Topic: Turbo coupe spring hight (Read 21464 times) previous topic - next topic
Quote from: STANG8U;425179
Just took a quick guess over what I know buildings mustangs over the meny years these springs should drop the bird around 2" give and take how I do it seeing how stock SN slings drop a bird
2" is what I'm looking for ........ I already have a truck lol
If it does work and drop it that much..im wondering if you need shorter sway bar end links and a bumpsteer kit?
88 Turbo Coupe 5 Speed..Full exhaust, K and N, Boost Controller
Even if it was around 1 1/2 it would still need a bump steer and cc plates to make things right
And I've never had a problem with sway bars
Quote from: STANG8U;425244
No issues with sway bars? I am running into a issue where the sway bar mount bushings were loosening up. A few people told me that the sway bar might under too much tension and that running shorter links might fix it. I myself had CC plates on my car when I bought but it was at stock height :hick:.
I dont have a bump steer kit on mine because I wasnt sure if I needed it..im starting to 2nd guess that now thou lol
Yea no issues lol
And if your car is lowerd it need a bump steer kit
I had -30mm eibachs on my coupe turbo and they made it awful to drive. I didn't change the shocks as i should have done.
No traffic In my other thread so ill bump this one
The springs did what I thought they would ...... Slam it lol
That's what I wanted and I'm very pleased the ride is not very bad at all and handles way better so far no issues
Now I need rims again I went from cobras to bigs and littles to ten holes lol
Another
I used progressive springs
I like thhe stance Stang8U !
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Thanks it almost looks like its on air bags lol
Big differance from a 4x4
The tie-rods should be parallel with the ground or at least that is what I have always been told as a good starting point with regards to bump steer if you do not have the gauges and plates to properly dial in the bump steer kit.  The sway bar ends should be parallel to the ground which is most likely going to require that you buy shorter bolts for the end links and shorten the spacer between the inner bushings.  From what I have experienced anything that drops a Fox Body more than an inch from factory benefits from the CC plates.
Darren
It's slammed it needs all of that lol
1 thing at a time
Mine's dropped around an inch, and I've got the toe adjusted as best I could using strings and careful eyeballing, with a tape measure thrown in for luck, and mine is....touchy...my tie rods are parallel though, so I'm guessing mine needs to spend a visit at the alignment place sometime. Much more pressing needs right now, however. A windshield being at the top of that rather lengthy list. I still do not wish to speak of the matter. Grrrrr.
The tie rods should be even with the ground when you lower a car it points them up a bump steer kit will drop them back down
That looks pretty sick..how hard does it ride ? What struts did u run sn95s or Fox?
Stock struts and shocks and surprisingly it rides good with the progressive springs
