Topic: Purchased Newer Truck (Read 8614 times) previous topic - next topic
I found a 2006 FX4 F150.
X
X
X
Good trucks but be aware of the 100k tune up....those plugs are a PITA
Travis
Good looking truck Id love one but there all rotted half to death up here.
Enjoy, and tune ups not that bad just take your time and do some homework.
I have a 2000 f150 4.6 that has been my daily driver, I have had the plugs pop out on it, real (pita).
Sweet truck!! Enjoy :-)
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Nice!!
Id get rid of the lift and throw stock tires back on.
I had a 2004ish 5.4 work truck had 300+k miles on it and got 17mpg towing a light trailer and about 10mpg towing a 16,000lb mini excavator behind it. good trucks if you treat them right.
Quote from: 83TB;429258
Yeah, the older mod engines couldn't keep plugs in. Ford fixed that issue by making it so you couldn't get the plugs out
Nice truck!
Very close to my 05. My truck has been very good and tows well but I would lower mine instead of lifting it. I only use 4x4 for snow, not really into the off road stuff myself. Here is a pic of mine (not trying to hijack, just comparing) towing a boat last summer in the Rocky mountains. Seeing as I have been a Ford guy most of my life, it took me a year how to figure out how to turn on the driving lights! Enjoy it, they are really good trucks...
"][/URL]
1985 Turbo Coupe
1988 Thunderbird Sport
1996 F150
I was looking at stock height trucks, but my wife is the one that actually talked me into getting another lifted truck, she says its just not me to have a stock vehicle, lol.  She said you better get what you want, she did not want to hear 6 months down the road that I want wheels and tires or lifts or whatever, lol.  So I found one, my 2000 f150, is 2wd with 6in lift and 315/75/16 on it.
Nice truck!  And ignore all this talk of removing the lift.  Its a 4x4 truck, its supposed to set up high! Pansies...lol.
That lift is fine.  It's nowhere near Bro-Truck status.
Quote from: V8Demon;430083
Needs to go higher!X
I have an 05 F150 4x4 with 5.4 and 220k miles, so I can tell you all the things to watch for. The plug change thing is correct. The sooner you get rid of the motorcraft plugs the better, and replace them with the Champion. Put some of the Seafoam treatment in the tank and run it for about 2 weeks. That will loosen the carbon buildup on the plugs that makes them get stuck and want to brake because of their design. The Champion design eliminates that possibility. I was not aware of the problem until my truck had 90K on it, and my mechanic, fully aware of the proceedures and equipped with the proper tools, broke one of in the head. Had to pull the motor to get the head off to get the plug out. $2500 later?  The next thing is to always use the motorcraft 5w20 synthetic blend oil and the Motorcraft oil filter. This is necessary to protect the variable cam timing apparatus. These motors oiling system is very sensitive and it needs the proper oil to keep this system working correctly. Very small oiling holes in the system can easily become clogged and damage the system. Mine made it to 180k and one of the tensioners broke and a solenoid went bad. Since you have to pull the front cover off to get these, I had the mechanic go ahead and replace both sides. If it goes bad, you will hear a lot of rattling at startup that gets progressively worse. There is a ton of info on the web about both issues.  Man, I got this one and a 2006 6.0 diesel. Don't even get me started about the EGR Cooler!  Oy Vey!!!
