild type, I would have known what I needed a lot sooner! :rollin:
Stock Quarter Mile
Quote from: turbotrav;433105
That ran 15.4@89.
Travis
That's pretty good. Best stick Thunderbird SC I've seen run was 15.6@90.
The track here is open on py weather days for test and tune. The best day I've had over the past several years was last year when it was 68* with about 70% humidity. The track is 630 feet above sea level. Converting the DA for that day was something like 1400 feet above sea level. When I plug my times into the dragtimes DA calculator my car ends up being .2 seconds and almost 2 mph faster at sea level. Best run that night was 14.12@98+mph with a 2.25 60'. My car spins bad off the line on street tires. Using that calculator it still converted to a 13.9 something at a little over 100mph. I need a cooler day and some drag radials as my 60' sucks. Plus I suck at launching. I've got a full weight (3700+lbs with driver) 13 second car if I could get it to hook.
I wish the track was open on a 45*-50* night :hick:.
Stock Quarter Mile
It's gotta be faster than my Mark VII LSC. At 3900+lbs with driver it hits 60 in a little under 8 seconds. It seems decently quick until I drove it a couple of hours after driving the Thunderbird. The Thunderbird (spinning like a mofookie off the line) will hit 60 in a timed 5.4 seconds.
Stock Quarter Mile
Quote from: thunderjet302;433113
Thunderjet....take that bird to the track and get your 13's....it can do it...LOL
Travis
