Topic: Looking for some door lock actuators (Read 1564 times) previous topic - next topic
OK.  It FINALLY happened.  The passenger side door lock actuator for my Cougar finally took a dump.  The driver side went a few years ago.  I've replaced it with an NOS Ford piece and subsequently TWO (yes TWO) more units from late model.  None of these 3 lasted longer than 18 months....The Ford unit was $130 disappointment most likely 'cause it's farmed out and not made by the same manufacturer as when these cars were new.....
Anyway if anyone has a set of the actuators laying around known to be good and in good shape, gimme a PM.  I'm sick of buying  that's new yet unreliable and overpriced and before I pull the pin on another set from Late Model, I wanna see if I can get some good used ones....
I have some good ones from an 88 TC that I'll ship, both for $40 total.
.  Just saw this....
Still got them?
I may have some squirreled away in my parts stash. Let me check when I get home tonight.
not to thread jack, but once v8demon gets sorted out I could use a set also :) thanks!!
I have one NOS one that I've Ben holding
It's a fox mustang one I'm sure there the same though
Quote from: thunderjet302;430084
Turns out I don't have any spares :hick:
No sweat.  I found one in mine!
I have a pair I just pulled from my old '89 Hatch 'Stang daily driver I'm parting out if anyone still needs a set.
Is the rod going into the actuator itself the same?  If so, I'll take them.
Demon, all the Ford lock actuators I have pulled and personally seen use a corkscrew style screw in end. If you have your old actuators, you could just swap the ends over to the replacement actuator.
Quote from: jangus;431564
Never noticed that.  Makes sense though.  Cost effective for a manufacturer.
If you still have that set PM me and we'll set something up  ;)
