Topic: new best city mpg (Read 7802 times) previous topic - next topic
new best city mpg
Filled up with Premium 93 today, and got 26.3 MPG on the highway........24 on 87 usually.
new best city mpg
Therr is less octane, therefore less power.
People always laugh at me when i tell them i get best out of 711 gas, and worst out of chevron and texaco.
new best city mpg
Quote from: MY83T;432045
I'm surprised you got a benefit. With the stock setup and stock timing you should see no benefit from anything above 87 octane. I run 93 octane in my Thunderbird but I've got the timing set at 18* BTDC. I run it for knock prevention.
new best city mpg
Quote from: thunderjet302;432057
Not only have i noticed better mileage, but its running smoother also on acceleration with 93.  I only put better brand fuels in my car also.
new best city mpg
When we did the stupid ethonal switch, i got the equivilent if 108 octane due to the corn . i also lost at least 7% mileage per tank. i think i got some of my power back by bumping the timing up to the 16° range, but the car ran the same with better mileage when i filled up at the gas stations that had not converted over yet.
i expirimented with higher octane. i saw no improvment at all. flying j gave me the best overall average. i honestly think it has more to do with you knowing you filled up with expensive gas. kinda like your sure the car runs better after you do plugs and wires, even though you forgot one plug.
the only reliable way i found to improve gas mileage was to stay a constant 55mph. this would take me from 25-28 range to 30-35mpg range. every other trick i tried had no effect or made things worse. my best actual mileages have actually all been or rural highways through moutain passes with several hundred lbs worth of gear.
When i drove to montana a day or two after i completed my t-5 swap, i brought all of my had tools, two spare tires, my 4 ton floor jack, two jack stands, and several more hundred pounds or work tools, parts and equipment, plus mine and another guys luggage. I got pulled over three times and searched for drugs because my bumper was practically dragging. i averaged 28mpg (no odometer, based off of google maps), but also didn't include about 100 miles worth of driving the day before. if u added about 100 miles into the 15.8 gallons i put back in, it would have been well over 30mpg.
When i tracked it everyday, same normal 52 mile route, i could go anywhere from 23mpg-30mpg without changing anything at all. not using cruise control was also good for about 10% increase. i also don't drive for best mpg. i always floor it wot on every on ramp and to get up to merging speed.
the biggest problem with mpg, two identicle cars driven by two diffrent people can give very puzzling results.
new best city mpg
Quote from: Haystack;432063
i don't dispute your results at all, but i can say that i tried my test one day apart.  Same weather, road conditions, and cruise set at 60MPH.  I then hit the reset on the MPG counter at the same marker as well.  The mileage benefit was definite. As for the performance question, i had some noise on hard acceleration almost like a slight knocking, which has vanished with the 93 tankful.  I ran the car down to 3 gallons remaining before filling with 93.  I always fill up at the same local BP station too.  I am driving Fox Birds/ Cougars nearly 30 years, so i am a quite familiar with the quirks.  Def feel a difference.  I may not be able to voice it in a super technical way, but the acceleration was smoother and less noisy.
new best city mpg
Hmm there are two possibilities. One is that your Cougar has the timing advanced from factory specs. Not likely but it could have happened at some point. The other is that the car has carbon build up in the combustion chamber. It will ping on 87 but not on 93 if that is the case. As a fyi my 91 Mark VII with a 5.0 HO runs fine on 87 octane and the factory timing spec (10* BTDC).
new best city mpg
I was thinking the same thing as thunderjet.  There is no reason a stock SO 5.0 should need 93 octane if everything is working properly.  The only other thing I can think of other than timing and carbon build up is maybe EGR valve stuck closed.
new best city mpg
Heh, even cars I had that required/recommended premium, I put regular or mid-grade in and had no issues at all.
Current: 1986 Thunderbird, 105k 3.8/C5, 2 tone  Midnight Wine/Medium Taupe, wing windows, wire wheel covers.
Former: 1985 Cougar GS 115k Oxford White/Regatta Blue, 5.0, full console, 14" 8 hole aluminum T-Bird rims, Edelbrock valve covers.
new best city mpg
I'm not taking anything away from anyone, just sharing my experiances. gas mileage is a touch subject. different prople drive different ways and every little bit can make a big differance.
As far as driving cougar/birds, i can gaurentee I've got near or over a half million miles on these cars. i put nearly 180k on my first 86 cougar, about 20k on my 87 cat, 40k on my second 86, about 50k on my second 87 cougar, 80k on my first and second 87 birds, about 60k on my current 87 bird and so far only about 5k on my latest 86 cougar. there's also a few other cars i never recorded mileage on or forgotten about.
new best city mpg
Here is actual mileage on the Highway the other day, this was average after about an hour or so of driving with cruise on at 55-60.
X
new best city mpg
So you don't buy into the 21mpg updated epa rating either?
I'm not gonna have enough money to fill my car till friday to actually record mileage.
my old 87 bird was fully loaded with the electonic cluster. calculating actual mileage over an entire tanks was generally 2-3mpg lower then what was actually calculated by the computer. less city, sometimes off. more freeway.
new best city mpg
Oh, since i can't calculate this tank i too my mileage 380, added 10%(speedo is off by 15%. i jus
t swapped more appropreately sized 235/60's out back) and that would be 19mpg over the whole 22 gallon tank. I'm surr i havent used it all obviously. i probably have more like 8 gallons left id guess, but nothing stellar.
I'm gonna do a ton of driving next weekend. I've been without a full time pay check for a while. it will be nice to start getting one again
new best city mpg
Quote from: MY83T;432296
X
My 90 LS, which of course, had the 3.8L, only managed to get around 20, but that thing was beat to hell.
new best city mpg
Just a technical note- those onboard MPG displays have no real fuel consumption data being fed to them. They work from the VSS and Tach signals, IIRC. They probably have a base reference to go by, for instance, 60mph @ 2500rpm = 25mpg (or whatever). Any more MPH with less RPM equals X more MPG. Any higher RPM with lower MPH (such as climbing a hill) equals lower MPG. I don't believe it even uses the signal from the fuel sender (my sender in my old 87 went bad, and I believe the mileage computer still worked).
You guys probably already knew that, I just figured I'd mention it just in case anybody new was reading this.
EDIT- I was proven wrong- there is fuel data from the ECM provided to the cluster. Whoops!
CoogarXR : 1985 Cougar XR-7
